Tesla Radiant Energy ?
  • Tesla Radiant Energy ?
    Does anyone can explain me how to build this, and what materials and parts i need, and are there someone was building this before ? ! And did you maybe know something about Tesla Black Box, i just cant understand how is possible to drive a car in 1931 with 120 kmph, and 80 horse powers el .motor, with using radiant energy ? or what, still big mistery, America fuuck us all !
    One way is to look at peoples experiments on YouTube. One guy, INVENTOR3 is worth looking up, as he has 24 progress videos as a series with what he did.
    Here's the Playlist he has that allows you to choose any or all of them: Free Energy From Air Circuit - YouTube
    The basics though are easy enough to comprehend and build. What Tesla is showing, is a way to put a metal plate high up and a deep Grounding rod at the bottom. A capacitor goes in the middle and that's from where you draw the energy.
    There is a potential difference, a voltage/current, that increases between the ground you walk on and the sky. It's how to effectively get as high up as you can that is where most people focus.
    You have to watch for lightning storms with a good system and have either a way to disconnect the system or fit a lightning arrester.
    There are a number of other ways of obtaining radiant energy, or to put it another way, free energy from something put in the back garden.
    My own forays have included a horizontal collector, mounted on a fence. I turned the usual vertical system sideways, because we have so many storms here in Oklahoma: Radiant Energy Collector - Low Height - YouTube
    Then, perhaps included, ways to extract energy from bits of metal stuck in the ground. Recently i've found that regular security fencing and copper from the middle of coax cable produces ~0.7V at 300uA with modest lengths of about 1ft into the ground. Am working on scaling that up.
    Fencing Earth Light - YouTube
      Can we got with this system high voltage ? !
        Yes, quite easily, but not the current without a lot of work.
        For high voltage it depends on how high and to drive what.
        With 20mA of current and about 3V, you can drive a Slayer Exciter type of solid state Tesla tower. Out of that will be at least mains voltage, able to light a neon bulb, small fluorescent tube etc. Either wireless power or with fixed leads are possible doing it that way.
          Slider, and All:
          A single little garden light -solar cell- can output 2 to 4 volts, and about 30 mAs.
          So, I connected 6 of those discarded garden light -solar cells- together and got about 12+volts. But with just the same amount of current, about 30mA.
          I then connected my Exciter to the solar cells. This was without adding my 12 volt 4.5 ah battery to that set up, just yet. Only a straight connection from the 6 solar cells to the Exciter circuit. As I'm still having slight heating problems when using a 12v battery as the source, going to the my oscillator circuit, which at least would need a heat-sink on the small 2n2222 transistor, if I leave it on and running for a long while.
          This Solar Exciter circuit works, even on 10 volts and only 2mAs obtained even just from the light of a lit 13w CFL bulb indoors. As this light is being picked up by the little solar cells that are placed below the CFL's light.
          I can see that the exciter circuit likes to have some current, also. I'll have to add a variable resistor to the base for 12 volts use, and above, but it runs fine up to 10 volts input, and lower mA, as is.
          I think that I can call this the world's second smallest Exciter, as it's only the size of a finger nail, but needs TWO L3 coils to run, won't work on just one.
          I'll upload some pictures or a video, when I get it all together.
            That would be good to see
            I use such solar cells a lot too and have 5 in a bar to rapidly charge AA's, 2hrs in full sun. Though mine only deliver half your numbers and the construction is different (bad workmanship) on each one.
            I have another permanently glued to a rechargeable AA, with germanium diode from the panel to stop backflow...just so it's always charged and ready. The battery sits behind the top edge of the panel, to give it a bit of an angle for the sun.
            Exciters will deliver high voltage and, depending on use, work great. My present project is to do just that - using the fencing pieces outside in the yard. Build up enough current and voltage to power a small tower setup, then light wirelessly or over 1 wire.
            A toroid 'Jenna's Light' type of circuit is another route for efficient lighting from low input.
            Regarding small L3's (the final output coil, for those not familiar with Dr. Stiffler's terminology), i've found that the actual final one is the main parameter. You can chain up a few L3's and they'll work, but, swap them around to have another on the end and the whole thing might not fire up.
              Last night I was up to all hours again, and I finally got my thumbnail sized Exciter circuit going real strong, and to light the CFLs bulbs now, WOW!!!.
