PSI Wheel
  • PSI Wheel
    thought that the PSI wheel would have been mentioned however I did a search but could not find anything. Basically the PSI wheel is anything that can freely rotate and is very light weight. Most people use there hands and place them in the vacinity of the wheel. Because of this the skeptics say that the rotation is due to heat. When I first got the wheel I was about as skeptic as most however upon removing it from the box and placing my hands near it I had no problem moving it. To prove to myself that it wasnt heat I sat on the other side of the room and there was no difficulty in moving the wheel. In fact I have not difficulty moving multiple wheels from across the room.
    By introducing greater dynamics into the room where the wheel is by placing the wheel in a corner of the room and turning the roof fan on at low speed it makes it very easy to stop, start, and change rotation direction of the wheel. I placed the wheel in the corner so that it would be exposed to a more complex environment.
    Able to rotate wheel while covered
    Up until today i was never able to get the psi wheel to rotate while covered. However today i got it out for the first time in a long time. I had to search myself for the mind state required and started practice. Things were going so well i thought what the hell i will do it covered over by a plastic container and the wheel did not stop one bit. After a bit of practice i can now rotate the wheel just as fast covered as when uncovered.
    So if there is anyone in my area who want to do a test i am fine with it. I say this now because i always new that the establishment would never be happy unless they could cover the wheel.
    Damian
    Brisbane, Australia
      Disregaurd covered wheel
      Well sadly i am inclind to disregaurd last nights results as i have been un able to repeat them today. I would say that i must have overlooked something in the setup
      Damian
        Egely Wheel Meter?
        Are you talking about the Egely Wheel?
          Edgely wheel
          Yeah the Egely wheel. I have been doing some reading and it would seem the rotating is due the torsion fields. How the mind is able to control that i am nto sure.
          As well in the same book which i read about the torsion waves which is in the book the divine cosmos after the discussion of torsion waves the discusion then goes onto torsion bubles and how each bubble bumbs the next . How he describes it is ecatly how it is for me. The sruff i talk about in my other post is torsion bubble movement.
            Rather expensive this Elegy wheel...
              Egely Wheel
              I've had one for quite a while and they're very interesting. It really seems to respond to intention. I can speed it to the max then make it stop dead and reverse direction.
              These 2 docs go into some of the research:
              Energetic Science Ministries™ | Resource Library
                Intention
                Yeah it definitly does respond to intention. I can rotate from across the room. As long as there is any part of my body in the room then i can spin it.As soon as it becomes covered the strategy for moving it seems to change which is inline with the research on torsion fields. I can also have multiple wheels in the room and cause them all to rotate.
                Have you been able to bend metal with your mind? I havnt as yet and i know its my concious that is stopping me from doing so. I think i need to attend a metal bending or levitation party to intiate my concious mind into the posibility.
                Yeah egely wheel is expensive which is a shame, but i am glad i bought it.
                  I can make psi wheels spin as well. it is nice to see some dialog about it, as many know you cant have a discussion with people about something they dont even think is possible.
                  Ive had the ability for about 2 years, in that time it has gotten alittle stronger, but more importantly it has expanded into other branches of telekinesis.
                  I've done several experiments. I setup a camera to record a psi wheel that i had been moving, to see what would happen as i left. I placed it in view and left the room, i went upstairs and actually started watching TV for several minutes. To my amazement when i reviewed the recordings, the paper was still spining the entire time...However this ability exists, it truly is magical.
                  I personally would suggest to people practicing and trying to make your ability stronger be very careful...I feel alittle crazy opening up about this.. but my ability is no longer selective to solid objects...whenever i focus (as in reading physics books or programming software) my computer screen will Literally..flicker...the lights around me wherever i am will also flicker.
                  I truly have no control over it, i feel as though ive opened a door that now cannot be shut, and that is very scary. (sorry for the long post)
                    Hi Nadda
                    I play around with it allot just seeing what is possible. Some things i like to do are to cover the wheel with a plastic container to stop air flow and allows you to breath without disturbing the wheel.
