Originally posted by Mad Scientist
The domestic fusebox, the consumer unit, needs a convenient
switch to connect it either to the town's LX supply or to the
generator. (The switching may take place under conditions of
considerable stress - in the dark, hurricane weather, screaming
kids and so on. It needs to be easy and to be performed in
blackout, possibly with the help only of a torch whose batteries
are almost dead).
N.B. We don't know the current rating of the unit as yet.
At the level of the house, the power need should be around 2.5Kw,
10 amps in the UK or 20 amps in the US with their 120 volt standard.
Its plenty enough to run the CFL lights, TV, laptops, water pump, washing machine, microwave, freezer and furnace. The home background level is only around 350w while the heavy load items need to be used one at a time. It can run off the car battery with the engine running via extension cord back to the house. Be aware it pulls over 200 AMPS on heavy loads. Basically you can live pretty much as normal just make sure not to use anything that heats up like toasters, hair dryers, water heaters etc. If you are not sure unplug everything first then add the essentials.
