Quantum energy generator
  • #31
    Originally posted by prembold View Post
    The Taiwan team hasn't looped the system yet, but they do have it outputing a few hundred watts - - this is getting good!!!
    John, don't know if you saw this on their website:
    In the QEG, there is no internal, common exciter coil, and no rotor windings. In addition, to look at the circuit diagram, it is not apparent where the input power comes from to start resonance, and this is key; the QEG exciter coil is external to the generator, and the excitation signal is conducted through the quantum field (zero point) into the generator core, to start oscillation. Once the machine builds up to the resonant frequency, it powers itself (self running). James M. Robitaille​
    I posted this already on another thread but it may be worth repeating, and I'm sure any good auto-mechanic could confirm it. Car alternators (new ones I think) don't have an exciter coil (or permanent magnets) like older models had, relying instead on the residual magnetism in the iron core to initiate charging. If these alternators are left on the shelf for an extended periods, no matter how fast they are spun, there is not enough residual magnetism available in the core to initiate charging. They must therefore be pulsed briefly with a battery until the required residual magnetism-threshold is reached or exceeded. This 'excess' will persists in the core for months, so with normal car usage, there is no need to ever have to do this. There's a video somewhere on Youtube about this.
    If the QEG operates similarly, there may be no need for any of this "zero-point" stuff to explain how power generation is initiated.
    Having just watched the Taiwan video, it's promising to see that there does seem to be a type of resonance involved - no real power produced at low speeds, followed by max power-out at a higher speed, then a significant reduction in output at a still higher speed.
    • #32
      sprocket,
      No, it doesnt work to store the Energy for 10kw as it is claimed at the iron core or the rotor, only through temporary magentizing.
      It also shows that you need a resonance to get this Power out not only a magentized core
      • #33
        Originally posted by Joit View Post
        sprocket,
        I never said anything about how the 10kw is generated, I am only talking about how the power generation may be initiated. In other words, how is the magnetic field needed to generate power created to begin with? Not by permanent magnets or electromagnets apparently. You can spin an old-type alternator till the bearings burn out and they won't generate any power unless the excitation-coil is powered. Once power starts being generated, you can disconnect the excitation-coil and the alternator output power is in no way diminished - simply because a small percentage of power being produced is fed back internally to maintain the magnetic field. I personally thought that all alternators (generators) needed an excitation-coil in order to begin generating power - until I saw a Youtube video pointing out that the latest alternators don't use an excitation-coil at all! This may have been obvious to you, but it wasn't to me. Nor am I saying that this is how the QEG works, it's just a suggestion.
        The video shows an apparent power increase at 'resonance', but since we don't know the power being input or being produced, we really can't say if there is any additional power being produced. You could easily breadboard a circuit that would show precisely this effect - tune to resonance for maximum output - but no one would claim that it is over-unity. Of course, if these guys have powered 10Kw loads while inputting considerably less, then it's an open-and-shut case! I really hope it is, I'm sick of paying through the nose for electricity.
        • #34
          Yes, the initial power comes from rest magnetism from the core. I stated that at the Witts generator too from vidbid. A Friend got a Generator what has no external input. I asked an EE how that works, that the Generator come to power again. He said, that the magentism at the core inside is enough to self-excite the rotor again and that his how he comes back to full power from about 2-3 kw. At a circuit i assume that the output is lead over the rotor, but at last one from the coils. Just that thing runs on Water. But at this Qeg some will still ranting sooner or later that it seems to produce 10kw from a 1kw Motor.
          And that is what you better dont try to explain from restmagentism.
          • #35
            I found that vid from 12/11. I just hope that this girl not only had a good business idea and used the Witts generator to promote it.
            • #36
              We will be watching this project closly, still thinking the best for HopeGirl587
              However we just got word back from a friend that is a retired telecommunication engineer:
              Still liveing in hope for HopeGirl587.
              Watching her Taiwan trip, to see if she leaves with a happy team.
              I want to beleave, even after Bert's negative thoughts - time will tell.
              • #37
                Quantum Energy Generator Forum :: Topic: IMPORTANT UPDATE: from the Taiwan Team - April 6 (1/1)
                • #38
                  Sterling Allan observation:
                  "...One thing that is important to know is that this QEG is still in the R&D phase of being characterized and optimized. It isn't yet to the point of stability that is ready for people to build and power their homes with it.
