Hi Ken,
Yeap I use 3/8inch carbon gouging rods for my electrodes on the bellerian device given their high melting point. I also have tungsten rods that can be used as electrodes as well, and if the idea is that one matter versus another matter has more energy to give up when stimulated, I think that idea is false.
Now if the electrode is like a 1b22 tube that has radium doping on its electrodes in a vacuum, that one might provide some means of a better output at a lower input but this "gain" would be the result of the radiation on the electrodes sorta pre-doping the space in the gap so that it takes Less energy to break down that radiated vacuum gap.
For there to be a gain, a coil would need to be in series on the lead going to the electrode so that the discharge would result in mutliple oscillations on that coil which then could be converted to dc via diodes and collected in a capacity.
The idea of stinging rays resulting from switch Closure implies that the big wire network spread out over Acres and acres of land as the Distribution Grid has some complex inductive/capacitive properties... and since the wires are coherent as wires due the ambient state of their compressed energy into the form of the element we know it as, when that monster grid gets connected to a volt source that then forces the grids ambient wires into dephased energy oscillations from the source, that sudden reordering is likely what produced that energy event where the switch was making contact... as that would be the "localized" point where some huge power on local output leads makes contact with some huge strung out wires of the grid which were sitting at ambient over pretty big distances... (implying multiple different non-zero potentials having an gestalt of a zero potential until an externally applied potential forces order.)
So I guess I'm not sure what getting those stinging rays would prove or disprove. (and I'm not sure one could get them without having some big spread out grid of wires that then get attached to a high energy source to order them... )
Actually theres one other idea that comes from the recent reading on masers... If one was to fire a driving frequency that meshed at some multiple of the spectra emitted by the target electrodes, that *might* produce some gain... in masers the idea was to use a crystal matrix, in the context run thru it was ruby with .05% chromium ion doping in it... The input was fired into it from the side and that rf energy input would push the ruby lattice to higher metastable energy levels... once that state was reached a trigger signal would come in axially sharing the same frequency as the chromium ions and that orthagonal entry would cause the totality of amplified energy states within the rest of the ruby lattice to emit the same waveform as the trigger pulse, but in a sort of Batch discharge where all the waves from the rest of the lattice are of the SAME form in a sort of lamellar discharge... which ends up being seen as a coherent directional discharge of focused energy of specific waveform... So that idea might be applied to electrodes that are doped presuming one has a spectrum analyzer and can pick apart the best freq's to apply.
Beyond that I'm not real sure how one would go about replicating such.
Hope thats helpful tho.
Take care!
Gene
Take care!
Gene
Originally posted by kenssurplus
