The injectors in direct injection configuration is needed to make safe operation and to lower what stan calls the speed of the gas explosion and works like this:
In the intake phase the motor let the air get inside of the motor than the motor start the compressional stage the air get up to 600 degree and when the piston start to going down again the hydrogen and oxygen is injected causing a controlled explosion. You wont need any spark. What Stanley call the laser distributor is in fact a common distributor witch is just used to turn on and of the solenoid in sync with motor turning, that control the hydrogen injection and at the same time it make the signal for the duty cycle witch control the power output.
The non combustion gases serves not only to lower the gas explosion speed but to act as a flash back arrestor in conjunction with the quenching circuit. This is the only way to inject hydrogen and oxygen together. Note Pure hydrogen wont explode until it has at least 4% of oxygen. The mixture also causes the temperature of the flame to be lower and the minimum temperature for to it self explode to be higher.
