  • MonsieurM
    I have just recieved a Pm from one of our member, as i don't want to mislead him..I would ask you guys to do me a favor and give him the appropriate answer....much appreciated
    Hi,
    I need a device that can take my current input 220V 50Hz and give an output of 220V but on various frequencies.
    I can acquire following devices:
    - pulse generator
    (http://www.testequipmentconnection.c...ilent_215A.php)
    - signal generator
    - oscilloscope
    is any of these devices capable of performing needed actions?
    I thank you in advance for your answer.
  • MonsieurM
    From the same link
    In the I Ching it says: The steps therefore are states of awareness of the creative process within the body that is constructed in the 6 steps, and upon the attainment of the 7th level the sage allows universal wisdom (the law) to move matter, while he rests in a state of clear awareness in the 6 centres or Chakra of physical movement (the movement is on 384 lines of energy). The 6s and 7s are found in the 9 x 9 Magic Square of the Moon in which the constant flow of 10s gives the total of the integer pairing 1 to 9, 2 to 8, 3 to 7, 4 to 6 in each decimal step 1234(5)6789. The total of each expansion is given as an average value in 5 and the total of 10 + 5 = central values of the 5 Element or Direction (into which the 10 Cyclic Signs fit). The x 6 gives the value of The Binary Trigrams or Trines, the Binary expands = 124875(10 = 1 = 64)24875 in the bound-up Torus 1 to 10, as in 3 6 9 and 9 6 3.
    hope this shades a bit of light....pun intended
    The 3 Spirals of Change
  • MonsieurM
    The Math of the I Ching (or magic square if you prefer )opens The Well (Field Pattern) The This Field Pattern is then found in - The Grail Quest,
    the division of the waters (the moon rules the waters) the tyrant of darkness was overcome, as the light/energy rose-up within the Earth (matter) to create all things. The people (parts or forces of nature - demonic pantheon) were then able to inhabited the Promised Land (that was built or rested upon the Sacred Mountain). But to remind the people of the time of darkness and toil, at the time when the dark was full or greatest the people held the Ceremony of the Sacrifice (this being the Winter Solstice - the time of Return), and at this time they called upon and gave reverence to their Ancestors who had sacrificed themselves in order to give their children life. The feasted on the meat of the boar and pheasant, which was cooked in the vessel (Caldron), and they stood before the king who gave his judgments of the law.
    are linked to the coming of the light through the law of physics. The readings give a means to produce physical movement of the body through its lines of energy or Chi, which we view as psychology (in mind). The union is between the body (matter), and mind (energy), between water and fire, as through the law or will of Heaven all things are balanced in the middle point of observation - the single point of observation is the inner eye or single gate, as all opposite movements of duality. If the balance of created movement is not maintained, as it is not when the middle position is lost to our knowledge, nature swings too far against its opposite sides (sides of the Well - source) and then the vessel breaks apart. .
    if you read the Kybalion...you'll recognize the above mentioned statements
  • MonsieurM
    A bit of child like curiosity will take you a long way
    Remember to a Child Everything is Possible...because he has Imagination...to him the fantastic things seen on tv exist..and he will argue you on that..
    In other words:
    National Geographic Channel - IF. Live curious. - YouTube
    If you are, you breath.
    If you breath, you talk.
    If you talk, you ask.
    If you ask, you think.
    If you think, you search.
    If you search, you experience.
    If you experience, you learn.
    If you learn, you grow.
    If you grow, you wish.
    If you wish, you find.
    If you find, you doubt.
    If you doubt, you question.
    If you question, you understand.
    If you understand, you know.
    If you know, you want to know more
    And if you want to know more, you are alive
  • MonsieurM
    Originally posted by Slovenia View Post
    Thanks Gordon!! I must learn this secret of 3, 6, & 9.
    It is not really a Secret...It is more of an Understanding of a Concept....Think of it this way...Analogy...it is as if you are used to seeing light in a normal way then to change perspective you put on Night vision Goggles
    As evolvingape Said
    Sorry, but I cannot tell you the secret, I can only show you... you must find it for yourself...
    you'll have to learn to visualize your acquired knowledge under a different light
  • MonsieurM
    also within the same link:
    The 5 represents the Center and is called the Force of Life (Chi). Chi was called Ether in the West and Prana in India. Ether is called the Vacuum in Modern Physics.
    The Magic Square is a representation of a Topological Structure called the Moebius Ring. The Ring is a Cyclic Structure without a Boundary. The Ring is the Basic Fractal pattern. The Universe is a Closed Self-Referencial structure, a Spiraling Spiral. The Ring enfolds in a Ring and the Enfolding is a Ring.
    While researching this Tesla Secret 3, 6, 9 phenomenon, I came across Marko Rodin. He is worth checking out too. He is a very interesting chap indeed.
    here is a nice vid linking Rodin Coil and Magic Square : (was mentioned in the the golden tractate thread )
    lo shu Magic Square / solfeggio code Matrix Vid1 - YouTube
    also you may want to go here too:
    David Icke's Official Forums - View Single Post - The Vortex Maths - Marko Rodin Thread
    also this one:
    Lo Shu Solfeggio code. I ching to Ho Tu to math introduction. Sum of things.. - YouTube
  • MonsieurM
    Originally posted by replaced View Post
    Just because you can find patterns between things does not mean that there is any significance or information shared in those things.
    Was the painter of Mona Lisa concerned about electromagnetic waves when painting or was this a person just like you and me?
