One topic I can't seem to find is the subject of 2 or more electrical streams running through the same circuit at the same time. An example being, if you have stream A with volts and current at 90degrees and stream B that is identical except for an offset in timing so that current B is at 0 degrees from voltage A and current A is 0 degrees from voltage B then will the two reactive streams shore each other up and equal one non-reactive stream with a funky stutter step?