                    I also like to setup 5 or 6 wheels all at once and get them rotating which is fun. There seems to be no limit to how many you can spin. It is not so much an act of energy on your part more clarity and direct intention.
                    For the wheel under the container use aluminum foil as it is allot easier to move at first.
                      How good are you guys with control? I can get the wheel to reverse direction but only for as long as i focus on the direction i want (and even then its tough). when i dont focus on a direction it'll just go by itself, randomly back and forth.
                      Does anyone use theyre hands? I never could, for me it seems to react purely to my mind.
                        looking away
                        Hi Nadda,
                        I can do both but this is what I've noticed...
                        Sometimes when I focused on what I wanted it to do, it didn't do it until I broke my concentration...then it spontaneously did it.
                        I posted about this concept in my belief on spoon bending:
                        "The formative energy template that the physical structure of the metal conforms to in this reality can of course be altered. When focusing the intention on a piece of metal to bend in a certain place, there is more than enough energy to get the atomic energies fluxing back into a state of probability but the change won’t be apparent until the awareness has been taken off of the metal. As soon as the awareness is taken off, the “latching on” to what was is gone and the intention that overpotentialized the metal in the place to bend finally reorganizes the template so the energies that are in the probability flux can conform to the new template. This is why the bending takes place often as soon as the person looks away."
                        I know that can sound like a bunch of mumbo jumbo but I at least know what I mean and hope others do too! lol
                        Rin posted today about some PATHS modules that seem to kick in AFTER getting off them and switching to something else. I noticed the same thing and thought it could be the concept of to get to 2nd base you have to take your foot off of 1st. Or to have a seed sprout, you plant it and have to let it go.
                        Anyway, particle/wave concepts is what I believe this falls under. When we have our attention and focus on something, we maintain it as it is even if we are intending something else. When looking away or thinking something else spontaneously, something happens but after we stopped thinking about it.
                        Paul Dong, a qigong master, mentioned in his book China's Super Psychics that there is something called "unobservable flight". From what I can recall, in pk (psycho kinetic - moving things with the mind) is that when there are observers, there is an intention that maintains things as they are, when looking away and "noticing" in the corner of any eye that somthing zing by...the object in question...that it was no longer held in it's "particle" state but rather looking away allowed the planted intention to manifest once the foot was taken off of first so it could go to second.
                        I have notice the EXACT specific concept occuring when I am deeply aware of a few people in my daily life. I do things in my mind intentionally MANY times a day to see if there is a response or reaction. What I do is intend a certain concept for them to think about. I may say something but not mention what I was intending or thinking. I then think of something totally different or focus on something else and then they say it!
                        When they do say it, this is what I notice. I am not looking away or focusing on something else with the thought in the back of mind (holding something in collapsed particle state), I actually look away or think about something else and authentically detach totally from what I was intending...it is THOSE moments that the other person will say something relating to what I was originally intending.
                        Anyway, just some observations and thoughts...but enough to see that it is CONSISTENT. Interesting topic!
                          p.s. The "formative energy template" is a concept I developed on my own and later found that some biologists and others have the same belief with different vocabulary attached to it like morphic fields, etc... that is the concept that I am communicating anyway.
                          • #14
                            Nice
                            I have noticed pretty much the same. When you think rotate to the right it is not possible to jump straight to rotate the left. Instead you have to switch to neutral.
                            You could say that the plastic mind create the formative pattern of a wheel that rotates and impresses it on the physical wheel and does so by not paying attention to what is happening in case the concious mind creates a formative pattern to uppoise the spinning one. This offten shows itself as a wobbling on the wheel. It is being rotated in both directions one by the concious mind and the other by ther other mind. Thre result being a wheel that warbles on the spot. It would seem that the concious mind and the cuncious mind can be in different time placess and the unconcious mind can create an event before a cause.
                            • #15
                              Got my wheel today I bought the cheaper one with no LED lights and RPM measurements. I think that if you want the results to be accurate, you need to train with the wheel under a plastic or glass container, because it is affected by even smallest air movement that you create when you breathe. A fun little device
