  • Quoting Myself on Previous Post
    Hello to all the ones who are replicating here...
    Just for ALL of you out there, I know you are interested in building it with me here...this is what is supposed to be done...and that is why am here!!
    Thanks!
    Here is the 750 Watts BOSCH Motor Diagram I have run with that miniature battery for more than seven minutes in my last testing...and could not stop it...it carries me on an electric scooter with three LiPo's (36V) and hauling ...
    It has 20 poles, four stators, four brushes on each upper lower ends...I wound it with 18 awg, around 20 turns per coil of two pairs...I have to make a resistance measurement and I will post it later on...On this motors is easy to do that "per Two Pairs of coils" since it has four Motor Brushes, all to do is rotate the armature...till find a good contact...they are also great to be able to diagnose that way...for open coils...
    @Mathew Jones: This is it Matt, sorry I did not had the CAD at the time you posted your question, and no, it is not like the connections you have shown before...
    Now, for sake of simplicity and not to fill it up with 20 Pairs of Coils...I have set it with just the Four Pairs that are interacting at the brush contacts...but the same "Laws Apply"...they are all wound in same directions...and starting all at one commutator and end at the other one...
    Now, in order not to get confused with the number of poles config or else ...
    Just think as a straight coil that you have separated in Two Halves right at their center, and inserted one right next to the other half, where the both sections facing outwards toward stators...were the upper-lower ends at its straight (before) shape...
    It is Ok to do "Finger rolling in the air, like following the wounds while turning to next pole"...just try that no one is watching you...or is going to think you have gone mentally insane...
    Ok Turion, take a look again at My Original Post here, related to the BOSCH Design...
    I will post a new one more "organized, However I Bold the important issue here...about how many coils total...
    Be back
    Thanks...had to go back just a "few pages" to find this post...
    • No, I am sorry...
      UFO
      I am having some trouble with getting my Modified Razor scooter motor to run. The attached diagram is the way I have it wired. In the scooter motor the windings go around three commutator segments instead of four, but that is not the issue.
      1. The diagram seems to indicate that there are eight coils. Correct?
      2. A blue coil and a red coil each have a wire connected to the same commutator segment. Correct?
      That uses up four of the 16 segments on the commutator. Should four commutator sections be connected together so there are four groups of four, or should three be connected together to leave off time in between?
      No Dave...hold on!!!!
      Nope!!...I am really sorry, there are a Total of Twenty Pairs, meaning Forty Coils!!
      Ok, the Diagram I have presented shows ONLY four Coils for SAKE OF SIMPLICITY!!...It is a 20 Poles Armature, and Each Coil, will turn around Four(4) Poles...So a Pair will comprehend Eight Poles, so it will have a Total of Twenty (20) Pairs and Forty (40) Coils!
      Meaning Twenty Norths and Twenty South Coils.
      Each Pair will have Two terminals, positive and Negative...right?
      and you have 20 elements at upper Comm, and 20 at lower comm...so you will need Forty Coils to fill in ALL EACH Commutator Elements, there are NO Elements joined here...each Pair has One element above and one at lower comm.
      I explained in Diagram that...I used Two Pairs, one for each Input brushes, and Two Pairs at Output (Gen) Brushes, not to fill in Diagram and make it a Mess with forty Coils there!!
      They overlap as you see on Diagram, by leaving one pole to start next round...forward...
      Did you see my Picture of Armature wound?
      [IMG][/IMG]
      NOPE, it is the same topology, same laws as the small R/S Motor, Positive goes to Positive Commutator and Negative to negative Comm, ONE Element per Pair above, one top. This (+-) is MAKING SURE, when Positive On, they turn Blue (North) and Red (South) by checking FIRST PAIR with a Compass, If you do not apply or not sure of the Right Hand Rule...
      Now, you have to figure the main rotation of Scooter...Left or Right, In my case I had to make it Left direction (CCW)...to go forward...So this drawing is for that application...I know you could reverse Voltage terminals...but the Design should be conceived based on BASIC and Operational direction...because all ""Throw Out Angles" are calculated based on getting the "most" of Torque-Speed.
