Originally posted by rosehillworks
Friction heater running in my house
The RPMs on the drive shaft is around 850 RPMs. The faster the RPMs the higher the temp but the more load on the motor. The trick is to find the balance. There are trade off for everything but its really just finding the rightOriginally posted by lota View PostHello,
how much rpm your heater has and where for the pipe is in the middle
thank`s
Greeting
Lota
combos for what you need.
Hello,
I have to 12 disks 3*200mm and 12 disks 3*235mm. With 1.5 mm of distance. But it runs very hard. I need 1 kW for the imput.
What you say to this patent.
Patent US4685443 - Hydraulic friction heat generator - Google Patents
Lota
Hi LotaOriginally posted by lota View PostHello,
Lota
Something I have learned after playing with this for about 1 year now is that "LESS is MORE". If I was you I would try a less viscus oil and try running less discs and you may also want to try a slower RPM. Hope this helps.
Very interesting!
Hey Slapstick,
Very interesting device. I'm looking forward to seeing more data. Immersing it in water sounds like a good test. What temperature does the vessel body reach? In how long? Does applying more speed give you more heat or do you reach a thermal limit?
Keep up the great work!
slapstick
I am going to replicate your heater and use it in my house are the specifications the same as you first had them? if they are not can you please
let us know what they are, and would you mind posting where you think the best place to get the parts made is. I think you did that in the other thread but it would be nice to have it here in this one.
William Reed
slapstick
Here are some specs from the heater I built.
The Top, bottom plates are made out of 304 SS .500 thick or 1/2inch
Body: Is a 8" tube heat sized to make it round the trimmed to 10"
Shims: also made from 304 SS @ .1875 thick or 3/16inch
The Drive discs and the stationary discs are made from mild steal @ .0625 or 1/16inch
I had them laser cut from Brill metal works out of Medford Or. ( they did the work and supplied the metal cheaper then I could buy the metal so it was kinda of a no brainner to have the do that work for me
the drive shaft it 5/8 bar stock from Ace hardware
Oil: 100% organic soy been oil from Wal-Mart
the heater take about 1 US gal. to fill up
I am running 24 discs total so that is 12 drive disc and 12 stationary discs stacked up in between the drive shims and the stationary shims.
The discs spacing is .0625 or 1/16inch between the drivers and stationary
Stationary Disc: OD @ 7.75inch with a 1.5 hole is the center.
Drive Disc: 7.00 inch with a 5/8 hole in the center for the drive shaft to slide through with a keyway slot cut out to hold the discs.
Then I used a high temp 700F caulking to seal it all up.
Have you changed it since you made this post ?William Reed
Hi VincevlOriginally posted by Vincevl View PostHey Slapstick,
Here are some numbers I have gotten so far. The temp will rise 3F every 1 min until around 300F then I have to change the rotor speed to get more heat. I have had the core to 400F witch is just below the flashing point of the oil. As far as a thermal limit goes, well I guess it depends on how much power you want to use and the oils you are using. I am sure if I wanted to run a larger motor and higher voltage, then you would be making more heat faster for lets say an on demand system. The system I am running in my house is more passive witch uses less power. It's really all about scaling it up or down to fit your needs.
The way this core works is the more heat it makes the cheaper it is to run, so there is a sweat spot.
I am using this heater to heat my full house and it is working better then I was hoping for.
I had this apart for some up-grades, and my house was 60F for 2 days on the inside. Needles to say my wife and kids were complaining about how cold it was inside. As soon as I got it back together, I turned up the thermostat to 85F and in about 4 hours or so my wife was asking me to turn it off. By the way 4 hours of run time cost me around .30 cents give or take.
I would like to say that it is nice to see people building this heater.Originally posted by rosehillworks View Postslapstick
As far as the parts go I had the discs laser cut out from a local company. I machined the rest of the parts from raw goods. My prototype that you have seen on my youtube channel is made from mostly 304 SS. My new heater cores that I am making are made out of Aluminum for better heat transfer.
You can Chose to do this your self if you have the tools or have a machine shop do it for you or you can have me do it, how ever you chose.
Good luck on your build, if you need any help just send me a message and ill try to help as much as I can.
Thank you
Gabriel
There are some changes but this is a good place to start. It really depends on how you are going to use this style of heater. Feel free to contact me if you want to.Originally posted by rosehillworks View Postslapstick
Thank you
Gabriel
nicely that still somebody builds on it.
I wish you success.
. My discs are from Alluminium. The engine is adjustable to 20000 rpm 2 kW.
Lota
May I ask what kind of heat you are getting from the heat core you have made?
My new testing heaters are full Aluminum as well. I have one as small as a coke can and runs off of 12v power @ 2 amp.
I would love to hear some data the heat core you have built and how your are testing it. Were ever able to get the power consumption down as low as mine?
If not it may be your power plant you are using. I am sitting next to my heater as I am typing this and the core temp is 250F with 500 CFM's blowing across it and the Watts read at 600. The motor to run with no load takes 500 watts so that means that the core is only using 100 watts of extra power. With the total system power using 600 at the moment. Its 78F inside my house and its 28F outside.
Thank you
Gabriel
Hi folks, Hi slapstick, thanks for sharing your work.
Had to chime in, though not much to share.
Replicated those plans found on net many years back, with the large paint can as the rotor and used aluminum flashing for the outer hull, 1/8" gap or so between outside of paint can and inside of outer hull.
Used treadmill motor with small belt to rotor.
Used high temp auto sealant and high temp JB weld to glue together outer hull seem.
Only problem, was not very focused at the time, unfortunately and used water inside and did not see any heat, though bet a thin oil might have worked.
Though of course the tolerances were nothing like what you have.
Though have seen others that claim to have achieved high heat from things like a soup can inside of each other with small gap.
Makes me want to try and rebuild it with tighter tolerances, you know, elcheapo method that works fairly well.
peace love light
tyson
This is part of the plans used to build device, sure many know of these plans.
Uploaded with ImageShack.usLast edited by SkyWatcher; 11-14-2012, 07:56 PM.
