  • Originally posted by john_g View Post
    Hi Hanon
    This link goes to a 1948 paper about mag-amps, doesn't cover phase shift but has a lot of references at the end that may be useful. At the time of it being written the limiting factor was the availability of advanced core materials.
    http://www.keepandshare.com/doc/6446...f-1-9-meg?da=y
    Hi John,
    Two problems:
    If I click on your link, it says I need to log in with free trial or paying choices
    If I choose the free trial, then it says you did not set your Sharing controls to give me rights to view the document.
    Gyula
      Hi John,
      Two problems:
      Gyula
      Hi Gyula
      OK I'll see if I can host it somewhere else, I have some other related docs..
      John
      • Tesla or Clemente Figuera ; Any kids can short circuit a Condenser with Screwdriver
        12volts battery- step up/inverted or Decay Tank Circuit(AC)- fwbr to charge- Condenser- Disruptive Discharge{PWM or Decade Counter} to Coil/Inductor(The rapid resonant impulse oscillation of condenser as Tesla stated on his patent) with-Induced Coils or Secondary coils e.g. Feedback Coil to-fwbr + cap to recharge 12volt bat, Generating Coils to charge Condenser To power LOAD of COils = Bulbs, Relays, Motors.
        The schematic you posted above is just a part of the whole system, The stages or Cycles of that event should not overlapped to each other. The key here is the COIL SHORTING TECHNIQUE of Tesla :Charge Condenser(as source) short out with Disrupter=spark gap, Make and break, PWM or any means of shorting the coil and cap, then Recharge Cap and repeat.
          Hi Gyula
          John
          Hi Gyula
          Sorry about that, rehosted:
          Home
            Hi Gyula
            Home
            Hi John,
            No problem of course, and thanks for the files. The thesis by Steffen is the paper I have not come across yet, looks useful, albeit the configurations shown in some of the Figures appeared in other, later published papers.
            You may have seen this collection on magnetic amps etc, shown by one of the members here: Directory contents of /pdf/Reference_Material/Magnetic_Amplifiers/
            and here: Directory contents of /pdf/Reference_Material/Mandelstam_Papalexi/
            And some more collection of useful papers: Directory contents of /pdf/Reference_Material/
            Thanks, Gyula
            • Originally posted by stupify12 View Post
              "The Problem of Increasing Human Energy"(link).
              Regards!!
              • I agree hanon1492
                • The simple secret of Tesla and Figuera
                  This people are talking about Overunity or Extra/Excess energy from input. Tesla always mentioned it in a simple and very understandable illustration and yet people are blind. I think you people understand very well the experiments done by Ufo politics in the Thread my motors got me Tap in radiant energy is one of the Example of the so called COIL SHORTING or Closing the Circuit.
                  The simple secret of all the Overunity system all fall the same simple principle. THE COIL SHORTING TECHNIQUE OF TESLA! Ufo did in Static Coil/Inductor + PWM and Mosfet to Short Circuit/Close the Circuit. Ismael Aviso did it also in the Black Box with Cap + 10x FET + Transformer- Primary and Secondary. Tesla did it on Charging Condenser + Disrupter/ Make and Break Switch + the Coil/Inductor. Tesla stated clearly that the Natural characteristics of CONDENSER has a Rapid Impulse Oscillation that made Tesla's System Produce High Frequency even its from 12Volts DC.Just find a way to convert 12volts dc to Ac so you can charge the cap efficiently.
                  2nd. Simple Secret is High Frequency- How can we get high frequency out of a 12volts DC? Kunel, Richard Willis, Ufo Politics, Tesla, and alot of people out there talking of Overunity System but all fall to the same very simple concept producing High Frequency to gain much more output.
                  I know Ufo politics understand it very well If you people BELIEVE that electricity is FLUID LIKE Particle, like WATER you will understand it much better.
                  • Ufo will disclose the schematic soon!
                    @ Boguslaw, i know you already know what im talking about at the above post, i know you understand it very well, maybe you have a device running like what I was talking about in my post.
                    The next thing that Ufo will show you is the device that I was posting here, is a motor that will combine all the ideas that I post above. Its a Motor while running can Generate output same with the very known concept of Mr. Clemente Figuera. And this motor is running from the very well known Concept of TESLA's COIL SHORTING/CLOSING THE CIRCUIT= it should be open first so we could CLosed it., Also the new on this re discovery is The Hot input to the Inducing COil of Motor and Generator can be Recovered and Stored, Which can be used as a power source or to Recharge the Battery.
