Super MEG
  • #16
    Franco Menghini only took inspiration from the work of the Iranian student, he goes his own way and keep us constantly informed of its progress
    • #17
      Franco says:
      the permeability of the m5t30 is around 40,000 times, but still have not been able to determine the maximum achievable inductance , I'll do it before starting the main windings of 64 turns cd . with those senses , surely I will use magnets to manipulate the 35x20 20x10 very best from 38 kg of force - I also hope that the voltage pulse that comes out to be larger than for the sake of construction . the student Iranian triggered its meg with a single pulse of current that then did resonance between the coils to a difference of the loop between the two and a system of fast diodes and two capacitors -
      the core section where there are the two coils is about 1 cm2 , while the central 2 cm2 .
      I want to clarify that between m5t30 metglass and there are considerable differences which 40000-500000 1/12 , 5 is a great deal -
      but it was realized that the sheet material is not a product but made ​​with a 3D printer.
      I was saying that he had used the magnets of the motor drive CD sectoral covering ( 2 in series ) across the surface of the core. the size of the object of the student resolves the palm of your hand - the tension that pulls out is reported at around 13.39 volts and lights a votive lamp w 12 volt 1.5 for more than 3 minutes, the duration of the filmstrip . We also lights lamps 45 watt car - with regard to the supply of the coils of diverting MEG bearden I used a normal square wave generator of new electronics to see the possibilities of use and of course it does not work due to direct connection the low inductance of the coils 24 that I used the trasdormatore concerned but goes to great resonance in series with appropriate capacity
      • #18
        Device of iranian student is not fake:
        • #19
          Hi Franco.
          Could you tell us a little bit more?
          Ben
          • #20
            Franco menghini says:
            the adoption of saturation comes from student
            while the adoption of small magnets is always the student but also by considerations on the versatility of tests
            and make possible the danger of manipulating large magnets I had already used 38 kg-27 kg lagneti 30x10 and I got hurt on his fingers.
            the deviation of the flow with the same coils is dictated by experience with the construction of coils.
            and I think it will prevent surges as they are the ones belonging to power the electric-drive which forces arise in the exact same time as those of power, while in separate streams may be affected by the missing that there are many and intensi.nelle vicinity of the magnets . --------- is by no means an error ------------
