TUBE DRIVEN TPU'S The construction zone
    I remember seeing a patent that used a toroid with windings on the outside and inside of the toroid, cant remember who the patent was by, it wasnt posted to long ago.
    Maybe MM will remember.
    check here ...Farmhand's amazing work
    • Originally posted by willy96 View Post
      i have ... around quartz .... lol then rang the crystal via jt ...
      W
      W , this got me curious...was there any peculiar effect....or a video link to that experiment
      from: http://www.energeticforum.com/renewa...netism-41.html
      HUTCHISON effect: lapis exillis - crystal energy conduit. - YouTube
      HUTCHISON effect. Quartz Crystal HIGH VOLTAGE Resonator - YouTube
      HUTCHISON effect. Quartz Crystal HIGH VOLTAGE Resonator with DC POWER SUPPLY. Resonance Cascade test (vibration as well as hi voltage).
      • i have played with crystals a bit ...
        never put it in water the crystal was a ISIS 5 point crystal .. lots of things can be done with crystals .. lots!!
        i banged a laser into that crystal.. whitelite resonance rings the quartz .. i have some videos messing around with them online somewhere you cant see it via human eye really well but fourntinally i have a dv cam with night vision and it see's what we cant !!
        i have the basic design layed out for a scalar radar dector dector .. lol
        and quantum comummications ! via tuned crystal and 3 freq carrier wave ..
        i have nano quartz aswell ... and i have dipped leds in it ...
        and i played with other special rocks .. of all sorts
        i solved the TESLA SHEILD a few years back too ...
        so whatever i think what i have choosen to do public is what is needed first !
        a sutiable means of chargeing caps !
        from there the door is wide open ..
        aa nst rectifiers .. this is prime realiestate ! with the use of this device its a whole new world ..
        or out of respect for tesla we could build his
        ozone conversion transmitter !
        W
          http://www.energeticforum.com/renewa...enerators.html
          this is why i never answered him at first ... and why i caution people i come across dumb ..... and i like it that way
          W
          here is an oldie but a goodie .. built it along time ago .. tought me much ... what goes around comes around
          since you need proof - YouTube
          • Originally posted by RAMSET View Post
            Willy
            We are playing with AC and Alum/stainless Tubes in the water on The Davey thread
            When Gordon Posted that I felt it had relevance but I don't understand yet How??
            Have you played with AC Coils and water??
            I also want to Try Gordons Caudasious coil and Quartz in the water?
            Chet
            ac and water nope .. i have not played hho in years .. but i will agin messed with electrolisis with the PM's other than that left it alone ..
            well we can figure it out in no time .. yes Gordan has made many good points !
            freezing a ringing crystal should prove intresting ..
            W
            • I wanted to post this along Dave's Picture :
              caduceus air core
              Nothing is at random Fellow Telestai
              • looks great ...
                hope your ready tanks full agin ....
                W
                • Vop Here We Go
                  VOP
                  i will now atemp to explain overunity and a supper simple way of acheiving it !
                  this is deep and child simple all at once ...
                  so what hapins when you run out of wire ...? you send a signal a pulse down a wire the end is open its a bradcasting point when the signal reaches the end of the wire exactally what takes place ... ?
                  ok vop is the speed the signal is sent .. so if the wire was copper it takes "X" amount of time to travel
                  when we look at radio waves and eather broadcasting .. all is based upon the speed of the eather or the speed of electricty in free space the mesurement system vop is based on the speed of light in free space ..
                  so what im saying it simply put is this ... if at max speed for copper a signal is sent say its 60% vop the speed of light ... when that signal exits the anttenna it will gain in speed..
                  hear that ? maybe this IT WILL GAIN IN SPEED !!!!!!! TO MATCH TRAVEL SPEED OF THE NEW MEDIUM IT NOW TRAVELS ...
                  now we sent at 60% half way through tranmission its 100% radio wave in free space .... so we have gained 40% of sum for free so now on the other end where you like to recieve the package you sent if you could harvest the sent item at 90% vop via a conductor you have a much larger gain on recieving end ..
                  this is simply put and constructed by diffrent metals ...
                  to allow yourself access to a higher energy this device is not designed to run 1/4 res... this takes another aproch to tapping energy that is free
                  simply by understanding VOP
                  W
                  • silver and the magic
                    silver is desired for best conductivity . lowest losses cheepest of all pm's
                    all i have said is easly proven true .. via VOP
                    so if on the reciever all wires were silver and tuned to a certain freq .. i would eapect so see extream results tranmisitter could be copper and iron.... max speed is say 60 % vop then iron is slower whatever the speed ... the excess between the 2 is over flow used to self sustain the transmitter ..
                    current could easly be made more by adding additonal rings .. to the stack
                    sounds so TPU
                    dont it ...
                    W
                    • Goose bumps
                      Gordon thats uncanny
                      The Coil in the water and the Turtle!??
                      Chet
                      BE that change !!
                        Chet
                        *Sigh
                        Its not a turtle...its a Scarab Beetle....ancient Egyptian
                          sounds so TPU
                          dont it ...
                          W
                          so to visualize i will atempt a crude text art ....
                          000000000000000000000 current ring #3
                          000000000000000000000 current ring #2
                          000000000000000000000 current ring #1
                          0000000000000000 feedback self sustain ring
                          transmitter
                          ali coil
                          harddriveplatter harddriveplatter
                          speeker magnet
                          now squish it ...
                          W
                          • you know i can keep talking of many ways SILVER IRON AND COPPER can be used with VOP
                            like for instance ...
                            iron from source to limit flow ... spark gap as its a broadcast point and a point of eather interaction connect to copper .. we gain speed via gap from eather as i just explained so
                            say it left source at 20%vop to gap hits 100% enters copper at 60% we at gap have over spew rf noise ... tap it there ..... signal leaves copper to antenna goes from 60% to 100% it is now in free space .. reciever is say 90 % we harvest!
                            and the bulbs glow ...
                            W
                            • just remember for any of this we need our suitable source to charge a cap ..
                              then we need a job for that energy to do ... but without our cheep source of energy we can dream all we want .... but thats it is a dream ..
                              this is why the aa and nst ..
                              its ma G
                              W
                              my G makes dreams come true !
                              Resident Deejays---Master of Dreams - YouTube
                                W
                                Copper and silver Iron...interesting....Dave....Romo....
