This is a sticky topic.
  • t-rex
    Originally posted by Logical American View Post
    Wouldn't that station notice a sudden power drain?
    The receiver consumes power from the transmitter, it would show on the plate current meter if large enough. It's not free.
  • madhatter
    Theory of Phases, Triple Sequence Systems
    (1) It is common belief that Tesla "invented three phase" A.C. power. This belief is wrong. Tesla envisioned poly phase power quadrapolar, relating to Goethe, the sunset and the archetype called the solar cross. This is is consistant in all Native American art forms. We have four seasons, or now, four phases, just like the moon.
    (2) The decision to employ the "Tesla System" for use in the Niagra Power Project resulted in the installation of Tesla four phase alternators, these constructed by Westinghouse Electric Co. It came to pass however that the transmission line from Niagra to Buffalo was a three phase line (11 kV) constructed by General Electric Co, the Steinmetz company. In order to interconnect the four phase system with the three phase system, a special transformer bank was developed. Westinghouse engineer, and Tesla's co-worker, Charles Scott. This gave birth to what to what is known as the Scott Connection and is widely utilized.
    (3) The theory of phases involves the theory of number systems. Recently the number systems of protocultures such as the Chaldean system was touched upon. Let us use it as an example of a number system. The Chaldean system is a base 9 number system, and its poly phase diagram is an equal-lateral nine sided polygon. Its symbolic expression is the ninth root of positive one, and it's versor operator is k, of base nine and raised to the n power. Thus the Chaldean system is expressed by n:
    0, 3, 6,
    1, 4, 7,
    2, 5, 8,
    and nine equals zero. In the related Kabalistic system it is:
    1, 4, 7,
    2, 5, 8,
    3, 6, 9,
    It is not a versor system. In genereal the nth root of one is one to the one over nth power. Hence the table:
    1) Monophase, one over one power
    2) Two phase, one half power
    3) Three phase, one third power
    4) Four phase, one fourth power
    5) Five phase, one fifth power
    6) Six phase, one sixth power
    10) Ten phase, one tenth power
    And ten phase is our basic Arabic number system:
    0, 5,
    1, 6,
    2, 7,
    3, 8,
    4, 9,
    And of course two phase is binary:
    0, 1
    (4) If the power system has a neutral, or "Electrical Center of Gravity." This system has one more wire than those used as phases. Hence for two phase like into your house, (mind virus - it is not single phase, single phaseis the Tesla one wire system) the 240 Volt phase pair is split into 120 V/120 V, and the two wire system has three wires. Likewise for a three phase system with a neutral there exists four wires at 120 V and now instead of 240 Volt the line voltage is 208 Volt. The square root of three is the factor. More wires than phases is best avoided, but has becom fashionable today in most electrical systems. But it has come to pass that today's electrical systems have become problematic and also unsafe because of the improper use of neutrals.
    (5) It is a consequence of multiwire T.E.M. transmission systemes that a number of conductors greater than the number of phases gives rise to parasitic modes. In telephone work they are called longitudinal currents, in audio they are called common mode currents, in power, zero sequence currents, and in radio, antenna currents. They are undesirable in all but the Tesla monophasic or one wire transmission system. Here the neutral is the neutral is the only wire.
    (6) In these n plus one systems with neutrals, for a balanced non linear load (flourescent lamps, and switching power units, etc) the neutral current is not zero but consists of a harmonic system of currents. The order of harmonics is based upon the number of phases:
    One phase, F
    Two Phase, 2F, 4F, 6F, ...
    Three Phase, 3F, 6F, 9F, ...
    Four Phase, 4F, 8F, 12F, ...
    Hence considerable kVAR harmonic power can develop in neutral bearing power systems. Further, the harmonic currents are all in phase, or flow all in the same direction in the phase conductors. This gives rise to undesired E.M. radiation from the electrical system. But this is the system of today.
    (7) Take for example a three phase motor, 60 cycles per second. The rotation is clockwise for 60 cps.
    60, clockwise force
    120, counterclockwise force
    180, longitudinal, zero force
    240, clockwise force
    300, counter-clockwise force
    360, longitudinal, no force
    Hence, it is seen that harmonics cause conflicting torques in polyphase A.C. motors. And the zero sequence waveform is:
    180 @ one third 1F amplitude
    360 @ one sixth 1F amplitude
    540 @ one ninth 1F amplitude
    Etc @ one nth 1F amplitude
    Try graphing this function so we can see a triplen harmonic wave like the one infecting the "Grid"
    odd numbered multiples 3,9,15,21 etc... in phase, ohh that's going to a be problem on the neutral wire!
    it could be mitigated with a delta-delta connection right? putting the DC source within the load.
