    That was absolutely all I needed to say or write here...
    Excellent graphics as always UFO which paint the picture perfectly...AND...we agree, it seems.
    I didn't want to go into fractions of degrees when broad principles establishes the point, but I can.
    I referred to 'pole angles' as 'A' being 1/28 of 360°...which is 12.857°
    The angle between P1C2 and P2C1, I referred to this as 'Z' being '5A' ...which is 64.285°
    I notice you have indicated the brush width as being approximately 50% of the comm segment width, not full width as it is in my 12 pole motor. This reduces the sweep angle 'sA' before P2 disconnects from 12.857° to...6.428°
    So
    X + Z + sA + Y = 7A = 90°
    Substituting
    X + 64.285° + 6.428° + Y = 90°
    X + Y = 19.287°
    X is tunable in the region of 5° from previous posts AND
    Y wants to be in the region of 20°
    Which adds to more than 19.287°
    Of course for the 12 pole 2 stator motor X and Y can not squeeze up to accommodate -
    'Z' being '5A' being 5/12 of 360° ...which is 150°
    The brush width being the comm width 'sA'...which is 30°
    So
    X + Z + sA + Y = 180°
    Substituting
    X + 150° + 30° + Y = 180°
    X + Y = 0°
    And therefore is not achievable.
    However the 12 pole motor configured as '4 pole pairs' does work, I've done it. But it is determined by the flawed geometry to be inefficient as the leading coil remains energised past the magnet bisector and therefore contributes drag.
    Good Hunting
    mark
    • Serious Geometrical Error(s)...
      So
      Substituting
      X + Y = 19.287°
      So
      Substituting
      X + Y = 0°
      Good Hunting
      mark
      Mark,
      Why you complicate yourself so much?
      It is so simple to look at without ANY Commutator nor Brushes.
      I am glad We agree up to a certain point, which is 360/28=12.857...as well as Five (5) Total Poles from start repulse bisector PIC2 to P2C1 create a 64.85º Angle. But let´s be even simpler here, so let´s round up 64.85 to exactly 65º
      That is all I need friend...no more angles within rotor nor commutator...but NOW, let's go from North Stator Bisector to South Stator Bisector...and we have exactly 90º.
      Now let's 'fit' 65.0º of Rotor Interaction Angle within 90º of Stators...from N1 to S1 Stator (which is only Half of Total Rotor Interaction, remember this is a Four(4) Stator)
      We set P2C1 Bisector away by 5º (towards rotation) related to North Stator Bisector , meaning we are now at 70º...and now...just the simplest math on this world...
      How much is 90º-70º=?
      Yes, exactly that... 20º, that's how far we are from South Stator Bisector.
      We have 20º to play from either side of both stator's bisectors (which is 90º)
      The Commutator for this Motor is based on 56 Elements, NOT 28....Therefore, every Single Pair must attach to TWO Elements.
      But this fact does not matter here, we are "fitting" the real magnetic interactions from Rotor within Stator configured Angles.
      You can NOT add EVEN 1º MORE TO 64.85º or even rounding to 65º, that is the Rotor MAX Interaction Angle based on Two Pairs being fired at same timing, when it is just one Pair being fired this Angle REDUCES TO Approx. 52º (4 Poles from Bisector to Bisector on One Pair =12.85º X 4= 52º)
      I really have absolutely NO IDEA WHY...You have to "KEEP ADDING" Commutators and Brushes angles to 65º from MAX EXTERIOR INTERACTION ANGLES, IF all those Commutator/Brushes Angles are COMPLETELY RELATIVE, as COMPLETELY IRRELEVANT TO MAGNETIC INTERACTIONS!!??
      The wires from Pair Coils to be attached to Commutator Elements-Brushes...I could flex, pull, stretch, Turn them left or right...up or down and connect them wherever I please to do...within interacting angles, or away by 10, 20, 50 100 degrees...it DOES NOT MATTER...that is just an ON-OFF Switching...as a matter of fact one could be in Japan, while the other one in Ireland...don´t care....or be Remote Control by all means...it does NOT ADD NOR SUBTRACT to the REAL MAGNETIC INTERACTIONS taking place.
      [IMG][/IMG]
      Switches are VERY Relative here, We could install them anywhere... like shown above... Brushes turn, wires expand and reach connections to Comm elements...Commutators turn ...above setting is right at center of Pair Intersection...the MAIN SIDE To Observe here are the MAGNETIC INTERACTIONS taking place between Rotor Coils and Stators.
      The only thing the switches are supposed to accomplish...is to Disconnect or Connect when they are commanded to do so.
