Thermolysis of water
  • Thermolysis of water
    thermolysis of water
    Sending water vapor in the reactor produces hydrogen gas, fuel, and oxygen, which is split:
    We can use also the thermic generator atomic hydrogen:
      Tachyon, how can you separate the hydrogen and oxygen gas?
      ____________________________
      Autocostruzione
        you can seperate oxygen from other gases using a magnetic field..
        The pure in heart will see the light.
          Tachyon, do you think that we can also produce HHO with this reactor?
            franco may I suggest you look into photolysis cells instead.
              What your goal? Fuel for car or house?
                For car and for house:
                  it's funny how this could actually work.. combining photolysis , radiolysis and collisional dissociation.. in one device. ( electric field must be controlled )
                  Radiolysis - Wikipedia, the free encyclopedia
                    I do not want to complicate things too much, you do not want to combine optical resonator and tripolar fuel cell ...
                    Autocostruzione
                      you can use photo-transistor material instead
                        you can do a Y tube and form a right hand wounded coil in one tube terminal and a left hand wounded coil in the other tube terminal and connect the one coil and to + and the other to -, it will seperate oxygen in one side and hydrogen in the other side..
                          Tachyon, you're great!
                          With a membrane which separates water vapor from atmospheric air,
                          the system is perfect,
                          much better than traditional electrolysis ....
                          • #14
                            water vapor membrane
                            • #15
                              reactor for large amounts of gas, without semireflecting mirrors:
