Tesla's Magnifying Transmitter "Replications"
  • Farmhand
    Thanks Slider, It takes a lot of work to wind one of those, I'm doing another one
    very slowly this time. The primary circuit for the Tesla coil could be much better.
    I think I've thought of a solution to blow the gap I have with air, I just need to
    drill a hole in the orange tube directly below each gap, then block one end of the tube off or
    (cap it) so I can force air in one end via a tube and out the two holes to blow
    out the sparks, I maybe can even cause a rhythm with it, turn it into an instrument.
    If I use a fan to force air through a tube with holes in it like a flute then to
    the spark gap when I cover the holes in the tube the pressure will increase
    and the flow of air blowing the gap could be varied like that. Maybe I can play it like a bagpipe.
    I like the pipes in this clip, they're bangin. I'd like to play that tune with a coil.
    AC/DC - It's a Long Way To The Top (If You Wanna Rock N' Roll) - YouTube
    I can run the setup from 120 volts if I adjust some things with
    what looks like almost the same length discharges at the terminal but they are
    less often (slower).
    Yeah it's a fourex can, I don't drink alcohol though so the beer went down the
    sink. I don't condone drinking while driving HV coils.
  • Slider2732
    The converter coil is a work of art, looks great
    There's so much Patent work in your videos, truly inspiring for own builds...and a can of Castlemaine I see for plasma discharge. That's if it is XXXX.
    Enjoyed the video.
  • Farmhand
    I done some modifications so now the setup looks kinda like this.
    Video clip explains a little bit. My next modification will be an improved spark gap
    that is adjustable and quenched either by magnetic quenching, blown air or both a rotary spark gap would be good but bulky.
    Tesla Transformer - setup.wmv - YouTube
  • Farmhand
    Hehe, yeah poor thing. I thought it would fly away.
    One insight that using a low frequency supply does give, is it shows where
    the leaks are most likely and what is effective to suppress them. I need to
    improve the Earthing which might help. After thinking this morning I'm
    wondering if doubling the copper in the capacitor rings might help, my
    resonant frequency is a bit high at 1.1 Mhz so the extra copper might lower it
    a bit. The extra coil can be easily adjusted by spacing the turns differently or
    even removing some wire. I'm going to put a tuning coil of a few turns below
    the secondary as well. I also will cut an aluminum plate to fit under the deck
    below the primary for a ground plane which should help. If the coil is too close
    to the the LV supply converter circuit it won't work, I need 2 meters at least.
    The only things that get hot are the two mosfets and the 12 volt supply
    wires, I had to remove the fuse because the housing melted. I've got a 30 amp
    auto breaker instead now.
    Suspending things in the air without creating a path for arcs is difficult, the
    plasma forms and holds in the nooks which supports the arc formation. Even
    inside the wood. All the wood needs to be sealed or something.
    It's very interesting to experiment with but I can't light the bulbs as good as
    dR can, I think the higher frequency supply helps with that, I get arcing inside
    the bulb while it is trying to light up so it limits the brightness, maybe a cap
    across the bulb would help.
  • dragon
    Impressive Farmhand... I have to say I can't remember a time when I laughed so hard... poor fly.... never knew what hit him...
  • Farmhand
    Hi guys, I have some video of one of my setups so far. This arrangement has 1 primary turn 40 secondary turns and 126 extra coil turns.
    In this video I'm just showing some effects of trying to contain the energy with a low frequency supply and show the way I put it together.
    I still have some adjustments to make and experiments will continue.
    Video clip. Warning: A fly is executed in this clip (Graphic images) viewer discretion advised.
    Tesla Transformer effects with 130 watts input - YouTube
    Piccies
  • dR-Green
    Originally posted by Sputins View Post
    Flat Spiral Coils under construction.
    Replication attempt of Eric's coils in Tesla's Longitudinal Electricity video.
    20.5 turns (2 x 10 + .5) of RG178 cable. Total length 25.6 meters. (2560cm).
    Image coil (reflection of first coil, also near finished)
    Primary two turn coil, will be same total surface area. (Under construction)
    Have the two 1b22 hydrogen spark gaps
    Will post further progress.
    Using this to practice posting images.
    Very nice Do you have any results?
  • Sputins
    Originally posted by quantitant2011 View Post
    Please concentrate about true theory of quantion. thanks
    WHAT?!
    Why?
  • quantitant2011
  • Sputins
    Under construction.
  • soundiceuk
    An interesting video I found using the technology to push the boundaries.
    H2O wireless electricity II.wmv - YouTube
  • epwpixieq-1
    Please ,back to reality ! We are in need of solutions to common day problems like heating our homes and cooking dinner.
    There was very interesting discuss recently in overunity.com thread about Kapanadze device. I think we can just use two grounds or two metals connected in open circuit and push pull charge between them at very high voltage without depleting charge from Tesla magnifying transmitter.
    One ground may be just piece of metal like metal container. User Znel from OU.com posted very valuable informations.
