OK, let me explain what you see.
There is an iron wire leading to one side of the caps, this wire is connected to the ground.
The whole set-up is located on a 5 m deep ground pin to which I can make connections.
The LV side of the secondary is also connected to this same ground pin.
The green insulated wire with the uninsulated end is the other HV end.
The other side of the caps (12x75pF/5KV) is connected to the metal disk.
The caps get charged when I switch the power supply on even though there is 23 cm space between the HV end and the metal disk.
I do not see any cheating in this set-up.
But let me make you and every one else here a proposal:
This secondary generates about 175 KV (if I remember correctly, I can check later) at a frequency in the 500 KHz range (I do know the exact value, but I do not want to post it here, and no it is not 504 KHz
If you have any idea what you would like to see tested with this set-up, of course it has to be related to the subject of this thread, tell me and I will see what I can do.
First thing I will test is if a leaf is attracted to or repelled from the HV output. (as soon as time allows)
OK? Any ideas?
Ernst.
)If you have any idea what you would like to see tested with this set-up, of course it has to be related to the subject of this thread, tell me and I will see what I can do.
OK? Any ideas?
Ernst.
