tesla style earth battery
Welcome Gav to the Forum
for your motor .... may i suggest exploring http://www.energeticforum.com/renewa...-machines.html
as for the circuits ... the choice would go to a joule thief circuit ... others with more knowledge would probably orient you better
your antenna to be more efficient ... you should find the right ratio between the gauge of your wires / Length / Coil turns and finally weight of the wires ....imho
cheers and thank you for sharing your experiments
ps: out of curiosity and experimentation sake have you tried placing the coil in a water container
Signs and symbols -Confucius.
being new at this .... gives you an edge over veteran electricians ( no disrespect ) .... you won't have to unlearn long held habits we have been taught all these years ( except being always cautiousOriginally posted by Gav View Postthank you MonsieurM, a friend has a few broken generators that i can have, im not totally sure what i will do with them yet. im open to suggestions on the coil, my inexperianced thinking was that the more wire and turns the larger the back emf pulse would be? i havnt put it into water yet, would doing so act as a capacitor? as i said im new to all this but very interested in learning
) ... experiment away and go with your flow ....the larger the coil is correct but it is not the only parameter to consider
water seems to enhance receptivity of an Antenna ...
also if you have the time you could check out this website :
Rex Research: suppressed, dormant,emerging unconventional alternative technologies: Free energy, Over-Unity, Antigravity, Inventions, Alchemy, Transmutation, Cannabis Hemp Marijuana, Magnet motors, Alternative Therapies"
James H. Rogers: Underground & Underwater Radio AntennaLast edited by MonsieurM; 09-03-2012, 02:43 PM.Signs and symbols -Confucius.
Eric Dollard Peter Lindemann Tesla's Longitudinal Electricity - YouTubeOriginally posted by Gav View Posthas anyone else noticed teslas pancake coil on his wall? and or replicated it?
Keep searching. It could be anyone who makes the next step forward, but don't believe that the big electronic corporations aren't looking at and developing this type of technology. bqTESLA Wireless Power Evaluation kit from Texas Instruments - BQTESLA150LP - TI Tool FolderOriginally posted by Gav View Postall the electricians and the ones that are ment to know what they are talking about just say its impossible and im trying to break the laws of physics and in the end they just think im crazy haha i dont care, we get so ripped off here in Australia, most dont believe there are better ways
And these are the things they want us to know.
The coil(s) on the wall behind Tesla is (one of his) high frequency oscillator/transmitter. It's 2.4 metres diameter, not bifilar. The coil IS the "antenna", connected to the middle would be terminal capacitances such as metal spheres, plates, vertical wires etc, or another (extra) coil. In the image I posted, the outer two turns is the primary as it is shown in the patent and Eric Dollard's demonstration, the primary and secondary have equal copper weight. Like Eric's coil the turns are separated in their own grooves, with two turns per groove.Originally posted by Gav View Postthank you, this pic shows a good veiw that can be used for construction, i havnt seen it before. is there a solid ring on the outer as a secondary? and are the rods holding the wire in place charged? or just used as non conductive spacers?
now i really want to make 1, even if it just becomes a peice of artwork for the wall
also i can not watch the youtube vids till after midnight, i live in a gully on a river, we get internet by satalite, no mobie reception and few radio stations.
im sure the main thing that i have going for me is that i have alot of ground water here, and im receiving negative energy?? my ground reads positive on the meter? ive read somewhere that it can actually swap if the ground is stronger then the antenna? if its true, this is how energy can be made anywhere at any time, using the differences of nature
Patent US649621 - NIKOLA TESLA - Google Patents
What do you mean are the rods charged? They are used to keep the wire in place and also to raise the wire so it's not in direct contact with the flat wooden surface. The "short circuiting" you are referring to applies to the power supply side, look into Tesla's circuit controllers.
Any potential is measured relative to some other reference. Whichever is the highest of the two will be "positive".http://www.teslascientific.com/
You have it right Gav, you'll get the 10.5V and the amperage from each positive connection
When running from Earth connections, it's much cheaper to connect Negatives, in the form of say chainlink fencing steel. You can have multiple rods of perhaps 2ft of steel and 1 rod of copper.
Outside in our backyard, I have what my wife calls Stonehenge lol. About 24 steel rods in a circle, with 1 copper rod in the middle. Each steel rod connects to the copper rod as a supply for power. The steel connections all run seperately into the house over old internet wiring cables (8 wires in each) and the single copper one also. Each pairing of copper wire and steel electrode wire will run a blocking oscillator.
After a few months now, even throughout the Midwest drought, they still all run and all output just about the same as they did at the start, 0.8V and 350uA. I've not found a decent way to sum them, yet can have a bunch of LED's flashing away 24/7.
Here's a vid showing 4 oscillators running outside: 4 Osc running - YouTube
And half a dozen inside, when connected via the internet cables and to an old router as connections block: 6 osc and board - YouTubeLast edited by Slider2732; 10-01-2012, 10:22 PM.
