just bought a new vehicle and am transferring my hho system to it from my old car is there anything i need to do? i heard i should keep the hho input low to begin with to clean out the carbon deposits as they burn very hot and may damage the head if to much hho is introduced straight away.
hho boosting a turbo diesel engine. anything i should know?
Data please...
Sounds like a plan.Originally posted by hhoexclusive View Postjust bought a new vehicle and am transferring my hho system to it from my old car is there anything i need to do? i heard i should keep the hho input low to begin with to clean out the carbon deposits as they burn very hot and may damage the head if to much hho is introduced straight away.
What are you going into a used vehicle with many miles?
What hho system are you using.
Any idea what production of Hydroxy is from it?
Acts 1:8
i run a waterforfuel type system it makes plenty of gas it starts at around 1lpm and peaks at 8lpm the vehicle has done 140,000k's and has been very well maintained. my sytem can be adjusted to produce any output i require within those ranges. i'm new to diesel engines but the knowledge gained from my old vehicle should be applicable
You have options
Sounds like you are in a unique position with your hydroxy system.
I would start with the baseline of mimimum hydrogen and monitor engine performance and check for alarms...
Slowly increase over time and distance your hydroxy measuring your mpg as you go for optimal performance parameters
Acts 1:8
Originally posted by hhoexclusive View Postthanks for that i'm in the process of making the brackets required for my high voltage alternator today. so hopefully wont be to long till it is all in. if anyone knows how to adjust the fuel mixture on a diesel engine? that is also something i need to take care of.
What yr. model and type of diesel?
Turbo diesel info here..please add input if any to this thread
(key words turbo diesel)
hi ashtweth. i decided to ditch the old petrol vehicle i was testing with for a newer vehicle as i had gone as far as the carb setup will allow without going to efi. and besides i really wanted to focus on diesel vehicles and generators anyway. my boss has approached me to build a system for his twin 800ci cat diesel powered launch now i have proved hydrogen is safe. so i should be able to forward some valuable info hopefully.
You need an EFIE if u have an oxygen sensor
Also check the Diesel turbo info posted in that document should get you started, i suggest U READ ALL OF THE DOCUMENT
For every liter of engine size, add 1LPM of hydroxy (liter per minute)
This will give you a good boost.
From what I have read, the O2 sensor on the new Turbo Diesels is to control the amount of EGR and not the amount of fuel being injected (unlike gasoline engines) But I suppose it needs to be added to the list of things to be testedOriginally posted by ashtweth View PostYou need an EFIE if u have an oxygen sensor
