about the Ferrocell (ferrolens)
  • Well this guy thinks otherwise - Don't laugh!
    I take this guy seriously!
    F**k complexity.
    Simplicity is the answer!
    [VIDEO]https://www.youtube.com/watch?v=C3DD33ZZ6Co[/VIDEO]
    [VIDEO]https://www.youtube.com/watch?v=5pcGN3YCGs4[/VIDEO]
    EM
    MSc. Electronic and Computer Engineering, TUC, Greece
    • Types Vector Magnetometers classification according to the materials they use
      http://www.energeticforum.com/attach...1&d=1536817893
      EM
      • Iamnuts, beautiful video, thanks ) Love it!
        • The ferromagnetic loop enigma?
          [VIDEO]https://www.youtube.com/watch?v=MO884n--t_o[/VIDEO]
          Watch carefully and give your explanation.
          However magnetic hysterisis can not be accounted for here, since the structure can be left hanging for years as reported undisturbed without getting loose!
          This guy claims that he left it hanging for 2 years! here:
          https://www.youtube.com/watch?v=832qz3s1M-s&t=210s
          copyright©Emm Markoulakis TEI of Crete 2018
          • retentivity
            It is simply retentivity, or remanence or remanent magnetization, which has no time dependence.
            • I applied the voltage on the coil-U core without the shunt, disconnected the battery and it couldn't hold the shunt. Since the remanence magnetization is not shape dependent as we know, I believe that remanence alone is not adequate to explain this phenomenon.
              I believe the explanation of nerd (excuse me I meant nornd ) is possible:
              [VIDEO]https://www.youtube.com/watch?v=H5q-LOhBHSI&t=[/VIDEO]
              EM
                Δ Psuperfluid
                Al
                • Retentivity
                  EM
                  You obviously did not drive the steel to saturation.
                  • I have just tried it out with 24V power supply. I have read a current peak of 12 A, disconnected the power supply from the coil and it still couldn't lift the shunt.
                    So I guess remanence magnetization in this open U shaped configuration is not enough to lift the shunt. But as soon I close prior the loop with the shunt and apply a relatve small voltage considering also the voltage drop from the 9V alkaline battery, the shunt keeps attracted with disconnected battery.
                    I don't believe that this is caused by the extra ferromagnetic mass added by the shunt increasing the remanance. It must have something to do with creating a magnetic loop.
                    • Originally posted by Iamnuts View Post
                      You won't get anything much better than this!
                      https://youtu.be/Mqo86FvLADY
                      Nice! See how the theta θ pattern emerges whenever he is lighting up the side field view of the magnet.
                      [VIDEO]https://www.youtube.com/watch?v=Mqo86FvLADY&feature=youtu.be[/VIDEO]
                      EM
                      • The solution to the magnetic loop enigma
                        Okay I've decided to give you the answer since no one here seems to know about it. The phenomenon responsible for this effect has little to nothing to do with magnetic remanence since this is too small an ineffective in this case presented to hold the structure together.
                        The phenomenon responsible for this effect is called circular magnetization (look it up) and is essentially the same field generated in a torus solenoid with a core electromagnet. You essentially creating a magnetic loop or else a circular permanent magnet (although very weak in our example).
                        One key characteristic of monoblock circular permanent magnets magnetization mode in contrast with other types of magnets is as soon you physically break the circle... they broken parts are not smaller individual permanent magnets (with the exception of a circular magnetic array made out by individual magnets).
                        You can demagnetize apart of thermal shock also by mechanical shock...and that's what I did. The closed loop configuration was magnetized by the magnetic field created by the high current passing the through the coil. The mode of magnetization is circular (not to be confused with radial) and is not detectable with a Gauss meter. Magnetism is confined inside the loop and don't leaks outside... nothing special really.
                        EM
                        • Magnetic path
                          Of course. What is the reluctance of the path with and without the the steel keeper across the poles of the U? What magnitude of mmf needed to drive the steel to saturation? With and without the keeper? Power supply requirements?
                          Even if you could drive the steel U to saturate without the keeper, as soon as the excitation is stopped, without the keeper in place, the hysteresis will relax to a low residual level incapable of the core flux needed to hold the keeper.
                          • Is De-Broglie Bohm (pilot wave) Theory gaining ground today over the Copenhagen?
                            Is De-Broglie Bohm (pilot wave) Theory gaining ground today over the Copenhagen Interpretation?
                            Dear All,
                            The omnipresent aether medium is coming back in science today with new proof of concept experiments and and as an alternative theory to the Copenhagen interpretation fallacy: The theory now contradicting the establishment and gaining ground over time is an old theory namely the the pilot wave theory:
                            Is This What Quantum Mechanics Looks Like? - YouTube (pilot wave theory)
                            https://www.youtube.com/watch?v=3ZPVp0NGEYY (Nassim Haramein explaining)
                            DUAL WALKERS
                            https://en.wikipedia.org/wiki/Pilot_wave_theory. (biased view)
                            Elementary particles and quanta of energy are all manifestations of this same omnipresent medium (aerher), in the form of vibrations, condensations, waves, and in general distortions of this aether universal dark (i.e. we can not detect it yet but only can see the effects of interaction with it like EM SNF WNF and Gravity).
                            EM
                            • Hi Markoul,
                              I am aware of this example and it perfectly fits the vibrating toroid being the standing wave. Love it!!! Just that Veritas got it wrong, its not particles creating waves, but the wave looking like a particle at point of resonance
                              https://www.youtube.com/watch?v=WffR6HrEqTA Go to min 0.50-1min.
                              Why do you think its coming back? Did you read that somewhere?
                              I would love to know who is picking it up Let me know
                              SSML
                              • Interesting video! I tend to agree with you. Although there is one matter to be solved...
                                If universe is vibrations like this:
                                Who is playing the fu**ing piano?!
                                There is a experimental paper written that emulates the double slit experiment using hydrodynamics and the pilot wave theory. Look at veritasium youtubre video.