                    This is the simple hint that well be very sure to be present in the Latest Electrodynamics that Ufo will be disclosing soon, A powerful Motor, A Generating Coil Induced by the Circuitry Driving the Motor, A self running device with a Capacitor Storage/Buffer. A switching Controller of Stages- 1st. Coil Shorting- Motor Dynamics, 2nd. Captured Excess Energry from Coil SHorting to be stored in Capacitors, 3rd. Powering the load- It should be Coil made device e.g. Relay, Bulb, Motors-self runner, 4th. Recharging the Supply Battery by the Stored energy in the Caps.
                    Its the Water(Electricity) Pressure=Voltage that fills the VOlume=Amperage of the COntainer.
                    I agree hanon1492
                    • Tesla analogy
                      From "The Problem of Increasing Human Energy" (Tesla, 1900) :
                      "Whatever electricity may be, it is a fact that it behaves like an incompressible fluid, and the earth may be looked upon as an immense reservoir of electricity, which, I thought, could be disturbed effectively by a properly designed electrical machine"
                      "Could we produce artificially such a "sink" for the energy of the ambient medium to flow in? .....To create such a "sink," or "cold hole," as we might say, in the medium, would be equivalent to producing in the lake a space either empty or filled with something much lighter than water ... ...it is energy which may be converted into other forms of energy as it passes from a high to a low level. To make our mechanical analogy complete and true, we must, therefore, assume that the water, in its passage into the tank, is converted into something else, which may be taken out of it without using any, or by using very little, power. For example, if heat be represented in this analogue by the water of the lake, the oxygen and hydrogen composing the water may illustrate other forms of energy ... ... We would thus produce, by expending initially a certain amount of work to create a sink for the heat or, respectively, the water to flow in, a condition enabling us to get any amount of energy without further effort. This would be an ideal way of obtaining motive power. ... Thus the virtue of the principle I have discovered resides wholly in the conversion of the energy on the downward flow"
                      Anyway I keep on thinking that Figuera did not need neither condensers nor resonance to get his device running. Maybe we are trying to mix to different concepts of overunity machines. I think he was just trying to minimize the Lenz effect in the exciter electromagnets.
                      I hope, anyway, that you were right and soon a great device will be disclosed !!! Any info? or just a guess ?
                      • Electromagnetism
                        Have you ever consider what makes a Magnetic Compasss points the same Magnetic Field the North and South ?
                        What if you could disturbed that Magnetic Field of the Earth by our little input of Electromagnetism Electrical Machine in a rapid impulse of oscilllation meaning high frequency input of ON and OFF oscillation..?
                        Does the little Electromagnetism we input can disturbed the Magnetic Field of the Universe? Or the little Magnetic Compass needed to be Large enough to detect this Magnetic Field flux or disturbance to the Magnetic compass Magnetism?
                        The todays Electronics or Science talks about the Resonance which is not exactly not Tesla was referring to or not really related to Tesla's Harmonic Vibration. The Tesla resonance was not done by LC combination, He was referring to the Primary coil and Secondary Coils Magnetic Vibration( Imagine you can create a Bigger Magnet like the size of the Moon, then controlling it ON and OFF). The Resonance Tesla was talking about is Universal Magnetic Disturbance, He is Resonating the Every Atom(Magnetism) on the path of his Electromagnetism Electrical Machine the Famous Tesla Coil. Tesla is resonating the Earth not hes device, Because Tesla known it very well that the electrons do not need to travel from point A to miles away point B just to ring that Point B. The electrons(atoms) just vibrate on the so called Harmonic Vibration, Im telling you that Atoms are nano size magnets, disturbed 1 and you can disturbed all the Universe.
                        If we Input 12v= The Counter Electro Magnetic Force of the Universe is like 300v to 1kv. How much more if Tesla Input 50kvolts on the Coil? The Condenser on Tesla coil is just A Fast acting Source of Electricity to Produce High Frequency. The Clemente Figuera Device is Working the same with the known Principle of TESLA TOROID TRANSFORMER. 4 Coils, 2 sets of coils, 1st set North and South, the 2nd set is North and South, Tesla design and arranged it ingeniusly to make the NORTH + NORTH= 2x powerful Electromagnets, Also SOUTH + SOUTH=2x virtually by Winding it Asymmetrically and Diametrically Opposite so he could Produce High Frequency Within the COILS virtually Magnetic Interaction.
                        • Comment
                          • LC resonance
                            According to this paper (by Utkin) you can have a kind of capacitor C just because the external coils act as a spread capacitor C of inductance L
                            Link
                            • Link
                              In fact they both have different wiring disposition but it can be one other implementation of the motionless generator described into patent No. 30378
                              PS. Also a curious video I have seen: TPU Secret - Steven Mark
                              • https://figueragenerator.wordpress.com/
