Can You Project Magnetic Fields ?
  • Can You Project Magnetic Fields ?
    I know you can project electricity wirelessly, but I've never heard of anyone projecting magnetic fields wirelessly
    Can it be achieved similar to wireless electricity? Ie instead of projecting electricity, you project an electromagnetic field?
    Ive been trying to research this, but cant find any info on, any links help appreciated
    In a manner of speaking you could but you still need electricity just like wireless. A pulsed DC spark gap can put out a powerful magnetic field. The problem is that the field would disrupt electromagnetic fields of radio waves and the like. An electromagnetic pulse or Emp can shut down electronics. Devices that disrupt phones or other electrical devices are not permitted and are easy to track down.
    A pure magnets field only extend outs so far. Any magnetic materiel's like steel will become permanently magnetized if located within the field unless the poles are constantly reversed..
      Of Course You can...
      Hello,
      Interesting Topic...but "dangerous side"...A Red Zone...
      The known method to achieve projection of MF into space is through Pulses...
      It is called an EMP (Electro Magnetic Pulse)...some call it "Death Ray"...
      Inventor: Nikola Tesla
      Tesla conceived this Invention to provide poor Countries with a "Barrier" to protect them from Foreign Attacks...as He naively thought that by creating it and publishing worldwide...it will reduce Violence and War...
      Patent: Seized by FBI in 1943 (Tesla's Death)
      Search: Venus ECCM
      Search Arie DeGeus Mysterious Death at Airport...Inventor of a "Self Recharging Battery"...gone
      In this compact form (Venus Shooter) it is like a Defibrillator by "Remote Control"...meaning, no electrodes need to make physical contact.
      Generator of-at least, but not limited to- Two waves of electromagnetic pulses that repels each others and are pulsed at same identical rates/peak at a certain vectoring angle will keep traveling in the derivative result of both vectors, or [>---] resulting in a Linear Shaped Pattern invisible beam. The pulse and vectors directions could be PWM/oriented for target distance reach, as intensity and other parameters to enter into the scope of Human Heart Pulse...inducing a "Heart Attack"
      It is a weapon, and as Iotayodi mentioned it could also cause severe harm in electronics, as all related equipment that uses magnetic fields to operate...like a Power Plant Generator...
      It is a "Taboo" field of search, find how many sites has been shot down because of offering a "Download of the Venus ECCM"...or Forums of related issue.
      I recommend an excellent book by John Case, based on this "Apparatus"...very well written: Ghost Dancer
      Kind Regards
        Thnx for the replies guys
        So basically Id need to research an EMP pulse, to avoid disrupting electronics, itd have to be highly directed
        So it begs the question, how efficient is it at generating a magnetic field, & how strong can the field be?
        ie voltage, wattage & gauss generated?
        Also to avoid disrupting electronics, can you change the resonance frequency, preventing it from disrupting communications?
        Also one last question, does transmitting wireless electricity produce magnetism?, ie as in a copper wire also generates a strong magnetic field, if electricity runs through it
        If so is it also possible to create a wireless coil, by increasing the sine wave resonance frequency of a current
        ie creating a wireless electromagnetic coil in mid air, using wireless electricity
          I never thought of it that way before.
          Great insight.
          Steve
          One thing to keep in mind is, man wrote the laws regarding the conservation of energy, not nature.
          Nature writes it's own laws regardless of what man thinks or does.
            Wireless TV
            I thought I had already read about this somewhere. There is already technology in prototype form for the retail industry for this. WiTricity Corp. Home — Wireless Electricity Delivered Over Distance Some TVs have been shown with this technology. Power broadcast. Tesla based, we are closer than ever to it. Popular Science published an article highlighting the technology in 2010. Here is the Google search: Google
            Randy
            _
              Hello roonyroo,
              So it begs the question, how efficient is it at generating a magnetic field, & how strong can the field be? ie voltage, wattage & gauss generated?
              The advantage is to use our magnetic field as a "bait" at low expense(low pulses, low V,A then W)...to capture and utilize the Radiant Field to be the one to vector, manipulate and propagate...it does better in air-space than our Hot field...then all parameters cited above by you minimize to very small levels...
              Besides the fact Radiant field is higher frequency field...as more intense...
              Yes Radiant Field propagates-induces better in an Air Core Coil...very "light weight"..besides you are not allowing Hot Field to thrive...
              Radiant Field will not conflict with Hot flow...(actually it "lives" inside Hot) as long as it is offered to have its own paths...and not trying to enclose it like a Flywheel Diode do to an Inductor or Coil (example: a Motor)
              That is the point.
                Conventional view thoughts to consider
                Hi Roonyroo,
                You have an interesting question and I am sure you will have started a lively thread because it has a peculiar appeal. I offer these thoughts for your consideration.
