  • Thanks all last few posts
    Originally posted by plengo View Post
    The PIC16F887A is not easy to program. I would highly recommend easier and cheaper ones such as Arduido. You will also need a programmer. If you computer does not have an old serial port you will have to spend more buying a USB/serial port converter.
    I prefer now using Arduido because its absurd simplicity, easy of setup and use and its open source concept and those ones come with USB cable too which saves you a little bit.
    My 2 cents.
    Fausto.
    After having trouble understanding what they were doing with the Hex controller on the other thread, these last few posts have woke me up. I have old computers with RS232 ports that were used for external modems
    and mouse ports. I also know a bit of programing in BASIC. So you have opened me up to a whole new area where, at least, I know a little bit about,
    and is more dos based (which I prefer anyway). Hope to start using some of
    these things myself. We need all the help we can get trying to build these
    circuits.
    FRC
    • Thanks everyone
      genessc, Your suggestion worked. I tried about 10 different sizes of caps, found by reducing from 10000uf to 470-1000 that the mosfet started cycling and charging battery without slowing rotor or adding amp draw on primary.
      Thanks again
      ED
      • Bedini GT3
        Brent,
        That coil is looking good, are you going to cut out the center hole for the welding rods, I did mine first so I could reinforce the spool. Your coil impedance looks to be about right. Sorry, got real busy at work but then discovered I left my computer on. My cable is intermittent here at home right now. But that coil is looking real good.
        John B
        John Bedini
        www.johnbedini.net
        • Center coil core
          John B,
          Thanks for taking a look! And yes, we are going to cut a 3" diameter hole in the flanges for the welding rods.
          Since you bring it up...and since we have never cut a spool up like this before. What kinds of things can we expect to run into when we do this? Are we going to destroy the structural integrity of the spool when we do this?
          Also, I remember you saying that the welding rods have changed some in the material make-up. Do you still recommend the RG60 1/16" for this build? Any recommendations on securing the rods inside the spools?
          Thanks as always!!!
          Brent
          Brent,
          John B
          • Pic
            Hello John K , FRC and Fausto Thanks for the info. In post 944 David posted he was using a 16F690 . He has giving me his code and it looks like it will work with a little mode help from him.
            Better controll of the timing dwell and duty cycle control is my goal also.
            Back too rereading and taking more notes for now. Seems I misssed a lot of info the first 2 times I read them all I also watch John B's video's (Energy from the Vacuum series) 2 or 3 times in a row lol.
            Thankyou everyone
            Randy
            • Bedini GT3
              Brent,
              The only thing that you will find is a step under the circle you cut out.
              You will half to make shorter rods for that glue them in first.
              Then cut all the other rods for the full length, that rod is fine RG60.
              Try to get them as straight as you can, glue them one at a time if need be. Also try not to cut the step out or you will break the bobbin, and that will be a tough one to fix.
              John B
              John Bedini
              www.johnbedini.net
              • Spools
                John B,
                Thanks for the heads up!
                Brent
                Brent,
                John B
                • Excellent Ed. Glad that worked for you!
                  Gene
                  Thanks again
                  ED
                    I tried a separate winding of 27# wire, 2 layers right on the main core. Than I wound the drive winding over it till the bobbin was full.
                    I used a resistor, pot voltage divider to supply from 0-5V dc to the small coil. I also use different amount of supplied currents. The coil was wound the same direction as the main coil.
                    Vissie
                    i thought you were just suposed to "close the loop" on the control windings and the induced current generates the mag amp effect? or am i way off...?
                    dave
                    • It sorta sounds like you're way off. From the limited info shared, John B noted to put all windings in parallel.
                      What I took that to mean was to take the two slave coils windings and put them in parallel with the drive coils trigger winding.
                      Considering there hasn't been a schematic assembled and shared for review, I'm not sure its clear the right way to wire things. RS has shared a schematic but not sure if thats the same as the Ferris Wheel setup.
                      Some sort of schematic would go a long way to align everyones idea of how this is supposed to work. Whomever has the youtube vid up showing the bicycle wheel rotor kicking back then sliding forward and starting to run, looks to have the circuit sorted out properly. (or at least enough to get it to run, if its running properly is as yet unknown, but it is running.) I'd posted a comment on that vid asking for a link to the schematic but nothings been updated as yet.
                      Hopefully someone thats got a working replica can take a stab at the schemo and we can all then discuss and work to replicate based on the proper roadmap.
                      Take care,
                      Gene
                      dave
                      • Originally posted by genessc View Post
                        Take care,
                        Gene
                        Gene, Check pg. 28 post 828. Thats what I am working with right now.
                        And there has been several Schematics shared. Pick one...
                        Every one else,
                        I do have this self starting, But it was running to fast.
                        So I moved the coils further from the magnets and re-tuned it. I over heated
                        the transistors and replaced them. Now it does not start as well. I did get the cap to dump better,
                        but it is tricky to get every thing right.
                        I have tried many different sized caps, but when you adjust the timing a
                        different size cap is needed to pick the charging back up.
                        The more I change things around it seems the futher I get from being right.
                        So I will go back and set it up from the begining. I does seem to charge better with the coils further away.
                        It seems the stronger part of the field is not close to the magnets.
                        Something else to concider.
                        Mark
                        • Cap dump
                          @ Mark
                          I do not know if you are using the Zenier,Capacitor,LED dump or not. If you are I have been able to change the Zenier combo and get it close to the charge battery voltage in combo with the LED (2.4 to 3volt LED) and then tune your Capacitance from there. I have used 4.7V Zeniers in series with others and the LED and get it real close. Retard your timing and you may find a sweet spot. Don't know if this helps or not but thought I would put info out there...
                          • Hello everybody,
                            I'm just a humble soul from Norway, watching all the fantastic knowledge and great spirit here in this thread. I have read them all,(1137 postings) multiple times, and seen as many videos, related to the subject, that my time will allow.
                            I'm about to start building a 1/3 scale Bedini Ferris wheel for myself. And I want you all to know what great inspiration you all are giving out! You have really got me using my brain!
                            Special thanks to Mr John Bedini!
                            I have one question for John_K, seeing your build, great work by the way, but thinking, you are in the southern hemisfere. And if you think about shaping magnetfields, we know you have your coils "upside down" and it works great.
                            But, would I be way off thinking you should have your magnetshield upside down too? Attached to where your core sticks out of the bottom, pointing downwards. Only then are you truly shielding "one" pole.
                            Or maybe building everything the "right way" and instead using south poles on the wheel and let it spin clockwise. Ofcource adjusting slave coils accordingly to have the right timing.
                            I'm probably way off, but just needed to get that off my mind ;-)
                            My english is not the best, but i hope you understand.
                            Best regards from Norway
                            Erik
                            • Bedini S1GT
                              Hi Erik,
                              Your English is great, no problem understanding your question.
                              Currently, I'm testing some things out with a solid state version until my parts arrive. But when they do I will experiment with the shield as you suggested on the rotor version.
                              I will also experiment with the way John B has his setup for the Northern hemisphere, just to see what difference it does make.
                              All the best with your build.
                              John K.
                              Originally posted by erikbuch View Post
                              Hello everybody,
                              Erik
                              http://teslagenx.com
                              • b
                                Hi Chuck,
                                When you say to retard the the timing, do you mean to adjust the timing so that the main coil fires before or after TDC? I will test both ways, but just wanted to clarify that.
                                John also mentioned that to me, but I haven't been able to test this yet because I let the smoke out of the parts.
                                John K.
                                Originally posted by chuck H View Post
                                @ Mark