              So, another step in the right direction.
              My Exciter uses a "trigger coil" wound on 1/2" cfl toroid, a 2n2222 , 1meg resistor, and 1n4148 diode. Adding another diode on the negative rail of the battery helps to keep the circuit running warm, but not too hot.
              I have a bunch of bad CFLs laying around just waiting for this circuit, but, I'm also going to buy a Black Light (24" florescent bulb), to connect up to the L3 coils This is all too neat... but, ones has to have the proper "toys".
              I'm still working on getting the 6 solar cells to charge the 12 volt battery, then use that battery to light the CFLs through the Exciter.
              I wanted to use the full 12 volts the fully charged battery has in it, to get the new exciter circuit up and running, as best as I can. So, far, so good...the tiny exciter circuit has been working great, and anything that is metal, or liquid all around it, will light the Av plugs. Real Bright! I'll also make a set of activated Carbon/Aluminum cells to power this circuit, later. Main thing was to get the thing fired up and going strong.
              Playing with that kind of static electricity, is something else...
              As you become the part of the circuit. So, it's difficult to tune the device, when ones body is affecting everything. Anyways, I'm slowly getting there,
              while still dreaming of the "Big Tower", though. The one that will blow your hats off.
              Dr. Stiffler always mentioned: having to learn to walk before you can run...
              But, my imagination runs wild...
              NickZ
                Here is a quick quote from this web site here - Tesla's Electric Car
                "Nikola Tesla had an Electric Pierce Arrow back in 1930, the ICE engine was replaced with an Electric Motor. The power source was a black box of radio tubes, in the glove compartment. The box had an antenna sticking out. Tesla would fool with some tuners and tune in the right frequency and got 240 volts delivered through the air to his car. The car ran almost silent. He had the car stashed in a barn near Niagara Falls. He was sending the energy from the Power Plant, some how. He said this power could be made possible for everyone. J.P. Morgan did not like the idea, because where do you put the meter? Morgan stopped funding and Tesla's Wardencliffe Tower was destroyed & taken down. Tesla sent a particle beam to the stratosphere and down to Siberia. soon after he leveled an estimated 60 million trees over 2,150 square kilometers, felling them radial outward from the blast center in Tunguska, Siberia, Russia in June of 1908. The tower would have made war obsolete. We were denied this FREE power and NO MORE WAR machine. We were denied the privilege, instead we get wars over false flag operations with so called pilot terrorists with no weapons of MD. Now we pay for gas & get to breath un-natural SMOG from burning dirty hydro-carbons along with 13 bad to breathe chemicals, know to cause cancer. We could be driving our cars with water as the gas, and steam in the tail pipes"
                Also seems Thomas Henry Morray mastered this device.
                Thomas Henry Moray: The Sea of Energy ~ Excerpts of technical factoids & illustrations of the Moray Radiant Energy Receiver
                "During the Christmas Holidays of 1911, I began to fully realize that the energy I was working with was not of a static nature, but of an oscillating nature. Further I realized that the energy was not coming out of the earth, but instead was coming to the earth from some outside source. These electrical oscillations in the form of waves were not simple oscillations, but were surgings --- like the waves of the sea --- coming to the earth continually, more in the daytime than at night, but always coming in vibrations from the reservoir of colossal energy out there in space.
                [p. 111 ] The device was housed in a wooden box something like 12" by 18", with an antenna and a ground going into it. Wires leading out of the box led to a bank of some forty 100-watt light globes and to an electric iron. My uncle touched a switch at the top of the box with a hand electrostatic plate and the globes all lighted brilliantly. We all noted that the bulbs burned cold except each had a hot spot about the size of a dime on the top slightly off center. I also recall that I could turn the lights on and off by approaching and retreating to and from the device, either with my whole body or my hand. If my memory is clear, the machine had to be tuned with a dial to be placed in this condition. [Chester M. Todd, March 19, 1971]
                Also he had an affidavit filed on his website here http://thmoray.org/images/affidavit.pdf
                The bold part reminds me a lot of Dr. Stiffler and the Tesla Coil circuits. Seems like the Tesla car was powered by his Tesla Coil or Magnifier from Niagara Falls and Morray tapped into the Radiant energy just like a receiver for the Cosmo Radio Station. Anyways just my two cents, thanks for reading.
