Can PATHS Help With PH Balance?
  • Can PATHS Help With PH Balance?
    I've been reading more and more about how we should be slightly alkaline for optimum health but that many Western adults are too acidic.
    This can cause lots of problems like calcium being slowly broken down in your bones.
    In postmenopausal women, the oral administration of potassium bicarbonate at a dose sufficient to neutralize endogenous acid improves calcium and phosphorus balance, reduces bone resorption, and increases the rate of bone formation, (N Engl J Med 1994; 330:1776-81.)
    Improved Mineral Balance and Skeletal Metabolism
    Normal adult humans eating typical American diets characteristically have chronic, low-grade metabolic acidosis (l-4). That persisting perturbation of systemic acid-base equilibrium occurs because metabolism of the diet releases noncarbonic acids into the systemic circulation (eg. sulfuric acid from metabolism of protein) in amounts that exceed the amounts of base released concomitantly (eg. bicarbonate from combustion of organic acid salts of potassium in vegetable foods) (5, 6). The size of the discrepancy between acid and base production determines the net endogenous acid production rate (ie, the net acid load of the diet), which in turn determines the degree of perturbation of systemic acid-base equilibrium (1, 2, 4). Under normal physiologic circumstances, the net endogenous acid production rate and the degree of the attendant low-grade metabolic acidosis are determined primarily by the composition of the diet (2, 4).
    With advancing age, the severity of diet-dependent acidosis increases independently of diet (3, 4). That occurs because kidney function ordinarily declines substantially with age, resulting in a condition similar to that of chronic renal insufficiency (7). Renal insufficiency induces metabolic acidosis by reducing conservation of filtered bicarbonate and excretion of acid."
    Estimation of net endogenous noncarbonic acid production in humans
    The IMVA (International Medical Veritas Association) recommends alkaline foods and sodium bicarbonate so that the pH of the blood remains high, which in turn means that the blood is capable of carrying more oxygen. This in turn keeps every cell in the body at peak efficiency and helps the cell eliminate waste products. Detoxification and chelation will proceed more easily and safely under slightly alkaline conditions. Increased urinary pH reduces oxidative injury in the kidney so it behooves us to work clinically with bicarbonate.
    Stop Cancer with Baking Soda - - Maya's Mom
    Is there an existing PATHS module that regulates PH?
    If not, is this a possible application for PATHS?
    Jessica
    Keep your mind on the aether www.PathsToSucceed.com
    I see the cellular health one says it :
    Increase blood alkalinity
    So I guess that would be the same thing?
    Jessica
      Thanks PATHS. I just got your e-mail regarding the cellular health module :
      We have boosted the instructions regarding alkalinity and PH balance.
      Now that I think about it, I probably started focusing on this issue in the first place so much recently because I'm on that module
      Jessica
        I need time and a little more info but I hope to make another youtube at some point on health, and this time about alkalinity.
        I know dr.s give baking soda / sodium bicarbonate to people as a prescription for certain kidney issues.
        I know athletes take it after a strenuous workout as I understand it oxygenates muscles and blood as well as helps remove toxins.
        I've seen testimony from people now who take a bit of it daily.
        I welcome any other info / input people want to give.
        Right now from my research so far plus some experimenting I've been doing on myself, I would offer that a good way to take it would be in apple juice (honey added optional).
        Then a bit after, take a bit (about 4oz per teaspoon of baking soda) of distilled water.
        I'm still trying to find out if that takes the sodium back out, or toxins, or both but apparently this method has done wonders for many, and I am doing quite well with it.
        I could almost compete with Kevin's news from his dr., but I have to re-do my lab work.
        After going through a significant amount of baking soda, my dr. said my blood and urine tests were normal except that my bad cholesterol dropped from 217 to 134 (!!!!!) and he thinks it must be a lab anomaly LOL.
        Jessica
          hey Jessica,
          excellent topic ...
