Run a motor on pure voltage
  • Run a motor on pure voltage
    Hi everyone,
    It is possible to create light by powering fluorescent lights with high voltage, zero current.
    In the same way, is it also possible to conceive of a motor which can run on high voltage, zero current?
    Nick
    Originally posted by Kregus View Post
    Hi everyone,
    Nick
    Traditional physics says that the fluorescent tube needs a flow of electrons to create light. This is a current. But, there are stories of people waving fluorescent tubes underneath high voltage power cables and getting an effect from the electrostatic field.
    Also, funny stuff is coming out of the world of Van Der Graaf generators, Hyde motors and so forth.
    It would behove you to check out these folks:
      how about...
      a rotating electric field?
      Don't expect much power unless you would use really high voltages.
      Ernst.
        Hi everyone,
        Nick
          Hi everyone,
          Nick
            While agreeing with everything posted above, I wonder if wave form is the key to running a motor with pure high voltage. It has been argued that a sharp transient voltage spike will be immediately followed by an influx of radiant energy into a circuit. If this radiant energy can be captured and fed into a capacitor, perhaps then you might have access to the required current. You'd need a PWM or similar device for this. I haven't tried this, only seen Bedini's videos - just a thought.
            Bob
              Interesting! Do you have a reference?
              Ernst.
                Ernst.
                I have never seen anything that actually proves it, but the transmission of energy without wires (well, 1 wire) does seem to show the effect.
                The method I used was pulsing an ignition coil with the HT connection going to a 1 foot long 8mm brass rod. If I held a fluorescent tube in my hand within 10 feet I got a slight glow. At a distance of a few inches the glow was approximately 20% of the tubes brightness when powered conventionally. There were no wires on the tube, the only physical contact with the tube was my hand. The tube was also brighter if, with my other hand, I held a grounded wire.
                Clearly this could not be considered normal electricity as there was no circuit, air being considered a reasonable insulator. Also the glass of the tube itself, which I was holding is considered an excellent insulator. All the voltage and current from the source was returned to the source via the primary.
                With this in mind, anything in the open secondary circuit must be considered radiant as it can pass through air and glass, and must be from a different source.
                Google "imhoteps radiant oscillator" and ""imhoteps radiant oscillator lite" for simple and easy examples of this.
                  Ernst.
                  Ernst,
                  I don't have a reference handy, but Tom Bearden makes this point in the Energy from the Vacuum series, I think it is. He likens it to the transient spike "poking" at the vacuum's omnipresent energy, and the vacuum pushing back to restore balance to the electrostatic environment. I believe there are a number of Bedini videos showing him catching the inductive kickback from a transient spike with a secondary coil and dumping it into a cap for regular use.
                  Someone on one of UFOPolitics' threads built a pulse width modulator and showed how he was able to run a DC motor using pulsed DC, with tremendous amounts of torque. Ordinarily, this would only be possible with a large amount of current, but something else happened. Come to think of it, it may have been square waves. But in any event, UFO was maintaining it is the off times between transients where the RE comes into the system. I think frequency is key here. You start poking the aether or vacuum with the right frequency, the aether pushes back with a stream of radiant energy, and perhaps it is from there that you have access to what is necessary to providing the required torque. In this way, it may be that HV is all that is needed, and the vacuum provides the rest.
                  Bob
                    Who needs current?
                    Do your homework...
                      This reminds me of the Bob Boyce water electrolyser (fracturer) which requires pulses with a very sharp rise time and fall time, at 42.8khz, the frequency mentioned by John Worrell Keely.
                        Wow, that's the nicest motor of that type I have seen, I would be interested to see other similarly well sorted motors of that type, if you know of them.
                        Unfortunately being the size of a golf cart motor, its practicality in this state of development is limited. As you know it is relatively simple to produce a motor of similar performance using low voltage and a higher current with lots of windings. A good example being the window motor By JB. these motors also have the advantage of being able to recycle the power producing interesting efficiency results.
                        It was the point of practicality that I was making.
                        Our enemies in a motor using current are BEMF, impedance and resistance but all these problems are related to voltage drop. Eliminate the the size of the voltage drop and we have something that can be exploited.
                        Resistance can be lowered by using bigger wire but this increases the motor size and its practicality. Impedance can be lowered or manipulated through transformer interactions, but we have the associated iron and air gap losses to take into account. BEMF can be mitigated or reduced by geometry and additional equipment.
                        The answer to the original question is yes, it is conceivable to produce motors that run on high voltage and virtually zero current, but it is also conceivable to run motors on high current and virtually zero voltage.
                        When talking of motors we want mechanical power, it is the current multiplied by the turns that give this in conventional physics, provided we get usable speed.
                        My second point is don't be afraid of current if we don't have to generate high voltages to get it. I know that this goes in the face of many people on this forum, but its always best to keep an open mind. In truth all these devices require a certain level of compromise, and personally I believe the solution will be found in the use of moderate voltage and current, just my opinion.
                        BTW I appreciate all the excellent work you have done, keep up the good work and keep sharing
