fedex generator
  • fedex generator
    Hii everyone new here and would like to share my experiments with you all...
    I have been working on a generator for the past month and a half an have had some really nice results.
    Ok so I have made a few different models and have had a 6v4ah battery powering my device and have had an output of upto 12v or more from 2 coils and 4 small neo magnets. So I decided to up scale it abit with more coils with thicker wire and more magnets but have seemed to lose the output is this from the wire gauge or what?
    in my latest model i have a 100mm 240v case fan as the base of the generator, cut off all the blades and removed the internals of the fan and placed the magnets inside the center and coils around outside
    being driven by a small 12v drill motor on the 6v4ah battery
    on previous models there was to much vibration and noise which makes it to inefficent i beleave
    all in all some pretty good resaults are coming from this experiment, but am looking for a way to charge the battery maybe from 1 coil and then the rest off to a grid tie inverter to sell power back to the gready power coumpanys
    here are some images of my latest model and my coil winding jig which is pretty basic a calculator and reed switch and old cordless drill. https://www.dropbox.com/sh/hi15zvdw1zbeze1/PuK0vj-Lzw
    ps sorry about the spelling, never really went to school so
    i will post more pics tomorrow and maybe a video too if i get the chance to make one... and will be rewinding my coils tomorrow too with the 0.25mm magnet wire instead of what i have used for this model which is 0.75mm i think
      Welcome
      fedexbra
      to the forum
      It looks like a very interesting set up do you have a schematic or video of your machine working.
      If you need help feel free to post a question the folks here are very helpfull and knowledgable
      Bizzy
      Smile it doesn't hurt!
      Jesus said,"...all things are possible through God." Mk10:27
        Hii bizzy will post a video tomorrow as its to dark outside to do so atm...
        The only circuit I have is the one driving the motor which is just a cap and risistor and a 4a circuit breake on the input side and I have made a 6 phase bridge rectifier,protection diode and 2x25v 2200uf caps for smoothing on the output. I am pretty new to this free energy stuff but believe I am on the right party to obtaining ou as on previous models I have built 6v in and 12v- 30v out, thats more out than in if I'm not mistaken
          You can increase voltage out easily in numerous ways, but its increasing the current flow or Amps out that you need.
            @lotayodi... Hii I knew about that but if it will produce 30v even at 1a that would be enough to supply a charge to a battery\bank correct
              Hey all i have finally revived my new magnets and have just mounted them in the rotor . After I clean up my work bench I'll take a video of outing it together and it running
                Basically to know if you have anything close to OU you need to calculate the power in versus power out in watts. So volts times amps on the input versus volts times amps on the output. Even that isn't the whole equation but it's a good start. Good luck with your project.
                  So if the max input is 6V @ 4A that's is 6x4=24watts yeah so if I can get 30V @ 1A that's 30x1=30watts that's more out than in and I am also thinking about running the electric motor at only 1A which would make it 6watts in and 30 out b going to have to wait for my multimeter to rock up in the mail......But from having it run another motor off the out put it seems to run faster but also it has no load on it either... Anyways I'm almost done cleaning up my work bench so will post pics tonight and video too
