bye bye bye
What is the Vacuum? And how does energy come from it?
Electrical World At All: Electromagnetic spectrumThat means space or the "vacuum" is filled with an unimaginable amount of energy at every point.
An astronomical amount. Just like a cook you will need to find the right combination of ingredients to make a certain recipe.
"radio waves at 60 Hz may be received and studied by astronomers, or may be ducted along wires as electric power."
Seeing how this is the first "machine" in recorded history I think its configuration is significant. Two toroids intersected. I think this was just a communication device. From the description there were 5 devices and a bright light emanated from 4 of them. When the one without the light moved,the others moved in unison. ElectroMagnetism or a variant? There are a multitude of light frequency combinations to make white light. If you divided or marked each electromagnetic frequency on a string,then the string would be thousands of miles long. The visible light frequencies would only be about an inch long on the string.
Walter Russell Diagrams
Hi Pengrove, In my opinion the term "Vacuum" has never been properly defined so I tend not to use it. I prefer to use the proper term "Aether" but that is just my preference, "Backround Energy" is even a better term, there is no need for there to be a vacuum and the term does more to confuse than enlighten. It's use should be discontinued because there is nowhere in the universe where nothing exsists. Just try and prove that statement wrong.
I was wondering if you could tell me Pengrove. What is the source of the Walter Russell diagrams you showed in this this thread ? The one's that are not found in the "Universal One" I mean.
I take it you are also aware of the connection between Otis T. Carr and Walter Russell.
I wonder what happened to the Learning Institutions Walter and his wife were supposed to have setup.
This info and the possibilities arising from the principals put forward by Walter Russell have been heavily suppressed. Tesla used the some of the principals he gleaned from Walter to produce usefull device's.
It is my opinion that the two were of similar brilliance but on slightly different tracks. The principals we need to harvest free energy from the Aether are all covered by Walter and some were put into practical devices by Nikola and others. He may have missed some stuff because I guess nobody is perfect.
A new concept of the Universe is a great book. So is Atomic Suicide. The Russell enlightenment courses are still available.Originally posted by Farmhand View PostI was wondering if you could tell me Pengrove. What is the source of the Walter Russell diagrams you showed in this this thread ? The one's that are not found in the "Universal One" I mean.
A word I got through a very good source to me said that the courses are for now. They are for the time when man wakes up and decides to seek enlightenment. Lao said that we will turn to the information when the weather gets severe.
I am here to make sure that man wakes up to this work. And is no longer taken advantage of. The ramifications of the damage already done to the earth are unfolding. Man takes information from enlightened people that are trying to do good and sells it back to them. Which nothing is wrong with that. But they should of been sharing the knowledge all along so we could of learned from each other. And together we would of kept a lot of what is to come from happening. The caveman within has won over the divine source but not for long.
Thank you for sharing the diagrams and information pengrove. They are very interesting to me. In my haste I missed that the source of the diagrams was there for me to see. I was unaware of this book "A new concept of the Universe" but I was aware of atomic suicide. To tell the truth I have yet to fully read the universal one. I will try to get to them very soon, I like the diagrams, they make a lot of sense to me. And the text attached within the diagrams is great way to do it.
Anyway thank you !
Not a "pro" but wanting to share an opinion...
Extracting energy from the vacuum implies to capture the "static field" that is all around us. In the beginning almost all were wanting to capture wattage, but you need to know that in the vacuum only exist potential gradients (pure voltage).
All we know that we can tap energy from the earth if we use an antenna (wire) elevated some meters from the earth's surface. Some people claims that the electrostatic potential is 125 Volts / Meter. Another interesting opinion is that the pure electrostatic potential can be transformed to electromagnetic energy and the electromagnetic energy's internal structure is made of pure static potential. To accomplish that, you need to use the negative electronic properties: negative resistance, inductance and capacitance. Since "closed circuits" are dissipative and "open circuits" could be amplifier.
A simple peltier module is capturing heat (energy that has been dissipated to the ambient) and emitting heat (power losses) in the other side. This effect is very well documented in the classic theory.
You can light a bulb using only back-emf and I can say you where that energy DOES NOT come from: it doesn't comes from the battery!
Tesla said that if the field was static then all the work would be in vain.
I believe that the field is not static as every interaction in the universe throws the system out of equilibrium. at this point the field becomes dynamic trying to rebalance the system.
The over unity devices I have studied have produced their excess of energy when we create an imbalance in the system. Tesla did this too. what would make more sense is to use natures imbalances and simply draw off the energy. Tesla certainly had been working on this and I believe morays device worked on this principal.
Our problem is not the understanding of this as many of us understand the principal, it is getting the mainstream to do it. We are aware of the powers that be that suppress this technology and we are not in a position to take them on directly, so we need to educate others at a ground level so that 5% of the population understands in the same way as the Imhotep fan helped me to understand.
5% is the critical mass in creating change in the world.
Keep up the education.
