Open discussion for projects on this forum.
  • Regulated power supplies
    Hello Guys,
    As you may know I recently bought a brand new PSU, which is the new kind based on Switching Mode, a piece of crap, I know...but my budget is low at this point...and the reason I got it was to run my Part G and Primaries...BUT needless to say it would not even add V when G was closed looped...Now it works...but it is still constrained as I am using very low ohms at all components...so can not "dial up" Voltage to its max potential output.
    My question is:
    Are these units "Regulated Switching Controls" or a "Protection" built in which is constrained directly based on Ohms or Kirchhoff Laws equations?
    The reason why I am concluding this way...is because when I tested Figuera Device with resistors it did render its full output which is 600W (60VX10A)...all the way till resistors started smoking....and PSU started its automatic fan motor...
    Now that I am using the low ohms Toroid winding...plus low Primaries as well...it only allows me to drive it up to a certain voltage which is far from Max V...while amps do reach max or 10A.
    If it would be so...then I would have to just maintain on my circuit the required minimal resistance values...like for a real example:
    My PSU is 60V and 10 Amps...which based on ohms law in order to fully drive it to max Wattage it must have at least a resistance of 6 ohms or above to play within its safety zone?
    Calculating from Ohm's Law: R=V/I so 60V/10A = 6 Ohms
    If it is so...then is just a piece of cake to wind my primaries and part g in order that they add up these resistance values...
    I wish I would be correct...but am I?
    Please let me know...and thanks in advance!!
    Hi Ufo,
    I guess it would be clearer if they stated the specifications like this:
    60Volts or 10 Amperes (whichever comes first on the particular load) and up to 600 Watts maixmum.
    So:
    Using resistive loads for simple examples.
    6 Ohms will max out current at 10A and voltage at 60V and be at max power of 600W.
    Say you have a 4 Ohm load. It will draw 10A from the PSU which will regulate at 10A and set the voltage accordingly, 40V in this case. If the load heats up and goes to 5 Ohms, the PSU will maintain that regulated 10A and automatically raise to 50V. (If you have the voltage adjustment set above 50.) In this example the 600W rating is not achieved.
    Say you have a 20 Ohm load. You could set the PSU to supply anywhere 0 to 60V. Current will be determined by Ohm's Law but would never exceed 3A. If you had the current dial on the PSU set lower than 3A, say at 2A, then the voltage will be limited to 40V such that 2A is not exceeded.
    PSU = power supply unit.
    You have 10A max or a lesser setting and/or 60V max or a lesser setting and the PSU will regulate at which value it encounters first.
    I hope that is understandable.
    • UFO, some pics from my 50Hz sim. Probably much faster then in your test. The higher freq gives higher XL values in sim than in your testbed= lower current. And have mostly higher fixed milli Henrys than yours. Supply voltage 24V !! I have 20 steps but only 1 + 1 time segment fully ON you have 2 + 2. Primarys 20 + 20mH secondary 1200mH. Observe the high start current! Run Amps =8 (yellow). This sim is not fully otimised! / Arne
      • You could say that the effective internal resistance of the PSU is 6 ohms, so the PSU won't be able to supply full output power, or maximum rated power, to any load below 6 ohms
        Voltage drop - Wikipedia
        Internal resistance - Wikipedia
        • Originally posted by seaad View Post
          I can only read from above:
          ..."Mine is Much Faster"..."Mine is Much Higher"..."Mine is Better..." than yours...
          Only one big difference...your whole thing is Virtual...mine is VERY REAL.
          Believe me I can accelerate that small Motor and Assembly up to 10,000 RPM's...and also Increase V and A Higher than that on video...but I will just blow my bulbs...and am not to do that stupidity.
          You keep doing your virtual simulations with Field Signal passing the zero zone.
          How many more times it is required to tell you it must be positive (above zero) at all times??!!
          Idk really why I am spending time here with you...when I have so many more important things to write and do here...
          • Originally posted by dR-Green View Post
            My PSU is a switched output and not linear...I only wished it would be linear...
            About Voltage drop...yes...it won't let me dial above certain value...is like doing nothing when I dial it up.
              Hi Ufo,
              So:
              Yes, thanks for your time Bistander!!