      I have set different positioning of brushes and comm elements here related to every machine different configuration settings...choosing the position would be better to adjust without major complications...making it simple for building.
      This confusion you are showing...all is doing is confirming that all your previously built motors have also, something very and seriously wrong within their interactions/timing settings...reason why all your under performance readings.
      However, I admire the fact that you DO have the 'audacity' (not to say the balls..)... to start shooting at me,the bringer of this type of winding...and who have a few naked, Imperial Rotors in his Garage...plenty of wire and many, many Geometrical Angle Rulers, and software CAD'S , HD Cameras to demonstrate you ARE WRONG...
      Please, think about all this...and do not waste my time insisting now on a Motor Structure you have not even started to work with...?
      • When you have 2 coils which have 4 coil sides and it is obvious that 2 of those coil sides cancel each other out, it is a no brainer to eliminate those 2 coil sides and go with a single coil of twice the span.
        A Single Coil would have much less "span angle" or as I call it Throw Out Angle. You can not just use one single coil and wrap it around EIGHT POLES of that Rotor, it is too wide of a semi air core, half and half steel and air desig
        UFO!
        6 poles coil for the A1MoGen = "singular coils" will be close the RPMs of the Pair Winds and 7 poles might be faster... "span angles" is not very important because the RPMs are almost the same.
        *TORQUE*
        ALSO the singular coils = A1MoGen will have around 30% - 40% MORE TORQUE than pair wind... Torque is very important.
        FACT: The A1Mo-Gen = singular coils wins huge in toque!
        Keep it Clean and Green
        Midaz
        Cat & Mouse
          So, on this Method We MUST TEST FIRST before engaging into Full Winding, by checking IF P2 and P16 (Leaving Pairs according to Rotation) get FULLY Disconnected BEFORE even reaching each related Coil#1 Bisector NOT TO ALIGN with South Bisector Stator!!!
          That is the reason of magenta 'enclosed region' for CRITICAL TIMING SETTING
          I have set Coil#1 in each Pair for being the one closer to Commutator Element to be connected to, as this would be the First Coil We start winding from each Pair.
          NOW, IF WE DO NOT FULLY DISCONNECT P2 & P16 BEFORE IT REACHES SOUTH STATOR BISECTOR...WE MUST DISREGARD THIS METHOD AND SWITCH BACK TO PREVIOUS OVERLAPPED METHOD, WHICH OFFERS MORE ADJUSTMENTS.
          Twice you reinforce the point that P2 must be FULLY Disconnected.
          We agree on the rotor geometry angles.
          We agree on the stator geometry angles.
          From your diagram we set the P1C2 bisector at 5º to start the 'ON' time...not P2C1 which I think is a typo.
          Therefore we agree on the minimum time 'ON' angle of 5º.
          But it is self apparent from your schematic that with P1 just entering the brush with P1C2 at 5º, P2 is still fully connected. It has 6.428º (call it 6º) before it fully disconnects. That moves P1C2 from 5º to 11º.
          So it is no longer 20º for P2C1 but 14º. From previous posts this was considered not ideal.
          However, on the 12 pole motor when you consider the rotor geometry as 150º and P1 just entering the brush, P2 is still fully connected. It has 30º before it fully disconnects. That moves P1C2 from 5º to 35º...adding rotor geometry of 150º...It exceeds the 180º requirement to disconnect before reaching the south bisector and you conclude 'WE MUST DISREGARD THIS METHOD'.
          I really have absolutely NO IDEA WHY...You have to "KEEP ADDING" Commutators and Brushes angles to 65º from MAX EXTERIOR INTERACTION ANGLES...
          ...The only thing the switches are supposed to accomplish...is to Disconnect or Connect when they are commanded to do so.
          Agreed. The leading edge of the comm segment connects on one side of the brush and disconnects when the trailing edge of the comm segment leaves the other side of the brush. The brush width has to be considered in the equation because P2 has to advance over the brush before it can FULLY Disconnect.
          However, I admire the fact that you DO have the 'audacity' (not to say the balls..)... to start shooting at me...
          Please do not see this as shooting at you. It is important for others to understand these interactions. As a novice those many months ago I didn't realise this simple truth. Fortunately I wasn't designing motors, I was building them to pattern. Now I'm designing configurations and testing performance.
          Your quotes above make it clear that the 'ON' time starts from P1 just connecting to the brush to the time when P2 is fully disconnected from the brush. It is self apparent within those two criteria that the angle for P2 being on the brush MUST be added to the critical angles between the two relevant magnet bisectors.
