HHO Gas Injected Into A Catalytic Converter Yields Extreme Heat! LENR? We Don't Know
  • Thank you Kindly Shellshocked
    I took the privalege of starting a few topics on Langmur
    Here
    103 cal/gram molecule to dissociate hydrogen yeilds 90.000 cal/Gram Recombined
    and here
    langmur and his findings 103 cal/gram in ------ 90,000 cal /gram out
    Very nice indeed.
    Chet
    BE that change !!
    • Originally posted by Gdez View Post
      @ beamgate,
      After looking at my old 7 plate cell, I've decided it would be better to build a new one. I would be interested in building a cell to separate h&o if you have any links.
      I have seen some stuff on the forums already about this, but I can't remember the thread(s).
      Thanks ,
      Greg
      @ woopy-- good ideas
      Hydrogen Separator Cell FREE separator cell design which is the standard for most designs on the market but its complicated to construct by hand.
      My website is jdcproducts. I am in no way trying to promote my website but I did design a unique split gas cell thats easier to build than the free version listed above. The plans are not free but you will not find another design out there like it.
      • Woopy is finding some inteesting reactions with his new toys
        CAT to LENR approach 5 wmv - YouTube
        thx
        Chet
        BE that change !!
        • Hello,
          I have ordered everything I need now to get started! I hope to have it all put together by next weekend then start testing. I think I will make my own reactor after I have the basic one working.
          Total cost so far is around $500
          -Altrez
          • @Altrez,
            Which one you get, man?
            I'm still waiting on individ parts for my cell and plumbing ...
            Resonance to all !
            • Low Energy Neutron Reactions (LENRs) in Automotive Catalytic Converters
              • Originally posted by Beamgate View Post
                @Altrez,
                Hey,
                I got this kit on sale for $199 I know three other people who have this kit and said it has been perfect.
                Whole Set HHO Hydrogen Generator Dry Cell Brown Gas Electrolyzer Gas or Diesel | eBay
                I also got some meters and a PWM to adjust current. Working on a electrolysis circuit to see if I can get 1 LPM on less then an AMP.
                -Altrez
                • Hi all
                  Hydrofuelincanada seems to approach a good solution to avoid the flashback when we approach the torch to near the cat.
                  And he dilute the HHO jet with some air .
                  I just tried it at my very little niveau and i used a barbecue ventilator , a part of the output, i directed to a hose in which i inserted my seringue torch .
                  And it seems to work fine, as after the very small 5 mm thick piece of catalytic converter, i get very hot temp, ( more than 150 degress celsius )
                  hope this helps
                  Laurent
                  • Hi all
                    here one of my further test on this subject
                    CAT to LENR approach 6 wmv - YouTube
                    hope this helps
                    Laurent
                    • Originally posted by woopy View Post
                      Hi all
                      hope this helps
                      Laurent
                      very good result
                      • good reading :
                        • Update 02/05/2014
                          MY HHO kit should be in tomorrow! I also have ordered some platinum bullion thats %99.9 pure and some palladium thats .999 I want to see if the gas has any effect on the platinum and palladium alone or its something else in the mix.
                          -Altrez
                          • post?
                            Originally posted by lamare View Post
                            Hi Mike,
                            Can you tell me where this post of Mike's is? It won't come up in this thread. Can you post a link to the actual post number? Thanks!
                            • great thread!
                              This is a fascinating subject of putting hho into a cat to produce heat.
                              I sent a lot of traffic here from my newsletters so I hope more people get interested in doing the experiments. jdcproduct, thanks for starting this thread!
                              Good luck to all your builders!
