EPFX | Interesting Screen Shots
  • EPFX | Interesting Screen Shots
    Here are a just a few of the THOUSANDS of different screens on the EPFX
    This first one shows the fundamental principles of the EPFX function-
    Kevin
    PATHS For Healing
    Energetic Science Ministries
    Meditation at the Click of a Button, Guaranteed!
    ESM Forum Support Link
    Here are a few addressing chakras, auras and energy leaks.
    The first one show big energy leaks and chakras very unbalanced.
    This next one shows the energy leaks (red and purple ovals) are shrinking
    This next one shows the energy leaks are gone, chakras still not balanced
    This next one shows chakras balanced
    This last one shows-
    No energy leaks
    Chakras balanced
    Aura corrected as best it can be this session
    Kevin
    PATHS For Healing
      This is a screen shot of a list of neurotransmitters. Any "Value" over 80 is less than optimum.
      Nice reference for seeing which neurotransmitters have what affect on a person.
      Kevin
      PATHS For Healing
        I had the following question asked about the above screen shots-
        Very interesting; thanks for sharing! You did that in one session? How long do the chakras stay in alignment after the session is over, especially when the levels are fairly far from 80?
        To do the energy leaks, chackra alignment, and aura corrections is about a 10-15 minute process. All other work done before that helps get better results in these 3 areas.
        It is sort of like going to a chiropractor....it may stick for a few hours, a few days or even weeks. Every person is different. The more you do it, the longer it lasts.
        The neurotransmitters that are above 80 are a completely different process to correct. These can be quite stubborn and entangled with many other issues.
        Kevin
        PATHS For Healing
          Hi, Good info Kevin. I should study with you!! I have to work more to understand the tech of the neurotransmitters process. :-)
            Maybe the next time you come to Florida. Love that Daytona Beach. :-)
              Hey Ron,
              Yep, Daytona was fun.
              I am going to be posting more shots of different screens.
              Perhaps you could post the instructions on boosting the power on the EPFX! I really enjoyed learning about that.
              I have found Neurotransmitter work to be very productive with many Clients!
              Kevin
              PATHS For Healing
                neurotransmitter database
                Kevin,
                Does the EPFX store the last sessions results for someone such as the neurotransmitters? Like in a database that can be referenced?
                  Kevin,
                  The EPFX does NOT store the last sessions results for 99% of the data generated. There ARE a few things it stores...the neurotransmitters is not one of them.
                  Much of the data generated during a session can be "dumped" to a report that can be printed out, or stored in a file such as a MS Word doc. It can NOT be imported back in at the next session for any comparative work.
                  Any session to session comparisons would have to be done manually.
                  Kevin
                  PATHS For Healing
                    Kevin,
                    I look forward to your next posts.
                    In regards to boosting the power of the EPFX. I will post what I do probably Sat or Sun when I get back from a Christmas visit.
                    Til later,
                    Ron
                      Kevin I am amazed at seeing this screen shot, great job.
                      The closest we have come has been to have it clear but still not rectified.
                      How were you able to achieve this? How long was that particular session? How many visits had this client had prior to this session?
                      Thank You
                      TREE OF LIFE
                      www.treeoflifebiofeedback.com
                        Hi, are you referring to the chakra balance and/or the aura balancing?
                        If so, I keep working on everyone until they are clear. Some it takes only 1 or 2 attempts, sometime (the other extreme) it can take 20-30 attempts.
                        I do not remember who this particular client was...but it does not matter, whether it is the first session, or if I have been working with them for 5 years, I always make sure to align/balance the chakras and correct the aura.
                        Kevin
                        PATHS For Healing
                          Actually I am referring to the patient rectified screen shot. Whenever we check that screen it has always come up patient not rectified so we click on the button that says correct all till Maximum.
                          We also work on balancing the chakras every visit with our clients.
                          Thank You
                          TREE OF LIFE
                          • #14
                            Ah, sometimes I work on one person for multiple days (subspace). Not everyone rectifies 100%, but the more time you spend with someone (as long as they are not alarming) the more progress is made.
                            Kevin
                            PATHS For Healing
