Got Magnetic Induction running right on Class E Amp
I have been testing Class E all this month and finally got the result I was looking for.
First of all, I needed high current and not high volts. I rebuilt my power supply just for this purpose.
To get high current, I cut out the secondary of a microwave transformer and relaced the secondary with 16.75 turns of 14 ga. insulated wire. This produced 16.6 VAC. When I put in a full wave bridge and a 3300uF Capacitor, the unregulated came out to 22VDC. The unregulated 22VDC went to the Class E stage.
I built a regulator using a Zener Diode and a Series Pass Transistor (MJE13007) which gave me a regulated 13.2Vdc. The regulated 13.2VDC was used for the Crystal circuit and gate driver circuit.
Most of all, I switched to a 100V 180A MOSFET (IXTH180N10t). They were $4.025 each at Digikey (in quantities of 10). The 180 Amp was overkill, but gave plenty of margin, so I would quit blowing up transistors.
I also rebuilt the Choke Coil using less turns and a less permeable toroid. It read .37 mh (370 uH). I kept with the auxiliary coil since previous test worked well with one. I think the Auxiliary coil will become a standard on all my RF and SMPS projects.
Worked great. The frequency remained stable, even with a load. I put a clamp Ampmeter on the MOT secondary and no load draw was 4.5 amps. Then I put in a steel screwdriver as a load. The Amps increased up to 8 amps as the steel got hotter.
I think I finally understand Class E Amps. Here is my updated circuit:
