LJ100 | Tongkat Ali | Eurycoma Longifolia - LJ100.com official discussion forum
  • LJ100 | Tongkat Ali | Eurycoma Longifolia - LJ100.com official discussion forum
    Welcome to the LJ100.com official discussion forum. LJ100
    Feel free to post questions, comments or simply engage in conversation about LJ100, Tongkat Ali - Eurycoma Longifolia.
    Below is a little bit about this amazing herb.
    LJ100 (Longjack - Eurycoma longifolia) is the strongest extract of Tongkat Ali currently available to retail. It was developed over 20 years of research isolating the active ingredients in Tongkat Ali and another 2 years developing a the highest technology in safe and effective commercial extraction.
    Proven Effective for Significant Androgen Increase
    Most studies quoted on testosterone boosting effects of Tongkat Ali are actually quoting LJ100 (Longjack - Eurycoma longifolia) results. This is because the research team, led by the scientist Professor Johari Mohd Saad, Ph.d., Dr. Ismail Tambi, and Dr. Azizol Abdul Kadir are at the forefront of Tongkat Ali research and only use the LJ100 (Longjack - Eurycoma longifolia) Extract in their studies.
    What Makes LJ100 (Longjack - Eurycoma longifolia) So Unique?!?
    • Proven Effective for Androgen Increase
    • Standardization of Active Components
    • Gentle on the Liver & Proven Safe
    • Developed by the Top Researchers of Tongkat Ali
    • Company Dedicated to Research
    Building on the traditional water-soluble extraction, the powder uses approximately 100 parts of the highest quality aged root (5-10 years old) to create only 1 part of extract. The extract process will also pull out phenolic components, tannins, high molecular weight polysaccharide, mucopolysacharides, from this fiberous plant.
    Standardization of Active Componants
    LJ100 (Longjack - Eurycoma longifolia) is superior in efficacy and quality. It was created by scientists who have been working on Tongkat ali Research since the early 1980's. For this reason, ONLY LJ100 (Longjack - Eurycoma longifolia) is standardized with 20-22% glycoproteins AND 40% glycosapaneins. The glyco-protein is patented and known to be responsible for the testosterone boost.
    In the extract form, you need significantly less powder per dose and will get a more specific testosterone boosting effect. LJ100 (Longjack - Eurycoma longifolia) dosage is standardized based on pharmacokinetic studies and observations. In human clinical studies, it has been found that a 200mg dose will double serum testosterone levels by 2x increase in 2-3 weeks. There is also a 45+% boost in DHEA levels. Results have been reconfirmed by several independent labs in the United States.
    Proven Safe, Proven to be Gentle on the Liver
    LJ100 is has passed all toxicology tests. Scientists and researchers have confirmed that this extract. This herb is completely safe and non-toxic, even at doses 1,000+ times larger than the recommended suggested dose.
    When extraction is done properly, impurities and non-essential compounds are removed from the herb. This is particularly true of tumors and roots like Tongkat Ali. For this reason, this extract (Longjack) is gentler on the liver than raw powder and even other extracts of Tongkat Ali. Indeed, BEWARE imitation extracts. If extraction is NOT DONE Properly, This herb is highly prone to fungal growth. Such toxicity would be seen via increased activity in the liver.
    This extract (Longjack - Eurycoma longifolia) is the direct result of a project that started in the 1980s to promote one of Malaysia's richest treasures; it's rainforest. The makers of this incredible extract(Longjack - Eurycoma longifolia) works with this original group, known as Forest Research Institute of Malaysia (FRIM) and its original and top researchers.
    Company Dedicated to Research on Tongkat Ali
    This extract (Longjack - Eurycoma longifolia) is truly a complicated gift from Mother Nature. The makers of this extract (Longjack - Eurycoma longifolia) are dedicated to continued studies on this herb. Research is on-going. We are happy to answer your questions on the root.
    For more information, visit LJ100 | Tongkat Ali - Longjack, Eurycoma longifolia
    LJ100.com is an Energetic Forum partner and is using this forum as its official discussion forum.
    LJ100 direct purchase
    Hi everyone,
    I am no longer directly selling LJ100 but you can still get it directly from the
    source by going here: Herbal Powers
      LJ100 | Tongkat Ali
      The links on this website have been updated: LJ100
        Tongkat Ali, LJ100, Eurycoma Longifolia, Longjack
        The website is updated! TONGKAT ALI
          go here for research..
          or
          Tongkat Ali 100% Pure 360 capsules - eBay (item 190430628562 end time Sep-11-10 20:58:34 PDT)
            Indonesiaherbals is a confirmed scam, widely reported in the
            Indonesian media. Just search Google for: dubious tongkatali
            indonesiaherbals
              Tongkat Ali - LJ100
              There may be scams in Indonesia selling bad quality products or
              something but LJ100 is medically documented and I have dealt
              with countless customers over the years with this exact
              extract from tongkat ali. It is anything but a scam. It boosts
              the good but not the bad hormones relating to testosterone.
              It increases ATP, etc... Tongkat Ali
              That is my website and I have worked directly with the importer
              during all that time. LJ100 | Tongkat Ali - Longjack, Eurycoma longifolia is owned by me,
              not the manufacturer.
              You should clarify your claims when posting - you have to qualify
              each point you make.
                How many different LJ100 are there? Is it all produced by Herbal Powers?
                  Tongkat Ali - LJ100
                  There is only one LJ100 and it is all from Herbal Powers. It is the cleanest,
                  purest and most documented tongkat ali product in the world.
                    LJ100 studies and results
                    By the way, most medical studies quoted by non LJ100 tongkat ali
                    products are actually quoting studies that were done with LJ100.
                      So, if there is only one LJ100, are the items sold by Ray Sahelian and Source Naturals also from Herbal Powers? Are the items sold by Ray Sahelian and Source Naturals encapsulated by Herbal Powers?
                        sadsad
                          All LJ100 I have seen is made with stearic acid or magnesium stearate. Stearic acid is produced by cooking up dead cats and dogs at rendering plants. The same kind of source that caused the mad cow disease in Europe. They can eat their LJ100 alone.
                          • #14
                            common sense
                            Yeah, sure it is.
                            Please take your garbage elsewhere. This forum is for people that actually have common sense. Maybe you should go get some and come back when you are ready to join the real world.
