Cause of cancer and prevention?
  • #46
    Yes, I know that an orgone energy device can alkalize water. pH = Voltage, as you know, so irradiating voltage to a liquid you can alter its pH.
    If you understand french you can look in the french literature and you will see that electrical and magnetic fields can alter the biological processes. I have a book that explains very well what happens when you have cancer, and it fully explains that cancer is mainly caused by an electrical disorder.
    Almost any disease is characterized by a lack of alkaline environment, that means that is characterized by a lack of voltage. If you "recharge" that cell, irradiating voltage to it, then the environment will gain electrons and the disease will start to disappear.
    I have read a little bit of all, since irradiating an animal 5 minutes a week, to irradiating 9 hours daily. Depending the time, you can get some different healthy effects.
    "A knot cannot be undone, without knowing the way it was made" Aristotle
    • #47
      I believe that happen because of the effect caused by electricity and magnetism which is not both. I call it orgone energy.
      Not just any polarity. Positive at the left hand and negative at the right hand. This will still work even if we do not touch the electrode because orgone energy will still transfer.
      • #48
        That is true. I remember that I read somewhere that a man irradiated some polarity to the plants and then the plants died in few minutes. If he irradiated the other polarity, then the growing speed of the plants accelerate.
        You say there are Female orgone energy, that it's positivie. Since I haven't read a lot about orgone energy, I know there were 3 kinds of orgone energy? the positive the death and the neutral?
        can you apport more information about these 2 or 3 kinds of orgone energy, what the produce in the biological systems and how you can synthetize each one? I mean, what kind of modifications you need to do to get positive or negative orgone energy.
        • #49
          I never heard neutral orgone. And my definition for polarity of orgone is different from most orgonomist.
          In term of property, based on Karl Reichenbach and Robert Beck:
          male = kill infection, kill virus, boost stamina or power. However overdose lead to headache, stress, nightmare, insanity or serious illness for prolonged overdose.
          female = cell regeneration, resting, calm. No report on overdose effect.
          People who use male orgone generator will feel his energy boosted, feel motivated, has more stamina and very emotional. He sleep less but do not feel tired at all.
          Peopl who use female orgone generator will be calm an at ease. Sleep easier but wake up at sun rise.
          Generation by bipolar = magnet north pole is female, electricity negative is female, crystal base is female, right hand is female.
          For synthetic generation I currently use clock wise copper tube for water, radiant sleeping aid and cemenite.
          • #50
            Thank you very much for the information exposed.
            Maybe I was a little confused about the term "neutral orgone". I have make a google and yes, I have only found positive POR, and negative DOR. I have to say that I have read very little about the orgone.
            I have seen your circuit and it's quite similar to the avramenko plug. But the avramenko only get one kind of orgone energy, aka radiant energy. I don't know if this energy is negative or positive.
            But almost all the literature I have read is about the negative energy in the living organisms. I know ther are more advanced theories, but I only talk of the things I have read.
            As you can see in the picture, a healthy cell is characterized by a negative voltage charge. As you know, biological energies are non-electromagnetic. As far I know, all the positive energies produce bad effects. I think really interesting to know that there are 2 orgone energies, since I though that longitudinal energy was only 1 and it was negative.
            I have also read that there are "pure current" waves, endothermic and exothermic charges, harmonic waves, etc... The dotto ring I think it worked with pure amperage. Radiant energy is pure voltage, but have no idea about synthetizing pure amperage.
            I recommend to you this book:
            Amazon.com: Bionics for the Evil Genius: 25 Build-it-Yourself Projects (9780071459259): Newton Braga: Books
            • #51
              Thank you, that is interesting reference.
              I believe that electricity - magnetism - orgone are state of energy that can manifest into each other. Electricity can create magnetism and orgone, magnetism can create electricity and orgone, and also orgone can create electricity and magnetism.
              Bob Beck use electrode with positive charge that effectively kill the infection on a leg schedulled to be amputated. So there is use for positive charge. However, over accumulation do produce bad effect.
              My circuit is just variant of radiant circuit. Polarity will depend on how we use it.
              AV plug is utilizing electricity that is swaying between positive and negative, so it is both but not at the same time. An AC version, with frequency.
              Frequency is sign that the energy is going positive and then negative at a period of time. If longitudinal energy has frequency, then it must have polarity. Seeing that device intended to capture or utilize longitudinal energy require resonant frequency, I believe longitudinal energy has polarity.