    We are looking for electrical replacement of this effect : electrostatic induction - YouTube (from 5 minute up)
    I posted an (interesting) observation on Kapanadze's device thread:
    Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
    It connects several Tesla patents (787412, 645576, 649621, 685953, 685955) about power transmission through the natural mediums and Kapanadze's device (KD) . In my opinion KD is one part of (the 2 parts) Tesla's system for power transmission - the receiver. The device is tuned to capture vibrations naturally existing in the earth, as a medium for containing electric vibrations. As Tesla stated with his own words: "When the great truth, accidentally revealed and experimentally confirmed, is fully recognized, that this planet, with all its appalling immensity, is to electric currents virtually no more than a small metal ball and that by virtue of this fact many possibilities, each baffling imagination and of incalculable consequence, are rendered absolutely sure of accomplishment; "
    As I stated in the post, it appears that 3 are the important (conceptually) parts, 2 grounds, 2 adjusters ( parts/device that adjust the frequency ) and a condenser (of considerable electrostatic capacity as Tesla states). There are some suggestions about the role of the spark gap(s), and I can see the role of an extra coil, to increase the pressure, but they are important for the implementation, and not so much for understanding of the idea. My post was about the IDEA that Tesla patented and, in my opinion, the connection to KD. Ones the idea is captured/understood there seems to be, technically, many arrangements to implement it, of course with considerable attention to the details and with incremental the cost of testing it. And this is what Kapanadze apparently has done.
    The concept that the charges are on the surface of a conductor ( in the video posted ) is quite a prehistoric one (this is not to disregard the concept but to point of a different way of thinking about it), as Steinmetz notes in his book: Elementary Lectures on Electric Discharges, Waves and Impulses, and Other Transients ( p. 13 bottom and p. 14 top ) the entire Lecture II "The Electric Field" is worth reading and re-reading.
    Hope these notes help to someone.
    It helped me see the world in a different way and to glimpse, in my understanding, Tesla's "Wheelwork of Nature".
  • dR-Green
    The way I feel about it, if I could delete the whole thread with dR's agreement I would do it.
    I hope that won't be necessary. For one thing, although maybe that's a part of the problem, this has served as an online notebook for me at least, it's a big record of various thoughts and ideas and quotes from various Tesla writings etc. I'd say it's a good resource from that point of view. Also as with philosophy the same applies here - to know what's right you must also know what's wrong. I've learned a lot in the course of this thread. The most recent thing being the difference between the low voltage and "real" methods of powering it. The "real" method seems even easier, it doesn't have the complication of tuning the primary by number of turns, so all the better
    Anyway, I've been planning for a while of starting a new thread AFTER all this stuff had been figured out, perhaps with careful consideration of the thread title The idea was, since this thread got so big, to just post all the relevant findings and design of a coil in the first few posts so it's all on the front page and easy to find. I see nothing wrong with documenting "incorrect" things, especially if it includes the fact that it's "incorrect" and it's all experimentation. Isn't that a part of science and experimentation anyway, knowing how not to do something through experience?
    Back to the original subject at hand, I spent a few hours last night doing calculations for a 1/15 scale 1 metre diameter Colorado Springs coil. Provisionally with 333m total of wire, 111m 1/4 wave secondary (35-36 turns with approx 4mm spacing), 222m 1/2 wave extra coil - equal diameter to height ratio, size is to be determined depending on wire length and number of turns. When these are built I will use the regular method of finding the resonant frequency of each coil and then tweak them accordingly. Although the wire lengths may be drastically out with the effect of the terminal and condenser across the secondary as in Fig. 4 of Colorado Springs Notes page 185, so these things will be determined through testing since I have absolutely no frame of reference for such a thing.
    And happy Christmas
    [edit] I will also build some jig thing of an appropriate diameter so the circumference is exactly 1 metre onto which I can wind wire from a spool, and so 1 turn = 1 metre of wire, so this will make measuring the wire length much easier and more accurate.
  • boguslaw
  • Farmhand
    Hi all, I propose we stop posting in this thread for some time, so as not to
    inflame any delicate situations, I for one don't want to be blamed for "driving anyone off"
    or escalating any delicate situations.
    It occurs to me that the mere appearance on the front page of this thread could
    annoy some people. So i will be posting in other threads for the time being.
    It seems the "replications" in inverted commas wasn't enough.
    And start another thread with a different title. Many of us have had a hard
    time in life, some have had their stuff taken from them, others have had their
    physical well being taken from them. Some of us are in real bad shape,
    suffering incredible pain daily, without much help.
    Many of us have good reason to "hate the world". But don't.
    It also occurs to me that if what I am doing is so far removed from Tesla's work
    and I am misunderstanding what I read anyway then everything I am doing
    must be my own work. Sounds logical to me.
    So I will be making my post's in other threads and trying not to write anything
    inflammatory. I reserve the right to post what i think is interesting and my
    opinions on it.
    P.S. A happy and safe holidays to all.