  • t-rex
    0, 3, 6,
    1, 4, 7,
    2, 5, 8,
    1, 4, 7,
    2, 5, 8,
    3, 6, 9,
    0, 5,
    1, 6,
    2, 7,
    3, 8,
    4, 9,
    0, 1
    One phase, F
    60, clockwise force
  • lamare
    Originally posted by Web000x View Post
    You can see the original scans here: Directory contents of /David/
    I added a gallery script, so you can browse the scans a bit easier:
    Single File PHP Gallery
    Furthermore, I made a new prototype for my moonbounce antenna, because the first prototypes were a total disaster. Now I made a dipole instead of a 1/4 lambda whip, and that one appears to work as specified:
  • Lambda
    DC Impulse Wave vs Oscillating Current Wave
    Greetings Eric and the Group,
    I've been lurking on the EG forum for some time, but am the one who posted the photos of your "Cosmic Induction Generator" as well as the plasma in the burnt out street lights that generated galaxies and marine life-like manifestations that Tom Brown gave to me in the yahoo group some time ago. I've learned an astonishing amount of information from your posts Mr. T-Rex and really appreciate you taking us under your "paw" and teaching us. I want to assure you that you are NOT wasting your time, good things will come of this! I promise to do my very best and will do whatever it takes to attempt to build a working TMT!
    I wanted to inquire about something that Gerry Vassilatos wrote in his "Secrets of Cold War Technology" book, on page 32 he mentions the pulsating DC with "no reversals of any kind allowed", but if I understand correctly, your TMT generates Oscillating Currents, which would go below the zero volts line, as you describe in your video with Chris Carson about 9 minutes into it when describing the impulse wave as well as the oscillating current wave, which you state was the one utilized by Tesla. According to the writings and researches of Mr. Vassilatos, I get the impression that Tesla was utilizing the impulse wave and that this is when the "real magic" happened, but you state your TMT utilizes the oscillating current wave form. I just wanted to have a complete understanding if possible. I obviously believe the man who has built the apparatus, the true Tesla Transformer, and believe you 100%. Can you give any insight on the usefulness of the impulse wave and if Tesla used it and how? I'm simply looking for clarification if and what application this impulse wave was utilized.
    I am an avid ham operator and have built my own Tesla coil (the type you refer to as the cardboard tube variety, although I used 4" PVC) and have also built the "Hairpin circuit", which does shatter ohms law as far as I understand it. I still cannot explain or understand why that hairpin circuit lights a 300 watt halogen bulb even with the circuit being shorted across the bulb. I have gathered all of the necessary parts to build the pancake coils arrangement and am working on that now since I finally have my own house and a pole barn that is my new lab. After the pancake coil I intend to replicate the TMT if it takes me the rest of my life, but am shooting for this spring / summer.
    I built a crystal radio back in 2006 that utilized a germanium diode (as they take 0.3 volts to forward bias rather than the 0.7 volts required of a standard silicon diode), and used a high impedance piezo transducer glued to a funnel rather than high impedance headphones, and I could literally hear that radio on the other side of the house, it was very impressive indeed! It was connected to a good 8' ground rod and a center fed 102' wire dipole (at my previous residence). Living in Illinois SW of Chicago, WLS has a very strong signal here at 890 kilocycles / second.
    I've donated in the past and will have another donation on the way in a few days. Again, thank you for all your hard work doing the writing and thanks to jpolakow for everything he is doing getting the information on the net.
    Where I live now, I have a 56' free standing tower with a tri-band yagi and wire antennas which go down to 160 meters, but it is nearly pure sand here, and although I have 4 X 8' ground rods pounded in at the tower, which seems to work great for conventional transverse wave RF communications, I know I need to do much better than that to get the intense ground system you speak of to continue in the right path.
    Again, thank you and jpolakow for all the hard work to keep the great information flowing! Everyday I look forward to all the new posts and the new information to absorb!
    73 DE WX9HV (previously KB9UBZ)
  • Sputins
    Council:
    Tesla:
    Council:
    Tesla:
  • the...dude?
    Tesla's System of Concatenated Tuned Circuits
    Here's a great reference for some of the "wireless" inventions and apparatus of Tesla:
    Wireless telegraphy: Its Origins, Development, Inventions, and Apparatus
    Charles Henry Sewall - 1903 - 229 pages
    From page 48 of the above book
    From Electrical Experimenter, "The True Wireless", 1919, page 29
  • Logical American
    question
    Crystal Sets Gone Wild
    ... Concluding, a Tesla Magnification Transformer, properly proportioned can, in theory, actually draw power from a local 50 kW station. Several hundred watts of power reception is likely.