              I believe dotto ring convert amp to orgone energy. And I believe radiant energy is not voltage but can produce voltage as effect with correct geometry.
              • #52
                I'm Magnethos, I cannot post with the other account
                a message says that the administrator has reduced the permissions of the account. The curious thing is this is not the first time that happens.
                In that book you can reaqd some circuits to experiment yourself. I think there are more in the internet but I haven't search for them.
                Electricity, as magnetism and other energetic phenomena is a property of the ether. When the ether differentiaties, then it can manifes as all those kind of energies, as you know is a matter of geometry.
                It's very interesting to know that. Since acidification is a mainly source of disease, and if you apply negative energy to an acid it turns to an alkaline substance. Maybe, hyperalkalosis is also another source of disease and then, if you apply a positive voltage you can reduce its pH level and turn it more acidic. I haven't read almost anything about this second option, but it seems to be very useful.
                So I understand that the radiant oscillator is a DC source of radiant energy. Right?
                Sure it has. Some time ago I believed that radiant energy was only negative, and it's possible that is negative. But there is some kind of polarization because I have read some documents and theories and they always speaks about 2 kinds of energies (both longitudinal).
                So if you think that is not voltage, what it could be? Maybe is possible that is not voltage, since I read somewhere that a man measured electricity in Ohms.
                So maybe we need to use ohms instead of watts or voltage, to measure the electricity?
                • #53
                  Maybe admin force you to only use one account?
                  Thank you. I think a single radiant circuit can be used many ways too.
                  Yes, unfortunately geometry is rarely explored.
                  It become DC with a diode. But since it is pulsed, the receiving part see it as AC since there is no actual zero. Similar to transformer output.
                  As far as I know, there is no measurement tool can be used yet. So there is no unit of measurement for it yet. The closest is Bovis reading, a dowsing standard for energy reading, but Bovis reading is a really subjective tool.
                  We can see the effect of those energy to human body reaction or plants. Those energy change blood activity for instance. So living being is a better measurement way.
                  • #54
                    Hello
                    Very nice information what you have tried to share with us. I like your way of explaining... Good job! Thanks to all....
                    lovegra online | generic viagra online
                    • #55
                      Viagra....? Lovegra....? Maybe wanting that we explain more things for then... search for that information and deleting it from the net?
                      No thanks, I won't explain more about this.
                      For this reason I don't like the forums.
                      • #56
                        Hey
                        Awesome information what i got from here... cancer is one of the dangerous disease and there are very few treatment for cure to cancer. I am thankful to you for your research.. Hope you got success in perfect treatment of cancer...
                        online pharmacy
                        • #57
                          Hi everyone here, I also think that everyone should be aware of the disease's like this and also the preventive measure from them.... Now a day's in this age every kind of the disease will cured properly by the new and advanced technology.... Take care of your health and keep maintaining your health for long life ever.....
                          • #58
                            There is no one reason but Such cells multiply rapidly and become malignant. Radiation therapies, radiation can normal cells and increase the risk of cancer.
                            Dunwoody GA Chiropractor
                            • #59
                              There are a lot of dogmatic schools of thought about the "#1 cause
                              of cancer is such and such."
                              The truth is that there are many causes of cancer.
                              Depriving a cell of oxygen will cause it to turn anaerobic and will start
                              fermenting sugar to feed itself instead of taking in oxygen. That is a
                              way to cause cancer (oxygen deprivation).
                              See Otto Warburg Nobel prize winner. Must have Nobel Speech:
                              It was known the oxygen connection and then Johanna Budwig appears
                              to know the connection with cottage cheese/flax oil, helps with enzymes
                              in the oxygenation process. This has cured many people of cancer:
                              Healing Cancer Naturally: Authentic Information On Dr. Johanna Budwig's Diet & Healing Protocol Based On Her Original German Works
                              Genetic mutation by carcinogenic substance is another way to
                              cause cancer. These mutations can be caused not only by substance
                              but also by electrical emissions, etc... such as children that have high
                              rates of leukemia that live near major power lines. And the ever growing
                              brain damage and tumors that are caused by cell phones. So chelation
                              and other detoxification methods like infrared saunas under strict protocols
                              such as what Dr. Sherry Rodgers used...I'm talking a very serious
                              sauna detox amongst other things:
                              Sherry Rogers MD you'll
                              have to search around for more info from her.
