Energy Amplification by Tito L. Oracion
  • Energy Amplification by Tito L. Oracion
    International Alternative Energy Center->>>>>>>>>>>>>>>>>>>We recomend inline fuses on all builds. - Energy Amplification by Tito Oracion - Powered by ForumCo.com - The Forum Company
    The circuit discussed is one by gyula using a precharged cap with fast switching charging the primary coil and back emf pick by secondary coil to charge back the caps pick coil produced from the resonance
    any ideas/ input are welcome
    totoalas
    I remembered Tito Oracion from the old TPU discussion. That was ages ago, but he kept saying something about energy amplifier. One of those threads, he gave a hint about its operation, but people got fed up with him.
    Basically, he ripped the idea off from the hard work of Wattsup, TPUBruce, Otto, and other members in the TPU research. He kept bragging about it without disclosing its intimate secrets even though he clearly got the idea and solved the technical problems with help from the forum members. I thought he was just full of it back then, but it seems he truly did built and patented that idea...sorry, but i'm just a bit disgusted.
    anyway, you might get a hint of his machine's operation by scouring through the old TPU threads at Overunity.com
      Hi.
      I've come across this research paper and the results speak for themselves.
      Osamu Ide - Increased voltage phenomenon in a resonance circuit of unconventional magnetic configuration
      Parametric resonance and opposing magnetic poles, that's the KEY!
      It would explain Magnacoaster's and Romero's devices quite well...
      I think I'll build a setup for this
      Cheers!
      kEhYo
        KEHyo77, i Cant read your link...
          Originally posted by kEhYo77 View Post
          Hi.
          Cheers!
          kEhYo
          I set up a capacitive system using coils and plates and also notice I only get charge separation if the poles are opposing.
          Here I used bare wire and weedeater string but changed the winding to insulated wire, works better, I used the aluminum cone from an angel food cake pan.
            arc/plasma charger 090213 yt toto alas
            hi
            when earth and additional coil was removed
            the caps are still charging
            the spark is changed to plasma when earth is connected same as Peter Linderman
              Hey Totoalos
              what schematic did you guy's settle on.
              dave
                Hey Totoalos
                dave
                Hi dave
                Tito circuit 3 which was used by romerouk
                And positive results
                Fpr onitial test i ised the circuit with red box in gyulas tito circuit 3
                Instead of switch i ised a spark gap relay from the open output contact of the swatter
                No earth is neefed as the arc is charging both caps
                With earth the arc is boosted into plasma sa peter lindermam showed on his plasma mod
                Hope you can imput your valuable experience in the ou forum
                Enerhy amplification thread
                Totoalas
                    ENERGY AMPLIFICATION
                      Energy Amplification Pt. 2 Circuit
                        Tito L. Oracion circuitry resolved?
                        A lot of backslapping and such going on at the other overunity place about the abovementioned invention. Anyone here somewhat current with matters?
                          totolas
                          Ok.I had registration problems but are solved now.Thanks.
                          • #14
                            I don't think it's solved yet, but good work is being done to identify the key elements of a working system. I think the principles involved could result in a few different inventions, but using the same basic principles.
                            Bob