          I have been repeatedly accused of being unable to time my motors because I am confused. The simple fact is this...these factors are out of everyones control. All comm segments, in principle, are connected to the brush from the leading edge of the comm entering the brush to the trailing edge leaving the brush.
          Hunting
          mark
          • Originally posted by HuntingRoss View Post
            Yes that is just great we agree on those points-angles.
            It was a 'typo', you are correct it is P1C2
            Yes, great we agree again...
            Ok, so it was good enough having three agreements in a raw...now I disagree with you.....because you are just adding the 'switcher displacement angle' to the magnetic interactions angle...just because the "switch" is outside the 64.85 degrees from the EM Interactions taking place.(see image below as the one you are referring to):
            [IMG][/IMG]
            Hunting
            mark
            Let's stop 'jumping' from 28 to 12 poles Machines Mark...pls...let's keep on the 28 poles Imperial.
            So on Image below...I want you to do your Math, the same "method"...and tell me the total angles that we have to adjust timing there...Obviously you overlook this image because I have uploaded on previous post, and you did not quoted at all...
            [IMG][/IMG]
            What about another commutator element connection from P1-P2 terminals?...plus brush rotation to meet the desired timing?
            See below Image Mark...a closer approach to original argument-discussion, but keeping "The Switch" WITHIN the 65º Angle of the EM Interactions...
            [IMG][/IMG]
            Now...are you still adding the Comm Element plus Brush displacement Angles on the Two Images above Mark?
            What I want you to note by those Two Images (actually all three) above...is that the switching angles could be moved within an unlimited area regardless of the EM Interaction Angle, (not affecting it at all) so...could be after (post), within (Aligned to EM) or even before (pre-retarded) to our convenience, however, the EM Momentum displacement still, will be taking place within the specific/required Space/Time, which is actually THE SAME for All Three Images on this Post...
            We are just changing "around" the "Switch" position, by stretching the connecting wires just 'a bit'...then moving the Brushes to meet those contact plates...
            It is a completely relative "item"(the switching circuit)...just like we could set the actual, physical ON-OFF switch... anywhere we decide in any electronic/electric device or equipment...
            Just hoping to have the 'final agreement'...
            • Tuning Test Results GM QUP-10 embodiment
              No magic bullet found so far in Quad Stator embodiment. I was looking for the spike down in amperage as found by GChilders in his dual stator 5-pole conversions.
              Review: This motor is built out of GM window regulator components into an aluminum 2' pipe, converting it to a Quad Stator. The rotor is a 10-pole and is wound using trifilar 32ga wire, with the coils coming in at a calculated 1.22 ohms, using 6'/ohm metric for for 32g wire. each coil had about 22' of wire. End plate construction allows tunability only constrained by brush wire length, as the brush wires must exit thru the motor body as opposed to the endplate, since the quad brushes took all available real estate there. I found I am able to avoid higher temps at the brushes, with lower amperage with the extra .2 ohms. As it has broken in the amp draw has dropped and the rpms risen, now maxing out close to 7000 and the brush temp about 122degF.
              Test picture shows optimum performance at 11.6v, 1.58A, using a 60w 12v power supply. Two of the 4 brush sets are receiving power.
              Using Ufopolitics wiring diagram to display results:
              The zero degree position is Ufo's recommended setting on his diagram. From there I notched 1/8" hash marks, 4 on one side in the direction of rotation, and 3 opposite to rotation. This is approximately 7 deg. per mark. I found pretty much a smooth degradation from optimum as I moved away from the 0, "zero" setting.
              Findings: Amp draw increased proportionally and rpm dropped as tuning was adjusted away from the initial position. Although amp draw increased a factor of 2 and 3 times as tuning was moved 21 and 28 deg away from optimum, No factor of 10 or more improvement was found.
              PS: tried a few 1/2 hash mark positions also, no suprises.
              Up, Up and Away
                [IMG][/IMG]
                So, this two images above represent the "Magnetic Circuit" as we all have observed for 224 years...IGNORING "BLOCH", DOMAIN OR DIELECTRIC WALLS...
                But, even more errors were added besides the wrong 'lines of force' formation by iron filings...Oh no!...but they further on 'concluded' without any substantial proof that the FLOW will take place FROM NORTH TO SOUTH...as seen the arrows above following a ONE WAY direction...
                This concept when translated into 'typical' electric circuits will mean that North is the "Source" while South is the "Drain"...Or even say North is Positive (+) and South is Negative (-) right?...right...so then...explain to me why we still have a very solid repulsion field between two South Poles?...
                We shouldn't have "any flow" at all, between two Drain sides without any "Source" being involved.
