hi! :-)
  • hi! :-)
    hi,i just registered with pathways and had a few questions.after registering etc..my program was available immediately.i thought i would be asked a list of detailed questions to tailor make a program for me?is this normal?also how often do i use it and how often do i change modules.also only one earphone on my pc works,will this affect the program?do i need to get a new soundcard?sorry for the trivial nature of my questions but i really can;t seem to find this info on the website.
    Hi Marty
    Welcome to the party!
    Until one of the PATHS staff chimes in I will give you the best answers I can.
    You should definitely watch your theater program after you get an e-mail from [email protected] bc I have seen another post with this question and they probably do need to do some more to your module before it is ready.
    Are you on the platinum module? If so, I don't have personal experience with it but it is defintely tailored to what you desire.
    I would recommend to watch it about 3 times a week. You can watch it more often if you want and at minimum should watch it once a week.
    As far as changing modules you are allowed to swap up to once a month. However, in the beggining the staff will work more closely with you to obtain your desired results. So if it turns out for example the weight loss one would be better than the ultimate body for you, they will probably switch it for you.
    There is a stereo component to to modules. It would be best if you can plug some earphones into your computer and use them while you watch your theater presentation.
    If a sound card is necessary to get the stereo to work on your computer I would recommend it. However I beleive you can instead view the theater twice in a row for every time you would normally view it. I believe that is the recommendation for people with hearing impairments.
    Feel free to contact the staff direclty at the e-mail address above if you want to reach them before they see this
    Keep your mind on the aether www.PathsToSucceed.com
      thanks pather.i sent them an email as well.. much appreciated.
        hi again,everybody! wonderful corner of the earth here btw. :-)
        i was just wondering had anyone any experience of the antioxidant module.is it likely that your body would go into a cleanse after starting it and is it suitable for someone in their 20;s?
          custom adjustment
          Hi Marty,
          In the next business day or so, someone will go in and work on your module.
            Answer to your question Marty
            Hi Marty,
            Here is a detailed answer to your question about how the Theaters are set up. Just click the link below
            Regarding the antioxidant mod....I use the antioxidant one month, and the goji the next...alternating between the two every month.
            Figure an ounce of prevention...
            Both of them are good for balancing your PH, oxegenating your cells, etc. It definitely has cleansing properties, but you are already going to be experiencing that with the spirulina you are taking.
            It is suitable for all ages, even kids!
            Have fun!
            Kevin
            PATHS For Healing
            Energetic Science Ministries
            Meditation at the Click of a Button, Guaranteed!
            ESM Forum Support Link
              cheers guys.
