Did the designer(s) of the Gizeh Pyramid complex once leave a message that was more sophisticated than merely being able to somehow calculate the exact length of a solar year or to deduce the dimensions of this realm ??? It may just be a crazy idea, maybe not.
This map is a screenshot from the book “We, the Skytians – The Lie of the Land of AEgypt” by David Alan Ritchie. Free pdf on archive.org
The measures & distances are in Royal cubits. The lines in red David draw on this scale represent 7 cubits. He based his calculations on the measures and information from Flinder Petries measurements of the pyramids in 1880-82.
The black lines around the pyramids are ways (causeways) that have been precisely cut into the rock. With some kind of Laser technology, not hammers and cisels.
Some time ago I read bits of The ancient cubit and our weights and measures by Sir Charles Warren, he mentioned the length of 1 side of the Great Pyramid was 1/8 of a minute of arc at latitude 30? N. I checked that… but NO, it is in fact 1/8 of 1 equatorial minute. But the MILE is almost exactly 1/8 of 1’ arc of latitude 30?N.
1’ arc at latitude 30? N = 1604.1388 m, which is only a difference of 5.2052 m to the actual 1609.344m = 1 mile
Great Pyramid, Side length = 1/8 of 1 minute of arc = 440 Royal cubit (RC)
1’ arc = 1 nautical Mile = 1,852 km , 1852 m = 1.150779 mile
1852.3m = exactly 1 Equatorial mile
Official measures of one side +/- 230.34 m – 230.75 m
1/8 of 1852 m = 231.5 m = 440 RC
1 RC = 1/440 of 1/8’ arc or 1/3520
= 0.52613636m = 52.613 cm
= 20.718 inch
Second pyramid, Side length = 411 RC
411= 3*137 and 137 is the 33th prime number.
Official side length: 215.16 m.
Calculated side length: 411/440 = 0.9340909090 = cosine
Inverse cosine 0.9340909090 = 20.918232?
1852 m * 0.9340909090 = 1729.93636 m
= 1’ of arc at latitude 20.918232? = 20?55’ 5.6352’’
1/8 of 1729.93636 m = 216.242m
Third pyramid, Side lengths 200 x 196 RC
Official measures 104.6 x 102.2 m
Calculated measures, repeat procedure
105.207272 x 103.1227272 m
= 1/8 of 841.818181 resp of 824.981818 m, corresponding to 1/8 of 1’ arc at latitude 63.547576?, resp 62.944308?.
Inbetween I read fractions of the Rhind papyrus
The designer(s) of the pyramid buildings worked with whole numbers and fractions thereof. Everything was a fraction of 1. 1 was the whole, the complete, also called Wedjet. The famous Wedjet Eye (Horus Eye) was a help for pupils to study mathematical divison by multiplying with fractions.
All ancient measures used were fractions of 1. It can also be seen in the Vitruvian man.
Example: The Zereth, Span was equivalent to 3 palm or 12 Finger or 1/8 of 1, the Ammah or cubit was ? of 1.
What if the Gizeh Plateau was ? of 1? Multiply and mirror, this is the result
Now it looks like a technical drawing. Did the designer(s) leave a plan ??? Could it be for some magnetic propulsion engine? Or sth else?
The ways, cut in rock, must have a meaning. The squares surrounding P2, the corner is where the causeway from P1 leading to sth North East is changing its angle. The line of the outer square ends between 2 Queen Pyramids, That’s not a coincidence.
That causeway from P1 starts now between the 2 x 3 Queen pyramids and touches the corner of the inner ones. They are now 2 x 6 total. Each side has both polarities.
The center of the second pyramid passes right through the head of the Sphinx. (Represents the Sun, thus magnetism? Or heat ?) The 4 Sphinxes incl 1 of the “temples” now in 4 pyramids, it looks like a quadropole generator. The 2 sphinxes on the right side are covered in my image.
Well, it’s not a high precision drawing, it’s made in an image editor program, not a vector program.
There is so much more, haven’t even started looking at angles, ...
From David Alan Ritchie: the dimensions of a room, or space are important, because they produce frequencies. So it might be, that it works or is started with frequency induction, 3 different harmonic frequencies united. -> Kings Chamber.
I don’t know if this is the right place to post “crazy stuff” like this … but right now I’m looking for some inspiration. Yeah, and I would be glad to know if Gamebeir is still alive, he’s been inactive for more than 1 year here.
= 20.718 inch