                Even more simple...Two Negative charged end terminals will NOT do absolutely NADA...not even a very dim spark when making contact...
                Then, concluding Two South Poles should do as well...absolutely nada, no attraction nor repulsion either...(according to 'stated' direction of flow)
                We all know this 'no field interaction' between two South poles never takes place...Two South Poles will repel as stronger as Two North Poles...it is a FACT!
                Your analogy to electric circuit is flawed.
                copied from: 6.3 - Magnetic Force and Field
                I don't understand your reasoning. Two magnetic South poles repel and so do two negatively charged particles (repel).
                Sparks are caused by potential difference or voltage. I don't know what you mean by _Negative charged end terminals_, but if the two conductors have little to no potential difference, they will not arc as they are brought together to touch.
                • Free Speech
                  Now, that is wrong Bistander, you have absolutely no right to "influence" others from My Thread here, with your old, ancient science laws...let them experience by themselves...they have been doing it before without you here...trying to "warn" about old concepts.
                  You are wrong Ufopolitics. I have the right to free speech. Even though you may consider ancient laws unworthy, the US Constitution and First Amendment trump you. Those who seek to shut out dissenting views and limit the speech and expressions of others who disagree with them often become tyrants. Don't let this happen to you.
                  So...let me see if I understand you...You are saying just "That Portion" of each coils would cancel...right?...cancel what to zero?
                  1- Magnetic Field?
                  2-Electric Fields?
                  3-Current flowing through that particular end?
                  I went through this twice, but again for you. Yes, the 2 coil sides in the same armature slot cancel;
                  1 - Magnetic field for those two coil sides.
                  2 - Electric field for those two coil sides.
                  3 - No, current will still flow through those two coil sides. It has to to complete the electric circuit. And that is the problem. You have current flow through copper and associated resistance which does no work for you.
                  Precisely, a Single Coil would have much less "span angle" or as I call it Throw Out Angle. You can not just use one single coil and wrap it around EIGHT POLES of that Rotor, it is too wide of a semi air core, half and half steel and air design.
                  But that is exactly what you end up with with your coil pair because the inside coil sides (sharing the same slot) cancel each other magnetically. So the coil pair will behave just like the double wide coil.
                  Yes, have "provided" the foundation for an electric machine industry...yes...but based on what kind of "PRIME MOVER" has been required for so long to just "TURN" those Generators built for over two Centuries?
                  Unfortunately, many Generator Designs have being conceived during all this long time...however, all based on the same old, methods...same old concepts.
                  They all still, require the "herculean" farting machines to run them all...what a wasted time!!!
                  Efficiency?...please...show me FIRST the "efficiency" of an ICE (Internal Combustion Engine)...and yes, of course... go to the "latest, state of the art" machines...to find out...be my guest...
                  I was talking about the electric dynamo. And the electric generator can be powered by hydro or wind turbines without any objectionable farting. This is the renewable energy sub forum.
                  I really don't want to argue with you. So just drop it. I simply saw an obvious way to improve an armature winding and posted it. You have an empty core there. Give it a try. If it works, use it and develop your own theories as to why.
                  • Originally posted by sampojo View Post
                    Sampojo
                    Thank you for your findings. I was hoping that you found amazing test results like Gary's "sweet spot". Was all if the timing adjustments done under No Load?
                    Bistanders is debating Raul/UFO on "Coil Magnetic Efficiency". Just like me, Bistander is saying that the Singular Coils are best for Asymetric Motors . Singular Coils is exactly how I made the A1MoGen. If you decide to build your motor with the Singular Coil design. Use 4poles singular coils for you motor. You will have more TORQUE, higher RPMs & less voltage drop.
                    Tesla was an efficiency purist. He would've done it with Singular Coils.
                    Midaz
                    UFOs and flying Unicorns are still myths. Looks like DADhav was correct. Gary, where is your proof or are you gonna disappear again!?
                      I'm neither overlooking nor ignoring the images. We already agree that the switching can happen in any position, so moving the brushes makes no difference to my comments. The only thing not on the images is the magnet bisectors at 90º.
                      I see the point of contention is what I've been calling the 'sweep angle' and you refer to as 'switcher displacement angle'.
                      And the issue is this. When our schematics show P1 coming onto the brush with the coil bisector at 5º and your emphatic comment :
                      Then we have to advance our schematic to the point when P2 is disconnected and consider the position of the bisector relative to the south bisector which has been stated in previous posts as being 20º.
                      If we refer to your images and ask 'Is P2 FULLY Disconnected' the answer must be NO...It is clearly connected...And will be for another 6º.