          I read somewhere like a week back about Spirulina and how it alkalizes the body so it automatically becomes immune to serious sickness ..
          will dig into it and post it here when i find it ..
          Love,
          www.paths4everyone.com
            Baking soda
            Jessica,
            Wow, that cholesteral change is amazing. Do you attribute it to the baking soda or are there other things you've been doing as well? How long have you been using the baking soda.
            Thanks for sharing,
            Bobi
              Lama,
              Sounds great, any info you find is welcome
              Bobi,
              Yes I do attribute it much or all to the baking soda because of how I feel on it. I had been eliminating some issues through chiropractic, but as this happened the others became more noticeable.
              So now the baking soda seems to have pretty much taken care of the remaining issues
              I started taking it maybe 3 weeks ago or so. At first just randomly but a good amount as it felt good.
              After that I went to three times a day and now I am doing it two times a day.
              I think I will end up doing it one time a day. I've just been doing what felt right. Once I did some of the research and heard the testimonies it started really making sense as far as my issues.
              I do want to retest with the dr. soon to know the results, but I'm also thinking of waiting a little bit longer. I think it will be even more reassuring if I've been on the baking soda a month or maybe two and then get good results.
              XO Jessica
                Excellent Jessica!!!!
                JESSICA!!!!
                Excellente! I've heard about the alkaline mode is the way to go, cancer doesn't like that enviroment or Arm & Hammer... It was exciting watching that informative video clip by ah, Doug Kaufman? (great name, huh?) (but more like that store in Pittsburgh)
                The info on "it" being a fungus is even crazier, wow - good stuff! I just chomped a Tums, but the baking soda is the way to go. I read the long link about baking soda and it's amazing all the benefits it brings. Lotza reading for me, whew!
                Wow
                Doug
                With AMEGA You can change your life in minutes...
                Hear how here: Live the Energized Life
                  I'm so glad to have found the info too
                  I gave new samples to my dr. yesterday. After checking out the urine he decided the first tests were valid. I guess he didn't have any reason to doubt the first blood test results after all.
                  I made some youtubes about Ph and will also post one by someone else on the same subject:
                  YouTube - Health and Ph Balance #1
                  YouTube - Health and Ph Balance #2
                  YouTube - An amazing health discovery
                  XO Jessica
                    Great Info Jessica!!!
                    Kevin
                    PATHS For Healing
                    Energetic Science Ministries
                    Meditation at the Click of a Button, Guaranteed!
                    ESM Forum Support Link
                      For me it's very blatant that the baking soda + apple and then distilled water is helping
                      About 8 years ago I went to the dr. with stomach issues. They checked me out and said I didn't have an ulcer, but gave me prescription strength Tagament (sp?). This made my digestive system stop. I threw it out and got ginger and something else (I forget now) from Whole Foods that made me regular again.
                      From that time on I did not ask the dr. anymore about my stomach. I modified my lifestyle, not eating much before rushing out the door in the morning (often taking food with me) and not eating acidic foods when traveling.
                      Now the dr. tells me they have better prescriptions for acid reflux, and I notice a lot of people are on them.
                      But I also recently saw that there is now an epidemic of cancer of the esophagus due to acid reflux issues.
                      I am glad I never went the prescription route.
                      It's interesting too that some sources say fat is the body's way of protecting against acid I have definitely dropped weight since taking the baking soda, which I think many would find odd as it would seem we get enough sodium.
                      The other thing is I've been adding a tiny bit of baking soda and apple juice to my cat's wet food and leaving a bowl with a tiny bit of distilled water (I take away her regular water bowl for a bit if she does not drink it).
                      She is 11 years old and had been getting less active. But now I hear her racing around in the middle of the night like she used to do
                      Jessica
                        Hi Jessica,
                        With your intake of the baking soda, apple and distilled water...is your acid reflux completely gone?
                        Quite a few years ago I used to take pepcid for that. When I cut out most of the simple carbs from my diet, the acid reflux disappeared.
