By moving a "Massless, Weightless and Invisible Magnetic Field" at super speeds, Frictionless, through Massive iron cores and Pounds of Copper Wires...with absolutely NO mechanical EFFORT whatsoever...except for that of a tiny motor and a small brush riding a commutator...
Oh...and I forgot also a brushless fan motor...consuming 12V and 0.12 A to cool off everything there...
Oooh!...and it is "kick back" ...not "back kick"...
Hello everyone:
I realized that it is possible with the G part, to fool Lenz into the inductors, if this is so, we will have the exciter
Matu can you put word to: "I realized that it is possible". What possibilities do you see? How?
If it is the "part-G" alone producing 100 to 200 times amplification of the input power it should be relatively easy to find out.
But if the "part-G " needs the primaries also for it's operation, it's more complex because for instance we don't know how big the mutual coupling between the primarys are tru the Y-part (secondaries) if any coupling thru that at all. Or between each other.
And here on this thread before; I , MM, many others and Dough indirectly have showed several types of "part-G's" from a split type, resistances, CW-CCW to "super short cut"!
Which one is your pick?
Matu; Sorry, me personally i can't see the possibilities to Over-Unity with a "part-G" consisting of resistors. . . . . .It's only marathonman who can.
He claimed three times OU from his test unit as I have refered to in one of my posts here before.
Your ignorance of the operation of part G is thoroughly impressive. part G is the currant controller, slitter and storage of the power in the form of a magnetic field for later use. the OU is basically in the operation in the primaries and the secondary not having to rotate a huge metal mass having the cogging effect every time it passes the primary. in my studies of Maxwell and the like they or he has proven that OU is possible, getting more out then putting in but such closed minded individuals are not capable of seeing this as people like J P Morgan wiped the very existence off the face of every book in the world through bribe monies .
Moving the massless, weightless field in the Figuera device is extremely easier then rotating a huge mass of iron that needs massive amount of power to rotate to get past the attraction of the rotor and stator. since the figuera device needs merely a flick of the wieghtless, massless field to move the field from side to side the output is beyond what any generator today can approach in it's most efficient form.
studying the north and south fields of a magnet or electromagnet one will realize that both sides rotate in the same direction and this duel rotation in the same direction is why OU is possible in the first place. two sides of rotation in the same direction, one spiraling in, the other spiraling out but both in the same direction but this is just my opinion in general.
Matu;
You are very correct in your assessment of the Figuera device.
Quote;
"maybe you. Can make me understand"
That will be entirely impossible, because he doesn't understand the basic operation of the Figuera device let alone the individual functions of each part.
Do not let mouth runners detour you in your quest for the truth. all some on this thread do is to seek to discredit people in a sad attempt to gain some kind of credit to themselves which in reality amounts to basically zero.
Seaad;
MM
Me: I can't see the possibilities to Over-Unity with a "part-G" consisting ofresistors and how resistors can storage magnetic fields?
"Your ignorance of the operation of part G is thoroughly impressive." Ignorant yes I admit that. I stand by waiting for your build or a better explanation.
Pls. Can you explain that word slitter in it's context.
Regards / Arne
Seaad;
using an inductor in the figuera case as a magnetic resistor allows it to be stored in a magnetic field for later use. a regular resistor can not EVER do this and will waste power as heat non recoverable. not good.
by having a movable positive brush traveling on wire contacts wrapped around a iron core will cause two opposing magnetic fields allowing you to have two separate feeds one going up in currant while the other is going down in currant on a dynamic basis....ie continuously.
and yes i will be there soon enough and you will know.
Good, we need a break from your mouth.
It seams your complete ignorance and lack of research into the Figuera device is your best asset along with that smart mouth of yours puts you right up to the top of the DUH ! list.
I guess it is to much for your rather limited intellect to actually do research into part G and the only function it is capable to conduct is the flapping of your lips and the rest just falls flat on the ground. i suppose you have trouble chewing bubble gum and walking at the same time.
To bad for you.
in the long run by you not doing actual research your only hurting your self.
Sorry but simulation is not research it is pretty much a waste of time but then again you never really added a thing to advance the device build.
... simulation is not research it is pretty much a waste of time ...
Hi MM,
I think almost everybody disagrees with you about simulation. Certainly Mr. seaad's results correspond to the testing we've seen much better than anything you've had to say. Having your followers follow your lead on using few turns of flat wire is just one example.
Doug's part G has substantially more winding's on it then when i first thought and after reviewing my notes i have concluded that this is the problem with the tests the builders have posted so far. i have had an influence on that mistake and for that i am truly sorry ...
