The GEGENE : a Great Efficiency GENErator with a Tesla bifilar coil
  • The GEGENE : a Great Efficiency GENErator with a Tesla bifilar coil
    JLN has released a new device he is working on, with promising results so far.
    Here's the link: The GEGENE : a Great Efficiency GENErator with a Tesla bifilar coil...
    Measurements taken with a scope:
    TEST #2 : Efficiency measurements with a digital oscilloscope
    Results:
    Input: 1050 W
    Output: 2014 W
    It has some limitations as to what you can run with it. From JLN:
    Concerning the load connected at the GEGENE output, you must use resistive loads such as halogen lamps and compatible with you country grid line (i.e. 220V in France). Don't use devices which have an electronic board inside because they don't work when they are connected at the output.
    Very interesting, very simple to replicate. Anybody have thoughts on this?
    we might be able to use this to charge batteries, though making the voltages line up might be an issue. This appears to have some promise.
    If you could tune the 2 coils, you might be able to increase the efficiency.
      Here's another replication by woopy, similar results as JLN, but no scope:
      gegene replication 1 - YouTube
        here's another discussion of the device, people raising good questions:
        1850 Watts free energy power ? New GEGENE circuit by JL Naudin shows COP = 2.8
          New test by JLN shows 96% efficiency, no OU:
          TEST #3 : Efficiency measurement with a calorimetric method
            You need to look at test 5 (and test 4 done by Romerouk with a grid tie inverter)
            Quite impressive
            Mike
              Here is the page of test #4: TEST #4 : First test of a closed loop system with the GEGENE by "Romero UK"
              Test #5: TEST #5 : New efficiency measurements with a digital oscilloscope with more power
              Test 4 is a self runner, very interesting indeed! Test 5 was more load and better scope measurements.
              Test 5 results:
              Input: 1805
              Output: 3819
                Actually, test 4 is not a self runner, it is looped. Still, it shows evidence of more out than in.
                The real test, IMO, is to set this up to run off a battery and loop back to charge the battery.
                  One to watch
                  While no ou has been proven yet, this is a good thread to watch. Naudin, romero, tk , woopy, etc....all into it. These are good replicators to watch in my opinion. Also the fact that it a basic Tesla design. Very easy to replicate if you pay attention to the basics. Woopy and Romero's vid's where pretty interesting. The light bulb part seems to need to go away and maybe start doing some motor/ torque work. This could make this a winner.
                  I suggest;
                  Stay tuned on this one, woopy's last coil waving demo was very interesting.
                  Good luck,
                  Gdez
                    I have not seen anything mentioned about matching the impedance of the pancake coil to the driver coil at the given frequency, or any consideration along those lines...Did I miss that?
                      Did someone try with stell pancake coil instead of copper pancake coil?
                      Sorry for my english... I speak french to!
                        I suggest;
                        Good luck,
                        Gdez
                        definitely some interesting test results from well respected replicators. I am watching this one very closely.
                        I think battery charging would be another good test.
                        apparently, it requires resistive loads, not inductive loads, so that has to be considered as well.
                          my test
                          My rough and quick test as a contribution to this discussion:
                          Światło z kuchenki indukcyjnej. / Light from induction oven. - YouTube
                          (switch English subtitles on if you don't understand Polish)
                          • #14
                            Hi Sciencisto,
                            Do you mean in your experiment with the induction stove, the output to the Tesla Bifilar coupling coil are only approx. 700 Watts?
                            So the bulbs are not completely lit?
                            Is it not that an Amplitude Modulated wave packs energy within, since the induction stove coil is oscillating at 22KHz and modulated by the 60Hz mains freq. Demodulating the wave would release the energy within, or am I missing anything?
                            aaron5120
                            • #15
                              It would be safe to assume that resonance is everywhere.
                              With an oscillating source driving L and C items, you are likely
                              to want resonance, if only to maximise results.
