  • MonsieurM
    If you understood the above statement , you'll understand the following
    just on a side note: the double spiral water closely resembles the double mobius coil mentioned earlier
    Step 1
    2 wires of six feet each to be made into 2 mobius wires (you end up with 2 mobius wires that are 1/4 the length of 6 feet )coiled at 45 degrees (see how to build a mobius coil Mobius Coil Tutorial )
    Step 2
    Coil the first Mobius Wire as previously indicated in a Caduceus Manner (three times / three crossing maybe )
    Step 3
    Coil the Second Mobius wire 180 degrees opposite of the first Coil
    Step 4:
    Connect as previously indicated http://www.energeticforum.com/renewa...-query-43.html start with post #1271
    enjoy the experimentation
    COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
    An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways
    . a harmonic cascade effect
  • MonsieurM
    I was wondering where the 6 went, in this system...60 hz...harmonic math 60 is 6
    42712.2 x 9 = 384409.8 Hz
    384409.8 x 3 = 1.153229.4 MHz
    I was just reviewing some numbers posted in this thread and started with
    an info posted by Prof Savic : http://www.energeticforum.com/renewa...r-query-2.html
    1.725mm electrode distance is 60 Hz. 300 Hz and the negative electrode has to play the sonic boil
    Reduction is one of the method used in Harmonic Math (also called Rodin Math )
    1.725 = 1 + 7 + 2 + 5 = 15 = 6
    60 Hz = 6
    300 Hz = 3
    I think 2.1mm was the space between the can and the ring so the ring should be 70.2mm
    2.1 mm = 3
    70.2 mm = 9
    I hope you see the Pattern...just find the 3 6 and 9
    last but not least:
    Early in this thread, Prof Savic wrote that the inside diameter of the beer can was very important because it had to be the quarter wave length of the frequency 1.1530479 MHz
    1.1530479 MHz = 1 + 1 + 5 +3 + 4 + 7 + 9 = 30 = 3
    I think you'll Appreciate this one:
    Sonic boiler are trying to make a 110 Volt 60 Hertz has a COP = 6.93
    What you supply area of the apartment, you calculate the width and thickness of the electrode, zero reba to resonate at 300 Hz. Fuse will die if you are using electricity for over 15 Amperes.
    300Hz = 3
    15 Amp = 6
  • MonsieurM
    Originally posted by Altair View Post
    Is mechanical 60Hz resonance more important , or is electric 1.15MHz resonance more important ?
    Altair
    Try the same operation for 50 hz....using the 5 2 8 triangle
  • MonsieurM
    the seven seals based of there respective Magic Square:
    Black Tourmaline
    Ruling Planet: Saturn
    Auripigment:
    Ruling Planet: Mercury
    Magnetite:
    Ruling Planet: Jupiter
    Moonstone
    Ruling Planet: Moon
    Copper
    Ruling planet: Venus
    iron
    Ruling Planet: Mars
    Quartz:
    Ruling Planet: Sun
    Btw: Searl Engine is based of magic squares Magic Squares and Levitation
  • MonsieurM
    so I figured I'd take a look at 369 Magic Square...found the following
    The numbers associated with the Moon are 9, 81, 369, and 3321. This is because: Each row and column of the magic square contains nine numbers.
    The square contains 81 numbers total, ranging from 1 to 81.
    Each row, column and diagonal adds up to 369.
    All of the numbers in the square add up to 3321.
    the Seal of the Moon: Planetary Seal of The Moon
    In the Western occult tradition, each planet can be represented by a seal or diagram. The seal is based off of the planet's magic square, with the seal theoretically touching every number within the square, although in practice that is not always apparently the case.
    As drawn here, the seal actually does intersect with every box of the magic square of the Moon. However. as commonly drawn, there are actually several squares that are not included.
    Like the seals of Mars and Venus, the seal of the Moon is based off a magic square with an odd number of boxes per row. Also like those two seals, this seal commonly does not include all boxes.
