Bi-Directional MOSFET configuration can be found in SSR (Solid State Relay) google it up to see a schematic. There is a way to make one on your own.
Basically it is a fast AC switch. It is made out of two mosfets connected in series: Source-to-Source. This way they can switch AC. A mosfet from a positive side conducts, the mirrored one doesn't but it's intrinsic diode conducts backwards so the signal goes through both of them in both ways when you apply a potential to their gates. I use extra, fast quality diodes in parallel with each transistor as those inside the mosfet's body are inferior in performance.
But it requires separate 'floating powersupply' for every switch so it might be to complex to build all of those on your own.
Recently I came up with a different approach to achieve alternating magnetic flux in the center output coil, using resonances on primaries without capacitor switching.
The idea is to add one more primary and drive 3 LC tanks 120 degrees out of phase !
Anybody thinking FLUX CAPACITOR?
