World seismic disturbance
  • World seismic disturbance
    Yesterday seismic disturbance World
    If you see these maps updated every half an hour, now they are all flat;
    while yesterday all stations were sismometriche fibrillation,
    wobble as if the whole earth.
    It 's the third time this has happened in a short time.
    What to think?
    LISS - Live Internet Seismic Server
    Over the weekend we had a 7.6 earthquake in the Philippine trench. I have been waiting for the activity to start here because we have has the Japanese quakes and New Zealand quakes. That meant opposing sides of a plate had been relieved putting higher stress on the remaining sides. Getting quakes here in the Philippines reduces the risk of big quakes in the US. So far we have had two magnitude 7+ quakes since japan which is good as these smaller quakes help reduce the stress on the plate. Better to have lots of small ones than one huge one.
    This is a huge plate and any large activity on it will cause the earth to quiver to some extent and that could be the cause of the activity you see.
    Whats the cause of the quakes?
    I don't think it is planetary alignments as the moon has a far bigger influence on earth than they do.
    Is it HAARP? Well it is possible and we know the US and Russian governments have experimented with earthquake weapons and we know that the US is still experimenting today but we need evidence. I am not aware of any group that is monitoring the activities of HAARP or any other similar projects around the world, are you?
    Global warming? No, the earths temperature has been stable for the last 10 to 15 years and Global warming is a myth to get you to pay your taxes to Al Gore.
    It is very possible that it has to do with our orbit which at the moment is relatively close to the sun, as I understand it and the sun's increased activity.
      thank you
      I applaud your update..
      If the Earth does get warmer the plates will shift..nothing new there.
      If the Earth does get warmer..the Earths crust will get thinner..Hummmm.
      So what would that change..??
      Tid-bit not related...Question: Mars needs a moon..What would that change??
        I would not worry too much about the heat generated by seismic activity, the sun is by far the biggest influence on the temperature of the earth, a fact denied by the climate changers.
        We have seen activity off the west coast of Canada, this should spread down over the west coast of the Americas and this is good news. It means that the pacific plate is fluid and massive earthquakes are less likely, absent some other influence.
        I did find a site that is monitoring HAARP HAARP Status and Real-Time Network Detection They documented that the weather was being manipulated at the time of hurricane Sandy causing winds in a general east west direction and very high levels on the east coast suggesting the hurricane was been drawn in. Not sure what to make of that. Currently they are sill operating in the same areas but with the following warning
        "Longwave detected earthquake signiture"
        November 1, 2012 - 3:30p EDT
        California has gone red. Usually this is a weather, but this is signature is that of an earthquake.
        The frequency build and peak of 7.4 suggests a window of Sunday through Wednesday of next week surrounding California.
        NYC station is back up after being down down. These signals are not from Sandy. These are new signals across the Northeastern United States.
        I cannot say if this site is accurate or not but it is worth monitoring.
        Having said that these two seismic records look interesting ASL DCC BILL TELEMETRY DATA and ASL DCC TUC TELEMETRY DATA what is going on there? There is no earthquake activity shown for these regions on google earth.
        My prediction is more moderate to large earthquakes on the pacific ring of fire and specifically off the coast of the Americas. This is in keeping with the small amount I know about the solar and planetary cycles.
        Are governments influencing seismic activity around the world? Yes, just google "earthquake tests haiti" amongst all the chatter you will discover that there was indeed earthquake weapons being tested by the US military in the reagion, admitted.
        If Mars had a huge moon like earth there would be more seismic activity. Would that be enough to keep the majority of ice on mars liquid? would it help mars keep a more hospitable atmosphere? I don't know but it is an interesting thought.
        Update 7.7 Earthquake Hits Where The Worlds Largest Geoengineering Experiment Took Place
          I did not think my prediction would come true so quickly, the recent quake in Guatemala and Canada has been preceded by literally hundreds of small quakes on the western side of north America over the last few days. Its almost as if the pacific plate is ringing.
            I'm afraid it is more than just Pacific Plate.
            V
            General D.Eisenhower
            http://www.nvtronics.org
              V
              Do you think HAARP could have anything to do with it? They are resonating the west coast of the US which is between the two big earthquakes HAARP Status and Real-Time Network Detection
                I might have found the reason for the HAARP activity, its only speculation but I would like to know what you guys think.
