I found this elsewhere.
The guy is a Living Genius.
Anti Gravity and Cold Fusion Verses Gravity and Hot Fusion. Abridged Version.
Understanding the Physics of Electricity, Magnetism, Hot and Cold Fusion, Gravity and Anti Gravity.
Electricity is a ‘flow’ of Magnetic Current as Direct Current. It can be made to be an Intermittent Activation of the Atomic Structure by the Force Lines of a Magnet in each “Passing By” of the Atomic Structure by the magnet. There is no actual “flow”, all there is… is vibrations in the wires.
Everything has an Opposite and Equal ‘effect’.
Electricity and Magnetism each have 2 equal and opposite effects.
Without Direct Current you CANNOT create a Magnet.
Without the Battery’s Opposite and Equal effect you cannot make a Magnet.
Anti Gravity, like its counterpart Anti Heat energy, are both Effects of North Pole Negative Field Current energy.
Electrolysis creates 2 Distinct Gasses according to the Polarity of the Magnetic Current.
Float up is the opposite and equal to fall down.
The Opposite and Equal to Hot Fusion is Cold Fusion.
Hot Fusion is Expansive Forces whilst Cold Fusion is Contractive, compression or Implosive Forces
Oxygen is a Heat releasing ‘elemental frequency’ as without it there is no “Fire” or hot destructive Atomic Structure disintegration.
In the absence of ‘Oxygen’s’ Fire Expansive forces, we have Low Energy Nuclear Reactions where ‘carbon’ turns into a ‘crystal’ as ‘silicon dioxide’ in a Cold Energy ‘Atomic reaction’ or more correctly a Magnetic Interaction.
Oxygen is a Wind that has been Charged Up by the Force of South Pole Positive Magnetic Current. Its Opposite and Equal is a Wind that has been Charged Up by North Pole Negative Magnetic Current.
It stands to reason that if, the South Pole Positive Frequency of the Wind is attracted to the Earth, the Earth must be North Pole Negative Magnetic Field. Earths or solids like metals can have a Magnetic Polarity Bias depending upon the creative Forces that Bio Transmuted or created the Iron in the first instance. Copper has a Positive Magnetic Bias while Iron has a Negative Magnetic Bias as does Zinc and Silver. The PARTIALLY North or Negative Mono Pole Field of the Spherical Earth is a Cold Fusion or LENR Environment for Petrification of any South Pole Positive Life Form into some variant of ‘Silica Dioxide’.
Some ways to duplicate this Anti Gravity effect is to make an ANTENNA Coil that is ‘Frequency activated’ by ONLY North Pole Negative electrical or magnetic forces. The two distinct Mono Pole Magnetic Fields, the Earth and the Wind, can be duplicated with Direct Magnetic Current by using the 2 Current s of a battery Individually when making a Field Coil or a New Field effect given to an object or ‘defined volume’ of either Earth, Water or Wind.
We can make Mono Pole magnets by joining two Same Pole magnets with a mild steel washer in-between. Where the washer will display 2 distinct New Properties from this application of Mono Poles technique. The washer undergoes such Atomic Nuclear changes that either the Washer will become Non Rusting or it will rust faster than any control depending upon which Same Poles were used.
In Electricity, a simple way is to use 2 car batteries that are connected in Series, but we only use one of the two in such a way as the Leads are either attached to the 2 Negative or the 2 positives but still only delivering the Voltage of one. This will give us two magnetic coils that will have two distinct effects on the other field coils if all Coils are wound with Iron Electrical Wire. And therein lays a High School Experiment to create North Pole Negative Magnetic Levitation or an Anti-Gravity Field Effect in Earth elements rather than Wind elements as in electrolysis.
Electro-Gravitics. The Force for the Motions of the Future. Giving upwards and downwards ‘thrust’ depending upon the Dial.
South Pole Positive Currents, like their ‘products’ such as oxygen, rust or turn to dust and disintegrate the Atomic Nucleus. Whereas North Pole Negative Currents (vibrational Frequencies) preserve, solidify and transmute the elements. North Pole Negative energy cleans, retains cellular Memory as per lines in petrified wood. Whereas South Pole Positive Magnetic Current dirties or destroys.
We find this in any of Joe’s Magnetic Induction Cells by reversing the battery leads or magnetic poles for an Opposite but Equal treatment of water by Magnetic Field Induction rather than ‘electrolysis’ as seen here.
Everything is Magnetic. If it can be dissolved, it can be electroplated which means the ‘Earth’ (metal) has a ‘polarity’ or is Magnetically Biased, rather than para or dia in newly invented terminology. Magnetic Electroplating is done without understanding the relationship between electricity and Magnetic Fields when using ‘electrons’ to alter the physical ‘Format’ of an element in a watery liquid.
One of the instructions for building a TubeCell, is each pipe has a North Pole that can be determined by either second sight or with a Dosing Rod or controlling manufacture as the North Pole end of a steel pipe exits the furnace first. The end of the extrusion is South Pole Positive. When all aligned with North Poles at the Top, the Magic begins no matter how the electrodes are connected for the 16 different outcomes such an apparatus can have on a single sample of a watery fluid. The South Pole Positive’s ends of the pipes must face the North Pole Negative Field of the Earth.
A Magnetic Field, regardless of how it’s created, is only detectable if there is WIND, Water or Earth to propagate IN. What is measured or detected is the Rate or Field Strength of the Vibrating WIND’S Atomic Structure. We evidence the Vibrating Atomic Structure with a Mass Spectrometer as frequencies not particles. Change the Frequency or make a Single Pole Field, it will change the Atomic Structure to that which is quite poorly understood like Carbon to Silica Dioxide or even teeth into Opals.
These are the Scientific Premises we use to form logical conclusions to Invent by. We visualize the Field Effect as an outcome of a particular design, much like Tesla did. Field Polarity is important in a Unified Field Device. A Magnetic Field has 2 Components and all Man really does is to spin them to manifest ‘energy’ in a Field Coil at the end of a wire, in order to be utilized. Its all Field Science as everything is Magnetic, no ‘dia or para’ about it. Everything has a “Rotating Magnetic Field” and “Vital” for its existence, said Tesla.
It is with this understanding of Magnetics that we can apply Magnetic Fields to the human Bio Field with the ‘Right’ Frequency of Magnetics. We can also apply Direct Magnetic Current directly to the Bodies Battery Terminals without Doing Harm or electrocuting by not knowing which hand or body part corresponds to which “battery terminal polarity”. This direct application of Direct Magnetic Current can be utilized in Massage therapy, other points on the body ‘similar’ to Acupuncture Points and through the medium of bodily immersion as in foot, hand or full baths.
Such experiments can be trialled on plants where Electrolysis verses Field Induction via an Antenna Array rather than 2 electrodes, will see not death by electrocution but Bio Field Enhancement. This could be the first experiment of the Aqua Chi Footbath Array for budding Magnetic Water Scientists and Future Field Inventors.
