Lenz Force and Repusion Fields...
Hello to All,
Been busy for a while, and just a few minutes to post about Lenz and its relation to Repulse Forces...
First, in a Repulsion Field we have -at least- Two B-Fields facing each others, and while many have written that they cancel...I do not think so...B-Fields, considered Vectors of Directional Force are there at all time during repulsion interactions, causing the compression we all feel...don't you think if they would cancel...we'll still be able to feel this magnificent forces fighting each others?
The ones that we could say that "apparently" Cancel...are the N-S Vectors in Attraction, actually not cancelling but giving birth to a new Field of different and greater geometrical configuration as the two originators...
In the Figuera case, we have that same High Compression Repulsion Field exactly at the center of the secondary core, and as we displace N1-N2 in unison (if we do not keep them in unison, the centered field will loose compression, and induction will drop) the compressed field would move through secondary core and coils back and forth generating an induction.
Lenz, in this kind of induction would have to "split" in two vectors, To a "Dual Travel"... depending on the compression field displacement, therefore Lenz would tend to cancel to zero in every back-forth displacement (which represents a full cycle here) of the Virtual Repulse Compressed Field movement.
This Thread would just be opening "the gates" for the new approaching horizons and future possibilities we never had before, or never thought would be ever possible at all... related to the old concepts like: "Induced EMF", "Lenz Forces", Cutting "Imaginary Lines of Force"...etc,etc
If you want to do another experiment...just take off that iron core from the secondary...then start moving the compressed field at primaries coils-cores...and would observe almost no induction at all compared when iron was present...now what does this tells you?
Does it tells you the Imaginary Lines of Force were still "Cutting" the conductors now?...and they supposedly were doing so...but why no induction now?
This simple experiment tells you very clear, that induction starts at Iron Core first, then it transfers to copper coils...simple.
Regards to all
Hello to All,
Regards to all