    However, the seals of Mars and Venus are asymmetrical, and while they bear many similarities with each other, they bear far fewer visual similarities with the seal of the Moon.
    It may be more helpful to compare the seal of the Moon with that of the Sun, as Sun and Moon are commonly seen as a pair as the great luminaries of the sky. Both seals are comprised of two large, intersecting diagonals, and both contain four crescent shapes. The crescent shape is particularly appropriate for the Moon, which frequently appears as a crescent in the night sky. The common astrological symbol for the Moon is also a crescent.
    Donald Tyson suggests that the 13 small circles in this seal may correspond to the 13 lunar months that are in a year. However, since he considers those circles to have only aesthetic value in the other seals, this may very well be coincidence.
  • MonsieurM
    Some of you may wonder where did the following come from:
    from the post: http://www.energeticforum.com/renewa...-query-43.html
    Water is a ready and fit subject for vibratory research on account of its "differential volume" and gravity of its gases. Even on simple thirds the differential action between hydrogen and oxygen causes antagonism and dissociation. The differential of mass is such that the hydrogen and oxygen become thoroughly repellant and thereby exhibit thousands of times more force than could be induced by heat on the same amount of water. Vibration of antagonistic thirds, sixths and ninths on the mass chord will compel progressive subdivisions and to get the best effect on water, the instrument is set on all of these. First, the focalizing chord of sixths induces perfect harmony to the mass chord.
  • MonsieurM
    Merry Celebrations To All During this Festive Time...And hope you feel the Good Vibe
  • MonsieurM
    From: http://www.energeticforum.com/renewa...-query-48.html
    Hi everyone,
    I'm new on this thread. I've read it entirely before posting.
    He said that the diameter of the can had to be 65mm.
    Doing the calculations, the wavelength of that frequency is 260.18mm.
    260.18 / 4 = 65.045
    Close enough.
    Recently, Monsieur M posted an excerpt from another web site that read:
    "But what you have to realize is that he left us a clue....Exploding water with 42712.2Hz...and Harmonic Math will definitely allow you to find the frequency to boil water"
    So I did a little calculation to see if there was a relation between the two frequencies. Let's apply the harmonic math to the frequency that explodes water:
    384409.8 x 3 = 1.153229.4 MHz !
    Pretty close to the frequency Dr Savic mentionned isn't it ?
    I did a search for the frequency he mentions but no results come out, except the forum pages here, and at O.U.R.
    So, my first question to him would be:
    Did you arrive at that frequency by the same calculations I did ?
    Second question is:
    How did you determine the optimum length of the can ?
    Could we obtain the correct mechanical resonance of the can with thicker wall and longer length ? (As opposed to very thin wall and length limited by what is available on the shelves of beer stores)
    Thirdly, I would like to know if the gap of 2.52mm has been determined also by harmonic calculations, and if it is based on 60HZ or its harmonics.
    I would like to thank you sincerely Dr Savic, for bringing the information on this technology.
    But in order to succeed, we must absolutely understand the principle by which this system works. Otherwise, we will never be able to build efficient replicas. The whole point of participating on this forum, and doing experiments, is to bring new knowledge to the world, and stop the suppression of efficient technologies.
    This water heater is the most promising simple technology at the moment, and if we manage to get it known worldwide, this will probably trigger the start of the real disclosure of free energy technologies in the entire world.
    Sincerely yours.
    Altair thank you so much for the calculations.... wow you made my day
    now unto the details about thickness, length etc...
    first of we have to realize that this set up is scalable (let's assume for now it is )
    from that statement above, you should realize that it is not about having a fixed size to succeed but the relation of all the component have to each other just like a musical instrument....a violin does not have the same chord as a guitar
    Sonic boiler a musical instrument not only heater.
