Mikhail Dmitriyev - Input 1000 W, Output near 3000 W.
  • Comment
    • Here's where the number 8 arm would appear to first fall. You may need to make a clearance at the end of the arm nearest the center to clear arm 7. Also if arm 8 slides down, it may not turn at all if it hits the red retaining pin. The other issue might be that at this point in the rotation, most of the mass is on the left and may slow or stop the rotation?
      https://www.dropbox.com/s/bsewdp7wydgyzno/paul.JPG?dl=0
      • Comment
        • Last edited by soundiceuk; 02-13-2018, 11:47 PM.
          • i'm starting to learn spaceclaim, the good part is that it has a physics simulator and seems quite easy to use overall.
            I'll be able to transform some of these ideas into computer simulations.
            The bad part is that i think i'll be in hospital for several days, i might go through a surgical procedure, minor. Hopefully everything will go well and i'll recover fast but still have other health issues.
            • Here is a picture to convey the new design feature which replaces the fulcrums with a new arm slot that works as a fulcrum, guide and pivot.
              Working on the basis of 10mm slot.
              There may be a better way to do this but for now this is what I've come up with.
              • Originally posted by TheVisitorV View Post
                Luck forward to seeing any simulations.
                A great tool for tuning I'm sure!
                Good luck with your ongoing health issues
                • Comment
                  • Modified arm and pivot design to allow arm to be fulcrum.
                    • Hahaha, I've drawn it backwards..... I will correct
                      • The corrected drawing.
                        • Thanks to your input, here are some images of the new design.
                          • Straight up noon
                            Originally posted by soundiceuk View Post
                            Hi,
                            What causes the swinging arm to become vertical at 12:00?
                            • The center of gravity is moved far away from the center of the axle.
                              The wheel acts like constantly tipping, balance scales
                              The previous arms hit each other and lever the arm until gravity takes over and the arm falls down the slot and onto the square peg.
                              The mass of the wheel stores enough energy from the decending pendulum/levers to ensure the wheel turns fast enough to bring the next pendulum into play.
                              There is constantly more weight on one side of the wheel. It seeks equilibrium but never finds it.
                              • Hopefully this explains it better!