    Maybe I should make a painting and sometime in the future someone will think that I made the painting because I wanted to reveal code. But in reality I made a painting because I was bored and did not put any code in the painting.
    sorry friend if this does not resonate with you, but disagreement is part of our discussion...to answer your question about Mona Lisa ...i would look into the background of Leonardo Da Vinci
    "The Lips of Wisdom Are Closed, Except to the Ears of Understanding " The Kybalion
  • replaced
  • MonsieurM
    A little interesting background history:
    The Magic Square was given to mankind after the Great Deluce by a Mythical Entity, Half Man, Half Serpent. He came from an old civilization that was situated in MU. His Knowledge came from the Star System Orion (The Turtle).
    The Egyptian name of this Magical Entity is Thoht, Tehuti or Djehuti. The Greek named him which relates him to the number 15 (3X5) of the Magical Square. Thoth was the keeper of the Secrets of Osiris (The Planet Sirius). Thoth was the Moon-God and is represented in old paintings as ibis-headed with the disc and crescent of the Moon
    Nothing is @ Random
    The Old Chinese Masters made a distinction between the Square and the Circle. The Square was related to Human Creativity (Playing the Infinite Game of Life). The Circle was related to the Cycle and the Spiraling Spiral, the Fundamental Laws of the Universe.
    The meeting of the Square, The Game, and the Circle, Fate, generates Luck, Coincidence or Synchronicity.
    just have to pay attention
  • MonsieurM
    That was the easy part...now finding a clear pattern...any ideas
  • MonsieurM
    Check the numbers surrounding 2 ...you have 1 for 2.1 and 52 for 2.52..you still have 42 74 43 3 11 51
    Happy holidays guys
  • MonsieurM
    Some of you may wonder where did the following come from:
    42712.2 x 9 = 384409.8 Hz
    384409.8 x 3 = 1.153229.4 MHz
    from the post: http://www.energeticforum.com/renewa...-query-43.html
    Btw all the value necessary for building the Davey Sonic Boiler or The Doulble Caduceus mobius are found here
    so I figured I'd take a look at 369 Magic Square...found the following
    The numbers associated with the Moon are 9, 81, 369, and 3321. This is because: Each row and column of the magic square contains nine numbers.
    The square contains 81 numbers total, ranging from 1 to 81.
    Each row, column and diagonal adds up to 369.
    All of the numbers in the square add up to 3321.
    the Seal of the Moon: Planetary Seal of The Moon
    In the Western occult tradition, each planet can be represented by a seal or diagram. The seal is based off of the planet's magic square, with the seal theoretically touching every number within the square, although in practice that is not always apparently the case.
    As drawn here, the seal actually does intersect with every box of the magic square of the Moon. However. as commonly drawn, there are actually several squares that are not included.
    Like the seals of Mars and Venus, the seal of the Moon is based off a magic square with an odd number of boxes per row. Also like those two seals, this seal commonly does not include all boxes.
    However, the seals of Mars and Venus are asymmetrical, and while they bear many similarities with each other, they bear far fewer visual similarities with the seal of the Moon.
    It may be more helpful to compare the seal of the Moon with that of the Sun, as Sun and Moon are commonly seen as a pair as the great luminaries of the sky. Both seals are comprised of two large, intersecting diagonals, and both contain four crescent shapes. The crescent shape is particularly appropriate for the Moon, which frequently appears as a crescent in the night sky. The common astrological symbol for the Moon is also a crescent.
    Donald Tyson suggests that the 13 small circles in this seal may correspond to the 13 lunar months that are in a year. However, since he considers those circles to have only aesthetic value in the other seals, this may very well be coincidence.
    just try..and you'll see...slice the number (for ex 2.52 into 2 and 52 )
  • MonsieurM
    while doing some research, i found the following:
    MODEL OF A WAVE
    Fuller saw the icosidodecahedron as the model of the electromagnetic wave. (Synergetics 11, 1033.112). What is required to model a wave?
    The model must represent the electromagnetic properties of a wave, and 2-fold symmetry, which establishes the creation of two fields: electric and magnetic, can be represented by the icosidodecahedron. The two fields are perpendicular to one another, producing an electromagnetic wave which is perpendicular to both fields.
    The above design reminded me of a post made a while back here: http://www.energeticforum.com/renewa...-magnet-7.html
    Originally posted by Dave45
    Lets look at what happens when the two coils are perpendicular to each other
    I found the following which reminded me of your drawing: FREE ENERGY # 27 ELECTRICITY GENERATOR USING SINGLE MAGNETIC FLUX PATH (MOTIONLESS) - YouTube
    the reason it also caught my attention is that the next picture also looks similar from a Russian engineer-electrician Alexander Kushelevwe previously talked about here: http://www.energeticforum.com/153539-post454.html
    Btw: link to patent mentioned in the vid:
    ELECTRICITY GENERATING APPARATUS ... - Google Patents
    russian link
  • MonsieurM
    The frequency you would need frequency 528 Hz (DNA repair frequency ?) : NO MUSIC single tone - YouTube
    I believe it could be done, would be a worthwhile en devour, after we get FE I will go in this direction.
    Tesla found that the electric field healed the body, I probably read it in one of your posts
    found this here:
    Letters=numbers=sounds=colors=shapes
    Note: Purple corresponds to 540 hz
    holistic living center
  • MonsieurM
    Originally posted by evolvingape View Post
    Hi everyone,
    I believe I cracked the secret of 3, 6, 9, a few years back... some of you might recognise this
    I will not give you my explanation just yet, I want you to think about it for yourself and see if you can figure out what is going on...
    Merry Christmas 2011
    Rob
    nice finding evolvingape...
    ps: A fractal exist on multiple dimensions...so to be more precise you have discovered one facet of 369
    here is a 3D version of your finding
    vortex like, isn't it