                              Cancer can be seen as a vitamin c deficiency since low ascorbic acid
                              levels in tissue doesn't allow the proper formation of "ground substance"
                              that acts as a binding agent for good strong collagen. It is hyaluronic
                              acid and ascorbic acid that works together to make the cement. Cancer
                              cells release a hyaluronidase that dissolves this ground substance
                              weakening the collagen and allowing the tumor to spread. See the
                              Linus Pauling and Ewen Cameron studies and not the fraudulent Mayo
                              clinic anti vitamin c propaganda nonsense.
                              Everyone has cancer cells but the immune system is in good enough shape
                              to get rid of it, usually. This is just a fact of life. People that live on sugar is feeding
                              yeast in their body and this sugar is junk food for cancer cells helping them
                              thrive. The yeast beats down the immune system and the body becomes
                              a walking fungus factory and the sugar that keeps this up feeds anaerobic
                              cancer cells causing them grow and grow. See the yeast/cancer connection.
                              Cancer Candida and Fungus - natural cancer therapy by Dr. Simoncini
                              maple syrup and baking soda cooked and consumed. Sugar appears to be
                              acting as a carrier for the alkaline baking soda to go directly to cancer
                              cells since cancer cells have a serious preference for sugar.
                              Nutrition is of course important because of the above reasons. It helps
                              the body detox, oxygenate itself better, provides nutrition to have strong
                              tissue and a strong immune system. Dr. Lorraine Day has a simple
                              raw food juicing method for curing cancer.
                              Dr. Lorraine Day's Personal, Official Web Site - Her Amazing Recovery from Cancer.
                              Check out http://www.energeticforum.com/dr-isa...edical-doctor/
                              Dr. Castillo probably has one of the highest cure rates for cancer.
                              Cancer has been cured by simple heat, red and infrared light and even
                              intention.
                              I've seen too many people murdered by the oncologists including family
                              members. There are many non-invasive methods to cure cancer that
                              are highly successful. The thing is that the average person simply isn't
                              willing to change their lifestyle to accommodate these changes even though
                              their life literally depends on it.
                              I have seen too many times people being
                              taken advantage of by their doctors, been put through the wringer with
                              chemo, radiation and surgery, and when all hope fails, as it is statistically
                              predicted that it will, then they will elect to do the "radical" natural
                              methods, at which time it is too late. I have literally seen this over and
                              over.
                              One therapy in conventional medicine I am actually hopeful for is for
                              esophageal cancer in children. Red light kills cancer cells, period, it's not
                              even debatable as far as I'm concerned and we have the cat scans, blood
                              work and pretty much anything else you can think of to prove it. Anyway,
                              photosensitive herbs like st johns wort, some parsley and others have
                              photosensitive chemicals (that make you tan quicker in the sun) and
                              cancer cells have an affinity for them. They soak up these chemicals.
                              The normal organs do too but not as much.
                              Expose red light to those cells and there is a chemical reaction that causes
                              the cancer cell to kill itself as a matter of fact. So in children, photofrin,
                              a synthetic photosensitive chemical can be injected in the children,
                              accumulates in the cancer cells in their throat and fiber optics with red
                              light can be put down their throat so the light shines on the area where
                              the cells are loaded with the photosensitive chemicals and the chemical
                              reaction happens that instantly kills the cancer.
                              Axcan Pharma Inc. - Welcome to Photofrin
                              Read section 3 on this website about photodynamic therapy:
                              Esophageal Cancer Treatment
                              PDT (photodynamic therapy) is the "smart sounding" term the medical
                              establishment prefers for nothing other than plain and simple red light
                              in 630-670nm range. There is nothing special about it no matter how
                              many times they talk about a "special frequency" of light. They also
                              don't know about the optimum frequencies to pulse it to crank their
                              results above anything they've seen...they mostly use steady non-pulsed
                              red light.
                              When I was neck deep in this about 8 years ago, this method was just
                              developing it seems. I'm not sure where it went but it was one of the
                              most non-invasive and effective "conventional" methods I've seen. The
                              only thing that wasn't natural was the synthetic version of the photosensitive chemicals. I believe the benefits outweight the risks of
                              this chemical that I don't think had any serious effects.