                In conventional thought about magnetism you always have some kind of organized movement of electrons. The electrons may be flowing through a wire of some kind or they may be traveling through empty space or they may be vibrating back and forth from point to point or they may be rotating in a circle or spiral. Each of these motions and others you may can think of have their own unique characteristics.
                For example, a concentrated beam of electrons could burn a hole through just about anything and would be very dangerous, but you would also have a magnetic field associated with the moving electrons.
                Because there are so many possible ways to send and move electrons you end up with an endless number of possible magnetic field configurations.
                Every electron is surrounded by an electrostatic field that extends to infinity. But it's effective strength is only important for a small distance. As soon as you somehow cause one or more electrons to move you have a local magnet and a magnetic field. The magnetic field extends to infinity but, again, it's effective strength is only important for a small distance.
                So, can you project a magnetic field? Yes, of course. Just move some electrons and you automatically project a magnetic field. If you transmit radio waves or radiant energy, you are projecting the magnetic field along with the electric field. The receiving antenna, if you are using one, receives BOTH electric and magnetic energy. It happens all at the same time.
                As the electrons move in the antenna wire, there is an associated magnetic field. The two cannot be separated.
                Now, if you can somehow demonstrate some kind of exception to what I have just said, CONGRATULATIONS. You now will have instant celebrity in this forum and everyone will want to reproduce whatever you come up with.
                So, here is a simple design for projecting a magnetic field. Or, as I would say it, producing a magnet at a distant location by doing something here. First, build a highly directional transmitting antenna and a highly directional receiving antenna. They would very likely be similar in design. Line them up carefully like microwave antennas. Select the right circuit design, resonant frequency and what have you. Wire the receiver to an appropriate coil through an appropriate circuit. Power everything up and there you have it.
                Good luck.
                One more thought for you. A permanent magnet has atoms with electrons moving in tight circles around their nuclei. It just happens that in a permanent magnet the circles are all lined up in the same direction and "stay" lined up.
                  Hello roonyroo,
                  That is the point.
                  Your comments are extremely interesting to me since they are couched in the arcane terminology of the occult. I would like to understand what you mean by Hot flow. Also, how or in what way does a Flywheel Diode enclose Hot flow? Thanks.
                    Hello Wayne
                    Hello Wayne,
                    Thanks!...I like your "terminology"...
                    I was not referring that a flywheel enclose Hot flow...but Radiant Flow...
                    Wayne, we create a "Hot Flow" by our artificial means to move electrons through conductors, and some cases creating a strong magnetic field when that flow passes through a Coil...or an Inductor, that is our Hot flow...our artificially generated magnetic field...but there is "another one"...a Natural Magnetic Field"...that has always being there, in many different patterns...some fractal, randomly traveling...before we even created electricity...and that is the Radiant Field.
                    Did you ever read My First Thread here?
                    If you could go slightly over the first pages...then you will understand what I am referring to...
                      Magnetic field is already "projected" anywhere you need it. To collect it you need a special receiving device called "permanent magnet".
                      Try to understand that magnetic field does NOT belong to a magnet.
                      ABC
                        Looks like Ill have to create a seperate thread for creating electric coils out of thin air, using emp bursts or radio waves, or resonant frequencies ...
                        Anyway Some excellent replies to this thread ...
                        From what Ive read so far, an EMP burst is the best way to generate an magnetic field in mid air?
                        As it creates a highly strong visible magnetic field comparable to a rare earth magnet ?
                        @UfoPolitiks
                        Thanks for the excellent reply,
                        how would I put your statement into practical use, I understand your use of hot flow & natural flow, as im familiar with Walter Russel, Leedskallin, etc
                        From what I understand, youre basically stating use the voltage & ampage to create high enough watts to tap into radiant fields or Zero Point energy & then use that energy to create an electromagnetic field?
                        @WayneCT
                        Again thanks for the excellent reply
                        Using radio waves & Antennae to create magnetism, would it be comparable to the strength of an emp burst?
                        From what I understand an emp burst is created by the back emf of somesort of highly discharged capacitator, which implies some sort of tapping into Radiant or ZPE
                        Rapid discharge of current, produces much higher electro & magnetic effects then a basic wave travelling in the electro-magnetic spectrum
                        Which tesla utilises in practically everything he invented ... ie AC current is more efficient then DC precisely because it generates massive amounts of back emf, as it resonates rapidly, while dc doesnt resonate it simply travels
                        Obviously DC resonates, but not enough to overcome the resistance in a wire across long distances, it simply melds into the resonant frequency of the wave generated by the wire ... as wire is a standing wave ...
