  • Hi Guys
    I finished winding the small motor. So, it worked, I have 2 phase output, lots of spikes, but something to work with.
    https://www.youtube.com/watch?v=M-l6WRq01jA
    I am going to try the rotating field, next, to see if it will do the trick. Spin something, then mount it. The toroid is bifilar, so I can close some coils, tesla did a lot of that, adding in series, creating harmonics, imho. Looks like the priest also was adding coils in series, etc.
    If anyone wants help building one of these motors just let me know, its pretty simple.
    Machine
    • Originally posted by machinealive View Post
      Hi Guys
      Machine
      machinealive , just watched your vid ..... cool Job
      now we know what the priest was trying to do ( in a crude way for now ) by cutting the lines of Force
      Signs and symbols -Confucius.
      • PDF on my thoughts of static generator
        Hi
        Here's a link to a pdf by myself that may give some inspiration or not!
        Here's a video of one test setup:
        Static Generator V1 Test - YouTube
        John
        • Pdf
          Hi John, I was reading your PDF ,very interesting, you mention the magnetic fields not sharing the same axis.
          I never thought of this before.
          Off setting magnetic fields, of equal strength, with an added field....just a thought.
          artv
          • Y'all might be ALOT smarter than me, I've heard alot of good stuff around here, but as usual, you hear some bullie types, you hear some jokes, and you hear some truth. It works better if there is alot of truth, some jokes and NO bullies. IMHO. WE need to help everyone.
            PS Please remember that not all of us have a Doctorits Degree or what ever the GOV says is required to do or understand this stuff, we like to do it for fun and to help others, EXCEPT FOR THE ONES THAT ARE ONLY!!!! AFTHER PROFET
            !!! ANY AND ALL POLICTICALS!! to help themselves.
            True or not?
            Best wishes to the smartest, they might help the rest!!!
            • Originally posted by shylo View Post
              artv
              Hi Shylo
              Thanks. As I said (could be wrong) having fields interacting but not joining may be the way forward. That way a secondary varying field which pushes/pulls the main field, will have its energy returned back to source (origin).
              The material for the induction plate needs to be very soft otherwise areas end up permanently polarized in one direction where the fields interact and are very difficult to unlock.
              John
              • Originally posted by john_g View Post
                Hi Shylo
                John
                Bingo One field is man made and one is omnipresent...
                • Well I don't have a clue what "omnipresent" means?
                  One field of a given strength interacting with a field, of either stronger ,or weaker strength , will cause flow, (migration of electrons)?
                  I think we have to stop looking at it as a path.
                  More a point of unbalance.
                  Just thinking out loud.
                  artv
                  • Correct!
                    artv
                    Art, I agree. The point of imbalance is key. And now we need a, always present, field to unbalance. A strong one that is everywhere. Hmmm, something like the magnetic field of the earth.
                    Randy
                    _
                    • Originally posted by tachyoncatcher View Post
                      Randy
                      For me question is : what does make Earth rotation ? It has to be HUGE power.
                      • Hi all,
                        There is a spanish patent about a overunity generator filed in 1955 by David Hogan and carlos Ludovik Jakovlewich (patent ES225316) which is curiously very very similar to the Figuera patent No. 303376 , the one with the rotary drum coil. In this patent the coil is stationary and the magnets are mounted over some rotating discs.
                        I have translated the claims of this patent:
                        CLAIMS SPANISH PATENT ES225316
                        The authors claim in this patent:
                        1) New electric generator characterized by the existence of series of discs, variable in number and in dimension, susceptible to host "magnets".
                        2) New electric generator according to claim 1 characterized in that the series of discs are mounted on a shaft in parallel arrangement ; the shaft rests on its sides over bearings. This arrangement of supporting bearings allow its intermediate extension if required.
                        3 ) New electric generator according to claims 1 and 2,wherein the " magnets " located in the discs must be placed parallely on the shaft. These discs, spaced, will allow that the poles of the magnets ( magnetos) of each disk are facing " north-south " (opposition of poles).
                        4) New electric generator according to claims 1 to 3, characterized in that between the discs (series of two) a stationary or fixed screen or sieve (grids) of copper wire or any electroconductive material glazed and covered with insulation is placed.
                        In the description it is clearly stated that the authors are describing an overunity generator where a part of the energy produced could be used to power the machine and the rest could be used externally for other uses.
                        Any comments?
                        Patent in pdf
                        • Cancelling out
                          Hi Hanon, In the lower right drawing ,with the coil inserted..the coil is being hit by 2 opposite fields?
                          When can you draw the load off of that coil?
                          If the coil was off-set , with the magnetic alignment, and the magnets off-set, could the collapse of the leading edge of induction, assist ?
                          Due to the fact it creates an opposite reaction.
                          Feed the collapse to the propagation of the field?
                          This stuff needs to be considered.
                          artv
                            artv
                            Amazing Resonance Experiment! - YouTubeCapacitive Battery Charger - John Saves Energy
                            • Shylo,
                              I read the Hogan & Jakovlewich patent and it is curious that there are not details about the wires location. I also noted your point about the cancellation. It is clear that the patent drawing is wrong.
                              Maybe the authors were trying to hide the real configuration of the wires. The key feature of Hogan & Jakovlewich patent is the location of the wires (how to locate them and avoid the lenz effect) and it is not told in the patent text. IMO the wires must cross diametrically between two discs (NS) and then the return path is between other two discs with the contrary poles placement (SN). This is not drawn but this configuration is covered inside the claims.
                              ...________
                              N | S.......S | N
                              N | S.......S | N
                              N | S.......S | N
                              My point for uploading this patent is to see the similarities with Figuera patent No. 30376 , the ond with a rotary drum. Maybe we could extrapolate some enlightening idea which could be behind both patents.
                              • Sorry, but I do not see any conflict...
                                artv
                                Hello Shylo, Hello Hanon, hello to all,
                                I am sorry, but I had to post this...
                                I really do not see any conflicts in either the windings or the Magnetic Fields on this Patent...
                                This is the way I "read" or Interpret this Graphics into 3D:
                                If You guys look at the FIG II I have chosen from drawings...please note all the lines at coil, depicting the outer exposed wires...
                                I see it as another Diametrical Winding of this coil...maybe I am seeing this form of winding even in my Soup...
                                I believe the Magnets Convention they have used...is the type I was discussing on my other Thread related to My Dual Rotor Asymm Motors...where I am eventually "forced" to show BOTH POLES of each Magnet in order to be understood inner-outer interacts...and Not only the side that is Interacting with the Coils...See below:
                                So, for a better understanding of this Patent...We should "IGNORE" Outer or Exterior Poles in each Disc...concentrating in just inner ones facing coil...so, Half Circumference N->S sandwiched between coil would be creating an "A" Magnetic Field...while the other Two "Semi-Circumference
