Garret what you have basically said there, is not much different to what I said in
this thread here. http://www.energeticforum.com/renewa...nsmission.html
It is a fact that Tesla stated that a high rate of transformation alone would
be the best way for the transmission of industrial amounts of power.
Transformation ratio alone means there is no need for a magnifying
transmitter to be able effect the telluric transmissions.
The basic principal is being covered in a whole bunch of unnecessary
complicated confusion.
Oh and a counter wound receiver is not necessary unless using the atmospheric
upper terminal conduction method, or the one wire method Which none of us
are talking about anyway I don't think, We are talking of the ground
transmission apparatus. The receiver can be wound either way if it is at some
distance from the transmitter. One transformer is shown in the last wireless
transmitter patent because they can all be the same or different and only the
transmitter is needed to actually throw the planet into resonance.
To me the basic method is obvious and there is record of my trying to explain
it as simple on this forum. Finding the posts could be difficult as they are
swamped with others' talk of free energy and elaborate theories.
The basic method is to create a high potential so that currents can be made
to pass into the Earth and throw the planet into resonance or to effect a
ground disturbance, the receiver uses the ground disturbance to magnify the
power in the receiver so as to allow the output coil ( which is in an inductive relationship)
with the oscillating circuit can produce an output of usable power from two wires.
The basic principal is shown in a setup using only a wire and ground plane as
the connection between the transmitter receiver.
I have shown by experiment how the voltage and current in just the primary is
magnified which in turn magnifies the secondary voltage and currents.
The one thing I will say is that without resonance these types of
transmissions are not so effective.
indeed...