                        @WayneCT
                        From your comment it seems radiowaves & antennae would produce beams which burn, if I tried to create high amounts of electromagnetic fields using your method?
                        In that case wouldnt an EMP burst be better, as it doesnt create destructive beams, just high amounts of resonant fields?
                        My main aim is to create a new form of electronics, where we use wireless electricity as circuit boards instead of solid state silicon circuit boards
                        This has the potential to be faster then even nano technology like graphene & could easily allow us to create quantum effects at room temperature, ie teleportation, warping time & space etc.
                        Basically creating circuits & coils in mid air by resonating the sine wave frequency of the electromagnetic fields
                        This just the beginning once we know how to create circuits & coils out of thin air, we can start plugging in ALL the elements of our environment into our circuits & coils
                        ie using hydrogen as a circuit directly instead of seperating it in water
                        Which is what I suspect Hutchison is doing ... as he uses the base resonance frequencies of various elements like hydrogen to turn petroleum into carbon, & the resonance frequency of atoms or fields responsible for gravity
                        As all matter is a standing wave, generating coils & circuitry out of thin air would allow us to create highly nutrititous plants & food & eradicate pollutants, & use our environment & time & space itself as a super computer
                        My main question before I start my feasibility study, how many watts & voltage would I need to create a 1000 guass field, which is comparable to a $1.00 magnet?
                        Basically how watts & volts would an emp burst need to create a 1000 guass field?
                        Im not too keen on using radiowaves & antennae, but if theyre more efficient then ill use those ...
                        Basically does anyone have any figures on how many watts & volts would radio waves & antennae need to create a 1000 guass magnetic field,
                        I need the same data for a emp burst ...
                        thnx
                          Hello
                          @UfoPolitiks
                          thnx
                          Hello Roonyroo,
                          I like my name with a "K"...Ufopolitiks...is that in German?...
                          My Statement in Practical Use?
                          You have to read My other Thread here In order you get a better idea. is too long of an explanation to add it all here...
                          From what I understand, your e basically stating use the voltage & amperage to create high enough watts to tap into radiant fields or Zero Point energy & then use that energy to create an electromagnetic field?
                          Nope, NOT to use "high enough" but "low enough" to tap Radiant Field...otherwise it will not be "economical"...
                          Figure your created, generated EM Field would be like an Inflated Balloon, let's "play it" in slow motion...
                          You pulse your EM Field out to space for the Time On at Square Wave...It interacts-aligns with its surrounding atomic level particles in the Vacuum, in the Ether...they align according to your displayed EM Field Polarity...just like any other magnet will...meaning, where you have the North...there would be a "Space of South Aligned particles surrounding ALL that Volume...
                          Then all the sudden you drop to Zero, Balloon deflates in zero time...leaving all those already aligned particles in the middle of where "used to be" your Balloon Volume... Your EM Field (and this I have proven) deflates exactly to the CENTER of Your Coil...so what happens now?
                          Well, ALL those aligned particles will enter your coil, following the "Suction-Vacuum" Magnetic Forces generated by the "Collapse"...Now SHE is IN...you Trapped Radiant Field inside your Coil...at that Time Off...SHE Enters reversed to Your originally generated EM Field...therefore where you had North...now you have South...and where you had Positive...now it is Negative...
                          Now, this is just "One Frame" of the 60 FPS in your "slow motion movie analysis"...The "Process"...depending on the Hertz your field was pulsed...it go for lesser time...to almost very close to zero...
                          You have to "provide" the right Paths for your captured Radiant Energy to flow through...without interfering (negatively feedbacking) with your generating Hot Field...or your EM Field...it could kill it instantly...at least your "switchers" (MOSFET's) ...and the way you do that "Traffic Flow Control" at your crossroads signaling protocols...is by simple Ultra-fast switching Rectifiers at each channel ...
                          • #14
                            Found some stats from a Bob Beck Pulser, as it allows you to create a magnetic pulse safely, for those interested
                            "According to Chris Gupta's calculations the array of 7 capacitors now store about 41 joules (Watt/Seconds) of energy and will produce a magnetic pulse of around ~6,000 gauss from the surface of the coil. "
                            So basically I need to transmit around 41j/s to generate around 6000 gauss
                            @UFOpolitiks
                            As this is the internet I presumed a k instead of a c ...
                            Thank for the description, do you think this is an efficient way of tapping into the resonance of objects electromagnetically & manipulating their electrical makeup remotely?
                            Also Bob Becks Pulser seems to remove the back emf & shields the magnetic pulser adequately, preventing the electronics from shorting out, im a beginner at all this so I could be wrong ... but it seems to generate a high gauss field safely ...
                            • #15
                              @UFOpolitiks
                              I have been interested in pulsers as of late so this information is helpful and good to know.
                              Steve