              Yes, it seems there is something very different from this PSU and the Extech I had for years...on the Extech I can set a CL (Current Limit) to Max, then just dial voltage, or viceversa...as both potentiometers dialing travel distance from min to max is the same...Not so for the newer one I have ...the Current (A) Pot is kind of normal dial distance...but Voltage Pot seems like endless travel to reach Max gain...not the same type at all...and this set me completely off when attempting to reach a proper VA adjustment.
              Unfortunately the Extech is only 18V and 3Amps Max output.
              I measured the resistance from both terminals of PSU when it was OFF...and gave me 1.140 Kohms...and when it is ON (no power dial of course) it goes down to 1.132 Kohms...have no idea if that would help...or mean any real value...but just a travel of meter signal through electronic circuit of PSU...(It takes very long for meter to read final, steady reading)
              Resuming here...so you believe it will give me close to Full Output at 6 ohms within circuit?
              I actually do not attempt to reach the full 600 Watts...but around 50V and like 4 or 5 Amps Max...which is about less than 50% from total output wattage (200 to 250 W).
              I will see by testing with some resistors directly...and observing increase ability as I increase R.
              Problem is that all Linear feed PSU's are untouchable because of such high prices!
              I have a new small 70 A Arc Welder, which I may start playing with it in order to convert it to a nice and robust Linear Output PSU...It has a massive Transformer!!...But it don't have Pots to regulate but Min-Max current switch...
              Problem is to find some decent priced high wattage pots...as at the same token...I have too many projects going on at once...so, I wouldn't like to add another one..
              Hope this resistance solves issue.
              Thanks again Bistander!
              • Ac/dc
                Ufo,
                It appears Mr. Seaad's graph showing AC voltage (+ & - swing) is taken from the secondary output, which will be AC. It is basically a transformer secondary. Transformers only work on AC or changing DC. So just the AC component on the primary current is transformed to the secondary.
                You all are patting yourselves on your backs thinking you've found free energy. I see no evidence of that. You have only gotten a signal from your partG by a modification which seaad and I were pointing to a month ago.
                Be interested to see data from the complete circuit (with secondary and primary).
                  Ufo,
                  Bistander,
                  I can see clearly Two Signals there...one Yellow as the Primaries stepping signal, plus a Red AC sinewave ...and so I was only referring to the stepped yellow signal, not the AC Sine.
                  Bistander, done that and tested...prior with resistor tests (not yet with part g).
                  Wake up!!, main point here is that Virtual Fields Fluctuations Displacement DO Generate an Induction on Secondaries...I did that rough test and got same light bulbs lit up hooked directly to secondary coil. And at low frequencies.
                  Spatial Virtual Fluctuations from Static Primaries Electromagnets Fields DO generate an EMF Induction on Secondaries.
                  • UFOpolitics, you scrambles my text in YOUR Quote 2 from MY Quote 1 to your favor, as you think. But, you are only making yourself foolish!
                    The point of my post was NOT to say that my contraption is better. My intention was to make YOUR contraption BETTER!! The same with the shortcutted G-part too!
                    ( I'm not good in English but you are ...... ! )
                    And the signal goes through zero because it comes from the secondary! (NOT a Field signal)
                    How should you achieve OU whether you seems to misinterpret most things??
                    PS: Run Amps =8 ("Yellow")
                    regards / Arne
                    • You can determine the internal resistance/output impedance of the PSU through making a simple voltage divider on the output. When the measured voltage across the load resistance is exactly half the output voltage, then the load resistance is equal to the PSU output resistance.
                      Voltage divider - Wikipedia
                      But on the subject of PSUs, I find it cheaper, easier and more convenient and reliable to get some transformers and regulators and make my own. And if you blow it up then it costs all of 50p to get a new regulator, which may have built in thermal and short circuit protection anyway. Then there's no trouble of unknown circuitry and switching frequencies and what not. I don't like the idea that I can light up 90V neon bulbs off a single wire from a 12V DC switched mode power supply...
                        regards / Arne
                        How did you come up with such output at secondaries being that yellow shaped signal?...which happens to be identical to fields signal?
                        Are you assuming this or is it the software response?
                        There is one thing you both (Bistander and You) are missing here...
                        The Input Signal to Primaries only effects a Spatial Fluctuation of Field on Secondaries, which is soft and smooth fluctuation...and Secondaries output signal is absolutely not the same as primaries!!!