    Because God is an artist not only a scientist.
    prof.Savić, Serbia.
    think of how you build a Resonant Circuit RLC or LC if you Prefer ( for the electronics wizard ) it takes a special combination to reach resonance
    Not all Resonant Circuits are alike and yet they are Resonant
    Electron for a moment lost in kavntnom [not translated properly IMO]
    field (leave this dimension)
    I think the word is Quantum field
    One last analogy
    Not all Spider webs are the same , and yet they still manage to catch flies
  • MonsieurM
    Oldest obsidian bracelet reveals amazing craftsmen's skills in the eighth millennium BC
    researchers have revealed the astounding technical expertise of craftsmen in the eighth millennium BC. Their skills were highly sophisticated for this period in late prehistory, and on a par with today's polishing techniques. This work is published in the December 2011 issue of Journal of Archaeological Science, and sheds new light on Neolithic societies, which remain highly mysterious.
    originally found here: Oldest obsidian bracelet reveals amazing craftsmen's skills in the eighth millennium BC, page 1
  • MonsieurM
    on a side Note: Worth testing the Mobius Caduceus Coil when Growing your Crystal cell
    called a super-coil. Supercoil
    DNA Coil
  • MonsieurM
    Sorry for the repeat ...but the following pictures taken from the painting kept bugging me:
    you have the double helix and Mobius like design present on the same drawing ...and the only design i know of that is mixing both is the following: The Mobius Caduceus Coil
    btw: I would really love (pretty please )to hear someone replicate the double Mobius Caduceus Coil experiment ..it is really simple...and heats water quite fast but i have no clue what happens...call it inspiration when it was built...
    Check out this thread, I am trying to get people to reproduce an experiment I ran a while back coincidently with another version of a Caduceus Coil...and the guys over there are doing an amazing job at Advancing our discussion....We welcome all the help .....
    you'll understand when you watch the vid
  • MonsieurM
    Have you also noticed the following from the painting:
    the double helix DNA
    is also a Caduceus Coil
    wanted to add the seven fingers in the light
  • MonsieurM
    from: http://www.energeticforum.com/renewa...tml#post172352
    Principle Of Mentalism
    Originally posted by purelyconstructive
    I would like to thank each of you for the interesting things that have been shared, and look forward to working with you all.
    Notes On The Works of Walter & Lao Russell
    Thank you for thelink to the doc:
    the following is from that doc:
    The Mind
    There is a continual emphasis throughout Walter and Lao's work upon the distinction between knowing and repeating. For example, one can repeat information without necessarily knowing its meaning or significance.In relation to this concept, the brain is seen as a recording mechanism for sensed experience, and the Mind, while acting through it, is distinct from it. Likewise, our senses are receptors for wave motion. They span only a limited bandwidth. We might extend this range with instruments like microscopes, telescopes, and the like, but they can also sometimes be deceived by motion.I'm sure many are familiar with the phenomena of seeing a pinwheel moving clockwise when viewed from one direction and counter-clockwise when viewed from the other, or how a fast moving object can sometimes seem to stand still. There are similar illusions for every sense(hearing, touch, etc.), and not just sight. This fact is extremely important to bear in Mind whenever we observe things, even with our instrumentation (such as in "Empirical Science").Only the Mind can encompass the whole spectrum, and in so doing, know the transcendental Causeof all manifest effects directly.
  • MonsieurM
    I have little "philosophical" thought about the term Overunity
    the reference Overunity is used on the basis of what we have today as examples...however, through our discussion, i realized that there are forces or combination of forces that are so subtle that we ignore them in our actual example of "efficient machine". How about we change referential and consider todays machines as "under Unity".......And Free Energy Devices as plain Unity Devises
    It just makes more sense for me and easily understandable and it is more Walter Russell-type of thinking...same for Alchemy
  • MonsieurM
    one more info on building a crystal battery
    Record conductivity achieved in strained lattice organic semiconductor
    "Strained lattices are no secret. We've known about their favorable electrical properties for decades and they are in use in today's silicon computer chips, but no one has been successful in creating a stable strained lattice organic semiconductor with a very short distance between molecules, until now," said Bao.
    And the Caduceus is here for that...one of its function amongst many others
