Originally posted by Aaron
The amount of energy in the spike is invariably some fraction less than the input. But if you work on one third of the input you've way understated the actual return. But work on that number. You'll already see a gain that goes through the roof. Can you get a scopemeter that can determine that energy on a dc coupling? Otherwise - can you just measure the voltage rise on two batteries - as I've explained. One battery to run the test. A second linked only at the negative terminals of both batteries. Then take voltage readings of the second battery. I promise you - you will see a dramatic recharge at low duty cycles. And there will be no evident decrease in the output over the resistive load. Try using a light for the resistive load to show this.
