Originally posted by RAMSET
Mikhail Dmitriyev - Input 1000 W, Output near 3000 W.
Just a thought.Originally posted by Regster View PostI've also changed my mind about open source. It would be nice, but if this is replicated it would be nicer to get a worldwide crowdfunding thing going for say a nice pot of cash for Mikhail in exchange for him transferring the patent rights to a foundation set up purely to sit on patents.
When this technology is proven we could count heads and decide what amount we could all afford to put into a pot each month.
Then vote on how the funds were to be used.
Anyone wishing to join the group would have to put in the same amount any individual had already put into the pot.
If there is a large amount of people the monthly figure will be small. As more people join the figure could decrease.
Any profits made could go back into the pot so it isn't profit.
Infact a trust may be the best way.
No one owns anything then.
Couple of questions about the motor/generator in the middle....
Considering that it is the most expensive single piece of the build, re future proofing for potential improvements in performance would buying one capable of generating a net 15kW run at these lower loads?
Are these off the shelf units... if so could someone link to one/two?
Electric Motor, Three Phase, 15Kw, 20HP,1400 rpm.(3Ph) | eBay
3 Phase Electric Motor 25HP (18.5kw), 1400rpm, 180M | eBay
Q. Hi, can the motor also be used as a generator?
I'm guessing it is an induction motor and therefore it can.
A. Paul, yes induction motor so can be adapted, i cant offer any advice as I dont have experience of doing it.
I'm trying to consider whether using a single phase motor for the input and a permanent magnet generator as the output would be far more efficient.
These are just my thoughts.
Negatives:
The frame would have to accomodate both.
More gearing.
Increased cost.
Positives:
Removes the three phase output problem.
Frequency inverter would not be needed.
Self looping would be simpler.Last edited by soundiceuk; 10-25-2012, 05:56 PM.
I think I'm now leaning toward separate input and output devices based on his last video and the positives and negatives you mention. Although I don't personally see the negatives as all that bad. Regarding the gearing, if it turns out that the 'kick' wheel isn't really necessary, then that alone will reduce the overall gearing or at least offset any additional required for two separate devices.
Any news on proto 12?
No news yetOriginally posted by purelyprimitives View PostI think I'm now leaning toward separate input and output devices based on his last video and the positives and negatives you mention. Although I don't personally see the negatives as all that bad. Regarding the gearing, if it turns out that the 'kick' wheel isn't really necessary, then that alone will reduce the overall gearing or at least offset any additional required for two separate devices.
It looks like the 7 o'clock free wheel is going to work from what I have seen so far.
Woah!!! I bet that is pricey!Originally posted by woopy View Post
I will have to email them unless you have done so already.
Maybe there are other types like this on the market.
I believe you have sent me your email address.Originally posted by purelyprimitives View PostThat's great news! Are you at liberty to share anything of what you've seen?
I know you have been following closely from your youtube comments and your posts from this thread.
I will ask permission.Last edited by soundiceuk; 10-26-2012, 01:02 PM.
Here is the PR6000 Frequency Inverter Manual:
I have added this to the comments section on youtube video:
addition6.The system is ready to closing the loop
addition6.The system is ready to closing the loop - YouTube
Fault Code: Er07
Fault name: Under voltage at operating
Possible cause: Abnormal input voltage
Solution: Examine supply voltage
& this to:
addition5.Full active load
addition5.Full active load - YouTube
Fault Code: Er02
Fault name: Over current at constant speed operation
Possible cause: Too small inverter power
Solution: Choose the inverter of large power