                        Kevin
                        PATHS For Healing
                          Kevin,
                          I still feel acidic, something in my digestion but I don't get a lot of heartburn.
                          More just a constant feeling of sensitivity and like I don't enjoy hot food.
                          My feeling is that I need to get my Ph right and then things will be fine. Also I feel this will take some time.
                          Your suggestion about carbs is probably a great one.
                          I don't overindulge in anything, but I do have a rebellious nature that if I try to restrict myself from something it just makes me want it more.
                          So I think the best path for me over the long run is to add the sodium bicarbonate, rather than try to change the food I take in.
                          I am adding a bit of sodium bicarbonate to my regular water now - to try to get the Ph to 7.5 as recommended by a dr. in one of the youtubes I posted.
                          Also I add lots of milk and honey to coffee I take.
                          I just received some sodium bicarbonate pills I ordered online.
                          I see that they are intended to be dissolved in water but I wanted to just pop them. So I tried that and am just making sure to take in lots of water with them.
                          Anyway they are 650 mg tablets and I find it interesting that the maximum daily allowance for adults up to 60 is . . . 24 tablets (!) (For adults over 60 it is 12 tablets and it is not recommended for children. Although for children imo it seems water with a Ph of 7.5 would be good.)
                          Jessica
                          • #14
                            I just thought I would report that despite taking baking soda (and now the tablets) every single day for at least a month. . .
                            When I woke up today I took a ph reading of my tongue and it was 5.5.
                            According to wikipedia (see color chart on right of page) healthy human saliva should be at 6.5-7.4.
                            pH - Wikipedia, the free encyclopedia
                            So I'm still too acidic after all the alkalizing.
                            I'm not surprised or discouraged, this seems to back up my gut feeling that I have a while to go before my Ph is corrected.
                            Btw I am not affiliated with these products in any way, but it looks like there is a nice filter faucet available to up the Ph in water while filtering out lots of bad stuff :
                            pH Miracle pHaucet pHilters
                            This Dr. also has a lot of good articles (which don't seem to work in Firefox for me, but do work in Explorer). Here's a quote from one that helps me understand why some fruits seem acidic but are actually good to eat :
                            Update: A Common Misconception
                            It is often said that 'acidic' fruits like lemons, limes and grapefruits will
                            acidify the blood and tissues. In fact, the citric, lactic, and other acids in
                            such low sugar fruits - unlike high sugar fruits - exsist primarily in their
                            anionic (basic or electron) form, especially as their Na+ and K+ salts (e.g.,
                            potassium citrate). Following absorption, these anions (bases or electrons) are metabolized to sodium bicarbonate. Thus, lemons, limes and grapefruits
                            alkalinize - not acidify - blood and tissues.
                            pH Miracle Living: Articles
                            XO Jessica
                            • #15
                              heartburn
                              For many people, heartburn is actually from not enough hydrochloric acid production and not too much. If not enough, the food isn't able to break down properly and will cause virtually the same heartburn type symptoms as too much production.
                              There is a simple test anyone can do. You can get a bottle of hcl tablets or capsules and at the same time every day...take 1 with a meal...keep to the same meal...dinner or whatever. If there is a burning sensation from 1 tab/cap then the problem is NOT lack of acid...the 1 tab/cap caused too much and that is why there is burning.
                              If no burning, the next day at the same meal time, take 2 tab/caps. Keep boosting 1 cap at the same meal every time.
                              For example, if it takes 5 caps/tabs until there is a burning sensation, that means there is a serious lack of hcl production in the stomach.
                              In this case, taking an antacid/baking soda, etc... will simply neutralize the little bit of acid that is there causing even more problems.
                              I would recommend not just trying this based on what I mentioned above on this simple hcl test, search around online and see what you can find for different regimens on testing for hcl. Many people are surprised to find that over a long time of taking antacids...the real problem was from a lack of production.
                              Anyway, just a distinction that might help someone out.