                      Where is the P2C1 bisector now ? It is -
                      5º + 65º + 6º + Y = 90º
                      Which leaves 14º, not 20º.
                      This may be sustainable in the 28 pole Imperial but when this was discussed in the context of the 12 pole motor, the point was rudely dismissed.
                      Surely we can agree your images show P2 to be fully connected at 5º + 65º ?
                      And surely it is not contentious to acknowledge that P2 is connected for another 6º before it 'rolls' off the brush ?
                      Hunting
                      mark
                      • Originally posted by Midaztouch View Post
                        Quick up date on the A1MoGen EV build with battery configurations.
                        In your video you state the motor is achieving around 150 rpm/volt.
                        Now whilst I don't agree fully with the concept, most on this thread are adopting rpm/watt.
                        On that basis, from your 20v DC PSU test -
                        150 rpm x 20v = 3000 rpm
                        3000 rpm / 420w = 7.14 rpm/w (no load)
                        Not allowing for frictional losses and so on. With a sprocket ratio of 3:1 your rear wheel will be 2.38 rpm/w (no load).
                        Hunting
                        mark
                          Hunting
                          mark
                          Mark
                          Don't adress me again... A 16awg coil wire got stuck = HIGH FRICTION = high AMPs, between the rotor and magnets during transport on my Bicycle. (That's why I said "I can show you 150 RPMs... ANYTIME and its CONCRETE", in my video.)
                          Me going to the Meiwa Electric was all about A1MoGen & Asymmetric Motors on a DC power supply for validity...The motors work fine on a DC Power Supply if the timing is correct.
                          Your a waste of time for me! You never listen or pay attention to anything.
                          Midaz
                          It seems like Raul/UFO is wasting his time telling YOU the same thing, over and over ....
                          To avoid the conversation about torque, RPMs and voltage drop with the Singular Coils = A1Mogen -vs- pair coils
                          • Weak Legs
                            Hello Bi and everyone.
                            After reading a few of the recent posts I thought I'd add some food for thought. I think It was Bi who mention empty cores. I assume that means an armature leg with now wire around it. I've always had that concern but when I first started designing and winding motors there was a very popular three phase wind used on model airplane motors that was known as the LRK wind and for a number of years it remained popular and was not improved upon until some of the later day motors. the wind had stator legs left unwound between the three phases as below.
                            I'm not siding with anyone here but there are many things that worked about this wind. I myself don't care for it and prefer no overlapping winds as well as no winds around more than one stator / armature leg at a time. With that being said has anyone here ever tested how much magnetism is found on the outer diameter of the your armature when the brushes are energized. I think you might be surprised at how low it is compared to your field magnet. It might also be much lower than what it could be if each leg of the armature was wrapped completely around. If that's what Midas did and kept the same wind as UFO suggests with a multiple leg wind then maybe that's good. As for me, I'm still waiting to see a test including loading that shows an improvement over the OEM. Speed alone means nothing to me. I put my money on the turtle not the rabbit.
                            Good luck everyone
                            J
                            • Originally posted by DadHav View Post
                              Good luck everyone
                              J
                              Sir J
                              Nice to see you around here again!
                              This is what I did with the A1MoGen design. The Singular Coils are the same size as the magnet or a little bigger for higher RPMs.
                              Empty Core = middle slots with no wires of the coils being energized.
                              [VIDEO]https://m.youtube.com/watch?v=0AwYKpdmYa4[/VIDEO]
                              Midaz
                              • Hunting GChilders;-)
                                Re: Post 7605
                                Sampojo
                                [/COLOR][/I][/B]
                                Yes I just look for max rpm no load, min amp draw. No way of controlling torque load consistently in my basement lab. But I don't see a lot more revealed in that. After seeing Garry's numbers, who I believe is a serious researcher, I am looking more at reproducing those numbers myself. After all it would be the mother load of free energy? Tesla's original energy multipliers he had in Wardenclyffe?
                                What has got me intrigued,assuming I did not miss an adjustment, is the question, "Is there a simple reason I did not see the drop-off of amperage in my motor?"
                                One major difference is quad stator vs. dual stator. I may either have to roll out my old radio shack conversions or make my dual stator GM motor tunable. Thats a big job.
                                Or get on to my Baldor 56 frame motors, which are dual stator, completely infinitely tunable.
                                Question for Garry: Just to confirm it appears you moved one notch off the Ufo recommended timing Position?
                                I guess its in his video, just need to rewatch as to whether it is before or after Ufo's recommended Top Dead Center timing mark.
                                Up, Up and Away