                        Your simulation software (in case resulting wave is due to it) is just "assuming" this transfer would be done through the same iron core, or by your input, assigning software a full, common core just like a transformer with field signal as input signal...and not like in reality it takes place, through Space.
                        No Sim Software is designed/programmed to reproduce exact Figuera's Full Circuit Conditions
                        Unless you are a Sim Software Advanced Programmer Engineer...and honestly I don't think so.
                        This conversation is completely nonsense, and I see why MM don't want all this noise there at the building thread...
                        Anyways many thanks for trying to make my system better...I appreciate it...but I have my own ways to go for it.
                          Thanks, I will look into all that!!
                          • UFO Quote: "" How did you come up with such output at secondaries being that yellow shaped signal?...which happens to be identical to fields signal? ""
                            Not out!
                            INGOING current, feeding the contraption from the PSU. Its frequency is 2 x the output frequency! Amp scale to the right.
                            I wanted to show you that with my component values and 24V and below 10 Amps you can still use your (weak) PSU.
                            Arne
                            • Virtual
                              Whether the methods may vary to achieve field fluctuations, the main goal, the proof of concept from Figuera's main idea is real and it does work!!
                              Ufo,
                              By virtual, do you mean "not really there"? Like generated in some computer simulation or alternate reality but undetectable in the real world? Because this fluctuation in the signal from your partG is real and causes real fluctuations in the fields of the primaries.
                              You can return to the forbidden thread where you only have to deal with the goodfellows and never a discouraging word but it is all silly. I know I, and I think seaad have never attacked or insulted anyone here. All I have done is circuit analysis and made comments on the device, not the people. And seaad has been running simulations. What's wrong with that?
                              Here's a goodie which may be useful to those winding toroids and trying various connections. Magnetically, the only part of the coil turn (or wrap as some call it) is the part that passes through the center of the doughnut hole. Extra loose coils add some small resistance to the electric circuit but only the number of "pass-throughs" of the toroid core count as mmf (Ampere-turns). I'd leave the coil loosely wound until you've worked out the number of turns, location of taps, and wire size. Then rewind tightly to minimize resistance and varnish in place for durability.
                                Ufo,
                                Bistander,
                                Basically I meant "Virtual" because it is NOT PHYSICAL1 : Being such in essence or effect though not formally recognized or admitted.
                                2 : of, relating to, or being a hypothetical particle whose existence is inferred from indirect evidence <virtual photons>
                                Above definitions taken from the Merriam-Webster Dictionary
                                I would say #1 will fit your way of thinking specifically...since you are of the thought that the "Spatial Field" further away from the air gaps in any Electrodynamics Machines...is considered as being neglected by actual science...and so, the "main and REAL fields" at work for your concepts...(due of course to your Classic Box training) in any of those machines would be ONLY the ones completely and intrinsically attached to their magnetic carriers like electromagnets or permanent magnets Cores...plus their very limited and "tiny" air gaps displacement...
                                #2 shows clearly we have defined Photons as Virtual...but they exist and are very real right?...Oh, but we can not see them...feel them...or touch them...Uhmmm.......massless, weightless and transparent Photons...same properties as Spatial Magnetic Fields don'tcha think?
                                Ahhh...Wonderful!!...Now you are starting to evolve into the Future, and out of that Box!!...and that is grrreat!!
                                But, not only Part G causes fluctuations on the primaries electromagnets...but also Fields expands all the way to the -in between- Secondaries...now can you take a closer look at Air Gaps here between both primaries gap, which are the "Field Generators", then notice this is beyond the size of a conventional air gap in a typical generator ?
                                Because we are talking here about a Spatial Magnetic Field Fluctuations which Scope is completely beyond the limited size of expansions contractions which were thought to you by classic electrodynamics magnetism...and that is achieved without moving primaries electromagnets mass... not even a millimeter mechanically...
                                But I love being there..!!...no noise from absolutely no one who is NOT BUILDING like We ALL are!!!
                                As you will all soon see how from Virtuality...we make Reality...
                                I really do not understand your underlined, bold statement above...we all must go with the wire through the toroid (or donut) hole in order to wind a toroid...
                                About leaving some room...making windings a bit loose...I said that on video...as well as I have written about it many times.
                                What we can not do ...is to make lousy windings like when we cross wind turns or leave longer or uneven spacing between winds (turns)...
                                But thanks for your concerns Bistander.
