Coral Castle - Ed Leedskalnin
  • #46
    Bryan, can you email this ebook to me?
    I have some problems downloading it from that hosting place. I would be interested to read it, after all Edward Leidskalnin was Latvian and so am I
    If you can, the I will PM you my e-mail address.
    Thank you
    • #47
      yes i can as soon as i get to my home computer. btw, this E-book isnt directly related to Ed, but some of the things that Ed did(in understanding) can be easy to understand with this book.
      you will have to read it to see what im saying.
      • #48
        ok, for the info of the group, i tested a question that i have been asking since i arrived here. Edward
        Leedskalnin of the Coral Castle supposedly used Stainless Steel wire in his generators instead of copper. he claimed that SS when used as an electromagnet had less magnetic resistence that the nature of copper tends to have. he said this eliminated a lot of the drag and "dead" spots in most motors and generators.
        well, i didnt exactly rewire a generator, but i did make a small electro magnet with only a few turns of SS around a screwdriver. the wire was pretty thin at about 32 gauge, and it was bare wire... no coating. i put a slight insulation on the screwdriver to avoid shorting and i also spaced my wire turns about 3/16" apart, to also avoid shorting. i only wrapped about ten turns on it and hooked it up to a 9v battery. the result was a very strong (relatively speaking) electro magnet. im willing to bet that edward was in fact on to something, and as soon as i can find some coated SS wire, i will rewire a small DC motor and test it further.
        -bryan
        • #49
          ss wire
          Hi Bryan,
          I'm not sure about Ed's comment on ss being less resistant. In Stan Meyer's WFC docs, there is discussion about the SS being more resistant, which may be desired to restrict current moving through the inductor chokes made of ss wire instead of copper.
          The only way to tell is to get equal length of ss and copper of same awg and test ohms and then wrap on core and see what makes a stronger magnet.
          • #50
            im not talking about the resistance in the wire itself... im talking about coppers natural magnetic resistances. because the iron rotor gets temporarily magnetized it has a slight drag effect because of the copper coils. SS does not have this problem because the wire holds its own temporary magnetism as well, which eliminates the drag.
            like i said before, i havnt rewound a generator to test this, i have just finished step one: making sure SS can be used in an electro magnet.
            coppers magnetic resistances can be tested by using a STRONG neo magnet and dropping it through a copper tube. the magnets rate of descent is noticably slower. Denis Lee showed me that during a live demonstration in Chicago.
            • #51
              Hmm, I would like to try this out on the SSG motor. The RPM should increase if instead of copper coil I use stainless steel wire. The only problem is to get the stainless steel wire exactly as thick as the copper one and the insulation. Maybe someone has an idea about how to insulate the stainless wire? Some warnishing perhaps? However I think that warnisg would not be too good, as ir would break if the wire is bent. Any other ideas?
              Also I made a test with a strong neo magnet, I moved it near a copper plate and could feel the drag, then I did the same witha a stainless steel plate - no drag there
              This is interesting,
              thanks Bryan
              • #52
                no problem, this has been an issue ive been wanting to research for about 3 years now. i finally have resources to test it out. except the same issue you brought up... how to coat the SS without the coating breaking off.
                i think that any polyuerethane would work, as it is a plastic/petroleum base, it should be flexible. to coat the wire, you would have to set up two posts in a backyard or something. you could clamp one end, then keep wrapping it around the posts until you have the desired length. if your backyard is 100' or 50' would probably make it easier. simple wood pegs in the posts should keep the strands seperate, and then you just run down the wire with a soaked sponge, squeezed around the wire. multiple coats would be the only way to ensure no shorted spots exist.
                • #53
                  Why not just buy pre-made SS magnet wire, or what about aluminum magnet wire? Messing with chemicals and coatings should not be the focus and in this day and age we surely do not need to make our own wire?
                  • #54
                    is there pre-made SS magnet wire??? ive never seen it, ill search again
                    • #55
                      Aluminum has the same drag as copper, maybe a little tinny bit less. That is why aluminum wire is not suitable.
                      • #56
                        There's gotta be a place that has it. If not maybe we can find some manufacturer who will run a custom drum for us. We could try to gather enough people interested in this, but first is it proven that SS magnet wire is absolutely the best choice for this application?
                        • #57
                          sounds like a plan, but that means we still have to coat some of our own to run the innitial tests.
                          since i have an EIN number, i will contact some of these wholesallers and other businesses to inquire about custom coatings. i will simply state that it will be used in a high strength, but aesthetic application, and standard teflon coatings are not desirable. (i dont want to get into motor/coil arguments with the "experts")
                          -bryan
                          • #58
                            My hometown has TWO cable factories and they make anything and everything, from raw materials. If I was there I could've probably get a small run of my own batch at no cost because they would piggy-back it onto some other larger run. Heck, I could probably get pre-wound multi-filar magnet wire of my choice...just one catch: all that is on the other side of the World...