                              Anyway, this is NOT advice, I'll just say what one of the things I would
                              do. I'd load up on photosensitive herbs and bath my entire body in intense
                              red and infrared light pulsed at 292Hz for 30 minutes to an hour a day and
                              I'd do that at least 3-4 days a week - along with some other nutritional
                              supplements and a few other immune system boosting methods.
                              Every cell is photosensitive and it is the mitochondria in a cell that is the
                              most responsive to red/infrared light. As soon as red light hits it, it kicks
                              into high gear, atp production increases, etc... and all the complicated
                              kreb cycle activities are cranked up.
                              For brain tumors, the Spanish studies showed that thc from marijuana
                              stopped the growth of the cancer. Study was first suppressed, but you can
                              easily find it now.
                              Marijuana Chemical May Fight Brain Cancer
                              You can see this on a bacterial cause of cancer...this was a popular
                              all encompasing cause of cancer:
                              The Alivizatos Treatment Program
                              If they are doing the real formula, it works. I wouldn't be surprised if they
                              took the formula from my mentor's research. He knew Alivizatos and Dr.
                              Donsbach funded the trip and we got the formula from the patent
                              archives that weren't avail online at the time. Niacin, C and Ribose
                              by IV. It can be done orally with benefit but not as good. Coupled with
                              red light and other modalities, I have personally witnessed it work over
                              and over.
                              You can see the organization that has done more than any other group
                              to supress effective cancer treatments are progapanda machines:
                              ACS :: Greek Cancer Cure
                              They say the formula had brown sugar, etc... the alanine they mention,
                              is a half truth. dl-phenylalanine was used ONLY for one particular kind
                              of cancer I believe...I think it was leukemia or something.
                              Spokane Daily Chronicle - Google News Archive Search
                              The Spokesman-Review - Google News Archive Search
                              Tri City Herald - Google News Archive Search
                              This is the first time I saw those articles. Rodger's sister died
                              after living a normal life for a few years after a treatment with
                              Alivizatos. Came back to the states, was pain free, lived normal,
                              won the woman's golf championship. It was recommended for
                              her to come for another treatment and she never did. For her,
                              it came back but she had a high quality life for a few years
                              after one treatment. There are others right here in my town
                              that are cancer free TO THIS DAY from one treatment from
                              Alivizatos.
                              I uploaded an entire zip file with all the original patents,
                              translations, etc... that Rodger picked up in Greece. If I can
                              find it I'll post a link to it. I know I put it up sometime in the
                              past. It was the first time the formula was openly released
                              to the public.
                              bis beta carboxyethyl germanium sesquioxide is an organic germanium.
                              By itself, has cured cancer. The body sees it almost like pure oxygen.
                              It looks like you can get Dr. Asai's book here:
                              Several years back, I bought about a dozen copies off the internet
                              for safe keeping and for passing around to friends. Jarrow brand
                              organic germanium is probably the best.
                              There are a few people that have used some of the PATHS modules
                              like cellular and immune modules in conjunction with a few other
                              modalities that are cancer free now.
                              Thanks for sharing this useful information with us. I am not aware of these things before. But nw i have.
                              • #60
                                Some good suggestions on this page.
                                Cancer is a normal part of life but dying of cancer is NOT. It's not so important what causes cancer but more so "Why do we die from cancer?"
                                Cancer 'is purely man-made' say scientists after finding almost no trace of disease in Egyptian mummies | Mail Online
                                The best video to explain how cancer is purposely used as a form of eugenics to kill the most number of people while also making sure to bilk all of their money out of them as they die is this one:
                                YouTube - The Science and Politics of Cancer (2005) - Part 1
                                The same people that suppress free energy technology are the same ones murdering millions with cancer.
                                A normal healthy immune system would make you cancer free for life.
                                If I had cancer, I would do the following.
                                1) Switch to a basic pH diet (versus an acidic one)
                                2) Take the appropriate amount of B-17
                                3) Use the Beck Protocol to strengthen my immune system
                                4) Get all the 90+ essential minerals my body needed (go read "Dead Doctors Don't Lie" - Dr. Joel Wallach)
                                5) Take MMS to also help pump up your immune system and help with your pH level
                                NO ONE SHOULD DIE FROM CANCER. It's totally curable.
                                Everyone you know that dies from cancer was needlessly murdered.