                I looked at the center of the harp activity on the west coast of the US, California to be more specific. There is obvious concern if they are trying to cause an earthquake n this region. I noticed a spot of high levels of earthquakes in one area and zoomed in on google earth and to my surprise found an area covered in what looks like gas fired power stations although they could be oil, with pipelines coming straight out of the ground and going direct to the power stations. The HAARP activity is diminishing in this area now. Is it mission accomplished? 38 49' 24.12"N 122 48' 52.72W
                Being suspicious I looked at the center of HAARP activety now which is slightly north of the center of Kansas. and what did I find? An oil field 39 04'42.50"N 99 09' 52.76"W
                Is HAARP being used to shake the oil and gas out of the ground? It does make some sort of sense.
                Better take a look now with the earthquakes turned on in google earth to see what I mean. In the central US area the main concentration of earthquakes at the moment is just west of Kansas in Colorado, again where there is an oil field. If the HAARP activity continues until we get the earthquakes in the center of Kansas then I think we have proof of the purpose of the activity.
                  Nothing surprises me anymore mbrownn. There was 4.3 followed by 2.5 in Eastern Kentucky in the past hour.
                  V
                    external net force precession tourque times delta T
                    the information i had posted will explaine these results.
                    this is a validation for me, i hope you will understand the information i had provided.
                    cheers.
                    If the bird that we see quacks like a duck and swims like a duck, and so on all the way down the line, then it‘s a duck.
                    If it crows like a rooster and can‘t swim, then it‘s not a duck. It
                    doesn‘t make any difference how many people insist on calling it a duck, —it still isn‘t a duck.
                    The physicists‘ atom is an imaginary atom constructed of
                    imaginary particles.
                    Irwin Schroedinger tells us, “If the question is asked, do the electrons actually exist on these orbits
                    within the atom, the answer has to be a decisive no. “The atom of modern physics can only be symbolized by
                    a partial differential equation in an abstract multi- dimensional space.”
                      According to HAARP Status and Real-Time Network Detection the earthquake signature has gone and Kansas is no longer effected. Only weather manipulation on the east and west coasts remains so I wont get my HAARP theory tested.
                      My prediction for the west coast of the Americas remains, more moderate to large quakes based upon the stresses on the pacific plate.
                      @mire Wow, is that your own work? I cant pretend to understand it all but it is interesting.
                      There will be hundreds of factors that cause quakes, as well as what man does but I still believe the biggest factors are the moon and the sun with gravitational, magnetic and electrical fields all powerfully interacting with the earth. Of course there is the solar wind and cosmic rays too.
                        Hi hi, yes i had done this paper on my own, im sorry i am not the best writer but if you have a question please ask.
                        the ice age model i had done and i am exited to share with anyone who will take an interest.
                        the precession was described by eintein but its hard to locate his work on the net these day. everything he said is validated.
                        please try to locate his work on earth precession.
                        this is the case, prediction becomes time variable I have done this over the last 3 years and it is more of a validation for me.
                        I just hope others can understand it.
                        if you watch this lecture you may understand completely that this is the case.
                        Earth Precession 2011 update. - YouTube
                        I have also examined symbols that also validate this effect, and time frame.
                        peace love.
                        Ice age 3 d -model described. Yes Doctor? The precession is continuity torquing. It continues to follow the slipping top analogy.
                        Its simply spinning. Its simply stunning, its simply continues to rotate I will exaggerate your observations. Its simply up to you to observe.
                        As it rotates earthquakes become time variable according to rotational speed. The axis it i pointing, it following the spinning top.. its simply slipping. its simply a stunning effect. There is a pressure of fluid within the core. Its simply splitting, its Humphrey Dummpie. Its described ,and self verifying. Its simply continues.
                        Its bursting, of a water balloon. Its simply to soon., Its simply predictable. Its following its secondary oscillation. Beating like a drum. The wave is in front. Its simply like a pointy boat or arrow. Its simply caused by this star. There is, simply no way around. The time frame was predictable. Its simply solar rotation. Its simply lunar precession. @3 days of solar rotation, and according to speed it will split like a cord. Ripping the seams. Its
                        It was simply well known. Its simply a des-cry. An utter dis-( By grace). I am simply sorry. It simply was well known to be true. lighting up like a tree on Christ mass day. Its spilling on two sides. The start of the predictable out come is time variable. It also follow along the net force inducing. Its also bouncing and skipping along. simply bending space. What is relativity?
                        Its simply, Cause and effect.. Angel
                        As the earth spheroid preforms like an egg. By freethisone, Mire..