                            • #59
                              Sea Salt Top Load
                              here it is, the Sea Salt top loading procedure. for the record, this procedure was invented, thoroughly tested, and otherwise researched by John Lord of Lord Enterprises ltd. and also Sea CLearly inc. This info can be shared with freinds and family, but copying/selling is strictly forbidden.
                              Warning: this procedure is done at your own risk. Nothing in this procedure is meant to replace or eliminate any medicines or advice from your doctor.
                              This is a 24 hour Sea Salt cleanse/flush. If you are unable to stay awake for 24 hours, you may take SHORT catnaps at 20 - 30 minute intervals. 24 hours means 24 HOURS straight... NOT 10, and then stop for a day and then 14 hours more. If you stop at any time, you run the risk of stomach cramps.
                              I personally did this flush multiple times and i must say FOLLOW the PROCEDURES. My first Top Load i deviated a little, and resulted in severe stomach cramps.
                              At least three days prior to this TOp Load procedure, avoid all heavy sulfur containing foods like eggs, brocolii, beans of all kinds, garlic and onions. Trust me, this is for your own good!! If you know how these can make a person has gas, times that by 100 with this procedure!!!
                              Everyones needs/toxicity levels/body sizes etc are ALL different, so please PAY attention to this next part. Your TONGUE knows the precise amount of SSE (Sea SAlt ELectrolytes) that your body needs. Ever wonder why you have those salt cravings even though the doctors say salt is bad? that is because your tongue doesnt know the difference between pure Sodium Chloride and Sea Salt.(your stomach sure does) When you have those cravings, it actually means your body is depeleted of its colloidal minerals and salts (the sea kind).
                              The reason i am being so thorough about this is because of the SSE to water ratio. There is no exact formula that neatly fits all body types, male/female, toxin differences, heavy metal differences, diseases, age, etc.
                              For ME, that comes out to be about Four TABLESPOONS per gallon of water, or Two tablespoons per liter (approx). Now this can even change, as it does for me. This happens as your body senses that it has enough, and tells your tongue to desire a lesser amount (or greater if you need more)
                              This Top Load will consist of about two gallons of water, equally spaced throughout the 24 hours. this comes out to be about 2 ounces every 10 minutes.( 1/4 cup)
                              Each of these 2 gallons must consist of either Reverse Osmosis water (R/O) or distilled water, with R/O being the better. What i did was buy distilled from walmart for about 50 cents per gallon.
                              To mix, start out by putting TWO TABLESPOONS into each gallon. i use De souza, but the only other alternative that we recommend is Celtic. IF you use Celtic, you must filter out the silicates after you mix it with a coffee filter. Shake until disolved and then taste it. If it is bitter to you, add another TABLESPOON and repeat the shake/taste. You want the mixture to taste GOOD according to your tastebuds. NOT BRINE, NOT BLAND... just right. Should have a lip smacking flavor like a good potatoe chip.
                              Now simply drink your TWO ounces every ten minutes, for 24 hours. If you must sleep, sleep for 20 minutes and drink 4 ounces afterwards.
                              THIS IS NOT A FOOD FAST: if you are hungry, you are allowed to eat LIGHT meals of simple salad, yogurt, boiled chiken, etc.
                              Also, if you need to drink fresh water, DO IT! If you are thirsty, that is your body saying "i need some fresh water"... drink as much as you need.
                              After the first hour of drinking, you will probably have one of the biggest sh!@ in your life. By the middle of the fast you will be squirting brown liquid about every 10, 20, 30 minutes... this is normal. i STRONGLY RECOMMEND using moist rags or something damp and smooth, you will get very sore if you use straight toilet paper. occasionally you will see gooey/lumpy grey bubble gum looking substances... this is sludge that has been lodged in your intestines for years. you may also notice dead worms, bugs, molds, fungus (stringy substances) weird colors... this is also normal. these are the things you dont want in your body.
                              by the end of the Top loading, your bathroom trips should result in relatively clear fluid from BOTH orifices.
                              When you are done Top loading, and you are pretty confident that your bathroom trips are over, you MUST REPLACE YOUR PRO-BIOTICS/ENZYMES. do this with yogurt or kifir.
                              then SLEEEEEP!
                              all days after this cleanse, drink daily amounts of SSE/water to TASTE, as your body desires it. some days you may not desire it... then sprinkle it on some food. other days you may need a lot, especially before and after workouts... drink as much as you need. i drink about 4 ounces per day, plus tons in my food. but my 4 ounces has about one tablespoon in it. i have worked up to this level over a three year period. i could probably survive on ocean water if i was ever stranded.
                              good luck
                              -bryan
                              • #60
                                Bryan,
                                that's brilliant, I guess I should book a long weekend and test this out, but first I need to get me some of the sea salt.
                                I could probably get my g/f to go through this with me, as a collective effort. Moreover she would probably be the one to drive the effort since I'd probably chicken out before we get to it
                                Thanks!!