                  The Fix the World organization wanted to open source this R&D process to speed the development time..."
                  • #39
                    News
                    High voltage burned coil windings.
                    Go to forum and read most recent posts!
                    Plans are already afoot for a proof of concept small model.
                    http://be-do.com/media/kunena/attach...pt_miniQEG.pdf
                    Potential, is a terrible thing to waste.
                    • #40
                      • #41
                        it's possible to start from autocad dxf file with imperial measurements:
                        h*tps://drive.google.com/file/d/0B-UG88wHB6NOS2VkS1BfZl80Z00/edit?usp=sharing
                        h*tps://drive.google.com/file/d/0B-UG88wHB6NOZ0REOEk4S2lyOW8/edit?usp=sharing
                        h*tps://drive.google.com/file/d/0B-UG88wHB6NOZTM1bTFHdHJzVUU/edit?usp=sharing
                        h*tps://drive.google.com/file/d/0B-UG88wHB6NOamZlT2lKQUYwNkU/edit?usp=sharing
                        h*tps://drive.google.com/file/d/0B-UG88wHB6NOczdMMk44aGRXRlE/edit?usp=sharing
                        h*tps://drive.google.com/file/d/0B-UG88wHB6NOeVh6cHJ2eWpnWkU/edit?usp=sharing
                        • #42
                          Complete Explanation of Theory
                          James (inventor) explains to Sterling working theory of operation.
                          Very interesting.
                          QEG Effect Replicated by Taiwan Group
                          See last video on page!
                          • #43
                            UPDATE: April 7 - QEG team in Taiwan
                            Quantum Energy Generator Forum :: Topic: UPDATE: April 7 - QEG team in Taiwan (1/1)
                            From James from the FTW QEG team in Taiwan:
                            Hello All, This is James. just wanted to post an update to let you know how we made out with resolving the insulation issue... It was another amazing day! As we said, yesterday we stripped all the wire off the two primary coils to prepare for replacing the insulation and rewinding. Today our host took us to a winding company here in Taiwan that also specializes in developing insulation systems.
                            This is one of the top 3 companies in the country, and one of the best in Asia (our host has amazing connections). They build coils for some of the biggest names in the world, and we had the entire design team in the conference room! It was amazing to watch their faces as we began to explain what the QEG is and how it works! (we get that all the time).
                            So they were intrigued and excited, and agreed to take on the repair. They will also build up Taiwan's second (bare) core with their improved insulation system from the bare core up. They confirmed almost immediately that what was needed was interlayer insulation to prevent this happening again, and to ruggedize the design.
                            So they will add mylar interlayer insulation and rewind the two primary coils on the first core, and they say they can complete it by end of work day tomorrow. We'll go pick it back up tomorrow evening and put it back together wednesday morning, to resume tuning and testing.
                            We have also conferenced with Torelco tonight, and they will add the interlayer insulation to all orders going forward. Our basic groundwall (bare core) insulation system, as described in the user manual, has proven to work well, so anyone out there who has been waiting to see how this went today, can proceed with winding, adding the interlayer insulation. Of course, if you are expert with High Voltage coil winding techniques, and wish to try it another way, go ahead by all means, and let us know your results.
                            • #44
                              What may be a contribution to the experimental QEG development.
                              Fun to try to figure out, in any case...
                              Published on Apr 10, 2014
                              Yesterday, woopyjump showed (on youtube) that simply tapping an iron core would generate a voltage in a winding around that core (MOT secondary). Rather surprising result. So I'm trying a variation of his experiment.
                              Using the secondary of a Tesla coil system that I've had for years, I place an iron core down the center = a heavy window weight that I had. Weighs about ten pounds.
                              Sure enough, when I tap the weight, or just rub it with pliers, a ringing sound (acoustic resonance) is set up in the iron -- and there is a voltage produced across the coil, as seen on the oscilloscope. I'm seeing 15-20 V peak-to-peak quite often.
                              This observation, which I don't fully understand, appears consistent with an important claim of the QEG team, as we seek a new path to generating significant electrical power.
                              • #45
                                Quantum Energy Generator Forum :: Topic: GERMANY GOT RESONANCE (1/2)