      So, the winding of First Coil...apply a small battery to terminals to check Pole orientation, then mark which will be your ALWAYS POSITIVE Commutator...and start winding...You will have to fill in ALL Commutator elements...at One above, One below...First Pair..and so on.
      Let me know
      Am sorry about your confusion there...
      Now, that is why...I ask you in My previous post, "if you have calculated the amount of wire that Motor will take"...to set Comm so close to armature...
      • Got it. Thanks!
        • Great Dave...sleeping well now...lol
          Got it. Thanks!
          Ok Dave am glad!
          Good night
          • Sleep? Are you kidding? I'll be up all night winding coils! LOL. Or dreaming about winding coils!! I don't know which is worse.
            • Idiot guide to winding
              Hi guys I'm new to all this but would love to join in but has anyone got a idiots guide to winding a motor and following the diagrams of UFO's ?
              • Different motors take different windings. Folks will be more than happy to help, but need to know what motor you are using...how many sections on the commutator, etc. You need TWO commutators, so in most cases that means taking apart TWO motors to make one. The easy way to start is with the little Radio Shack motors, just to see how it works, but that is not a good motor to really do any testing with since no two are exactly alike because they are so cheaply made.
                • I'm starting with the easiest one with 3 armatures then will progress once I get the hang of it
                  • 25 Pole
                    Hi UFO,
                    I would like to rewind this 25 pole beauty, can i take
                    your 20pole example and group 5 poles together instead of 4 poles?
                    Thanks for all your work
                    PS: Can anybody tell me the best way to get rid of this grey coating?
                    • open file
                      Hi Fabio
                      look this patent too:http://www.rexresearch.com/szabo/wo9318570.pdf
                      waterfall
                      • Pmwuk,
                        If you read through the thread from beginning to end, all the info you need is here. For the three pole motor first look at posts 53 and 96. All the info you need has ALREADY been posted.
                        • Hi all,
                          I tried to make my first modified motor this weekned, from two small toy motors, i thik 4.5 or 6 V, they looked the same but had different gauge wire. They were 3 poles, but very fragile commutators.
                          I managed to place the second commutator on the shaft, but had no extra shaft outside the case. For some reason it didn't start, i figuerd my battery was too discharged and i couldn't start it by hand to see if it turns. When i changed the battery i fried the coil that was on... (sound stupid, i know, but i was too excited about this little motor )
                          Until i get more wire to rewind the coils for this little guy, i'll put it aside. My plan is to use some rotors from two AC motors, 12 poles each for the next step. The comutators have 24 slots each, i'll use every other one to connect my coils.
                          I can't upload pictures yet, as my laptop broke down... but i'll have it soon fixed.
                          Happy motoring
                          Live long and prosper!
                          • Originally posted by pesonic View Post
                            Hi UFO,
                            The grey stuff is more than likely baked on. Watch this:
                            Winding of an Electric DC Motor - YouTube
                              Pmwuk,
                              Thanks for the help
                              • Toy Motor Mod for Civu 08; Winding Guide for PMWUK
                                Civu, I started with a 3 pole toy motor as well. It would not work until I turned the end caps 90 degrees at each end and placed them on the motor, and it worked like a charm. My motor cases were like flattened cylinders. The ends had to have slots cut into them (I used a very fine exacto saw) to make them fit over the ends. The trick is to be precise to keep the clearance between rotor and stator magnets. If this is your issue, once the brushes have been turned 90 degrees relative to the stator mags, she may run for you. You may have to make some fine adjustments, and once you've found the right seating of end caps, a drop of crazy glue at top and bottom of each end will hold the caps in place.
                                Pmwuk Hi guys I'm new to all this but would love to join in but has anyone got a idiots guide to winding a motor and following the diagrams of UFO's ?
                                PMWUK, Dave's right. It's important to read; and check out the posts he points out. There's an excellent 5 pole wiring explanation here:
                                UFO's 5 pole wiring diagram is above, and the 3 pole diagram Dave refers to is below.
                                If you're winding 3 poles, follow UFO's instructions closely.
                                Go slow, be methodical with it, follow the Yellow Brick Road, and watch what happens to the witch .
                                Bob