  • Aether84
    eric dollard on tesla
    audio video - Eric Dollard on Tesla Wireless Technology
    Eric Dollard on Tesla Wireless Technology Pt1 - YouTube
  • t-rex
    For the diagram shown the coil dimensions are missing, number of turns, etc. A good ground is essential for these kinds of devices. 16 Ground rods in a 10 to 20 foot radius circle, connected to a single ground rod at the center(17th rod), this connection being 10 gauge wire. Dry sand or rock will not ground, so this requires 80, each 14 gauge wires in a 30 foot diameter circle in a star radial configuration, to a center terminal. Without these groundings a Tesla Transformer cannot properly operate, but some "HI-Z" sets may.
    The objective here is to scale the "Crystal Set", a step at a time, into a Tesla Transformer for the reception of medium wave band, 300 - 3000 kilocycle A.M. broadcasts. No license is required for this and the broadcast station provides the power.
    And this objective cooperates with the primary objective. That is; Who will be the first ham to disprove Einstein's theory? An International contest, but who will sponsor it, Iran maybe?
    We have the good fortune in the "Crystal Set Initiative" that, in theory at least, a quarter wave A.M. broadcast tower, and its 120 quarter wave ground radials, must emit a pair of waves as shown by Tesla in his basic diagrams.
    Hence it can be seen that a pair of waves are engendered by this transmission system. (Tower and Star Radials). One wave, Hertzian, is the over ground wave, the other wave, Telluric, is the under ground wave. These two waves arrive at the point of reception in their own distinct time frames, giving rise to a difference in phase. Hence, multiple rings of interference patterns are produced. Since the Hertzian portion, over ground, time frame is based upon the velocity of light, then the Telluric portion, under ground, time frame gives the Telluric velocity. Two crystal sets, one over ground, one under ground, and a basic oscilloscope , that simple. I have done this at Landers.
    Concluding, a Tesla Magnification Transformer, properly proportioned can, in theory, actually draw power from a local 50 kW station. Several hundred watts of power reception is likely. This would prove Tesla once and for all. No antenna, just a good ground, and a nice and bright 100 watt light bulb.
    This would overturn physics more than any billion dollar C.E.R.N. project. A ham radio operator overturns Einstein for 100 bucks. What a concept.
    Read,
    Tesla, "The True Wireless"
    Tesla, "System of Concatenated Tuned Circuits"
    Dollard, "System for the Transmission and Reception of Telluric Electric Waves"
    A.R.R.L. "Radio Amatuers Handbook". Chapter "H.F. Transmitters, & Tank Circuits"
    73 DE N6 KPH
  • Logical American
    Nikola, Telsa - US Patent 568178 "Method of Regulating Apparatus for Producing Currents of High Frequency" to reference "See Nikola Tesla, "System of Concatenated Tuned Circuits", patent number unknown"
  • jpolakow
    Tesla Coil
    Eric asked me to point out the Tesla coil pictured in the fractal discharge(which Eric built), compared to the original picture of the Tesla coil in Colorado Springs.
    Here is the discharge:
    And here is the Colorado Springs version:
    Look at it and notice the similarites, make a visual comparison. Same number of turns, same width to height ratio. The pictures speak for themselves. The coil pictured sitting next to Tesla inside the fence is called the main coil, or the "Extra Coil". The primary and secondary coils are the fence, 51 ft in diameter. In the "Extra Coil" it is critical that the length and the diameter are equal.
    Now notice a second picture of Colorado Springs:
    Notice the tall, slender coils to the right of the picture, we will term them "cardboard tube" coils. This is a primary source of misinformation about Tesla coil's existing today. The "Extra Coil" in the left of the picture is the one doing all the work. The Arc Discharges would be there regardless of the "cardboard tubes". The different height cardboard tubes was Tesla dealing with different frequencies and harmonics, they were called Test Coils.
    Pictured below are people making a Tesla coil WRONG:
  • Kempis
    A question
    Thanks to all for the contributions in this thread and thank you Eric for all you are doing for us.
    I have a question:
    I have a transmitter with a power of 10 watt.
    The receiver of the post 212 is tuned to the frequency of my tx.
    The minimum power to operate the headphones is 100mW.
    How many receivers tuned to the frequency of my tx can receive my signal at the same distance and at the minimum power (100mW on the headphones)?
    Kempis
  • t-rex
    Fractal Discharge
    From "The Lakhovsky Multiple Wave Oscillator Handbook", Thomas Brown
    This photograph is a pulsed discharge from my magnification transformer. It discharges into counterspace, away from ground into itself. Its form is golden ratio log periodic, a 5 phase fractal.
    Note that the discharge is much longer than normal for 30 KiloVolts. It discharges into itelf carrying it onward.
    The board is the result of many pulses (seasons) over time, creating a Golden Ratio Log Periodic Form, or five phase fractal.
  • t-rex
    From "Electric Waves, Discharges, and Impulses", C.P Steinmetz, p67
    Relation of Magnetic and Dielectric Energy Transient
