Great resource on ether theory
  • Great resource on ether theory
    Hi all,
    Just stumbled across a great resource on ether theory:
    Aether Theories - Collation of Modern Scientific Theories of the Ancient Aether
    Particularly interesting are the theories by Paul Stowe:
    An Index of Physics Articles - by Paul Stowe
    Aetheric Framework Hypothesis for the ZPE Field - Paul Stowe
    Many of apparent inconsistencies that exist in our current understanding of physics have results from a basic lack of understanding of what are called fields. These fields, electric, magnetic, gravitational...etc, have been the nemesis of physicists since the birth of modern science, and continues unresolved by quantum mechanics. A classical example of this is the problem of an electron interacting with it's own field. This case results in the equations of quantum mechanics diverging to infinity. To overcome this problem, Bethe(1) introduced the process of ignoring the higher order terms that result from taking these equations to their limit of zero distance, in what is now a common practice called renormalization.
    These field problems result in class of entities called virtual, existing only to balance and explain interactions. These entities can (and do) violate accepted physical laws. This is deemed acceptable since they are assumed to exist temporarily at time intervals shorter than the Heisenberg's uncertainty limit. It has been known for some time that such virtual entities necessitate the existence of energy in this virtual realm (Field), giving rise to the concept of quantum zero point energy.
    As a result of this presentation I will propose the elimination of both the need for renormalization and any such virtual fields. This will be accomplished by replacing the virtual field with a real physical media within which we define elemental particles (which more precisely should be called structures) and the resultant forces which act between them.
    The scope of this presentation is limited to conveying basic concepts. No attempt will be made to try to derive all possible elements and processes that can result. To do so would result in encompassing all of known physics (a daunting task). Although the basic field concepts are extremely simple, even the simplest permutations are not.
    The Cause of Gravity, EM, & QM - Paul Stowe - Mountain Man's News Archive
    This article is to present an overview discussion for a conceptual model which is based on basic kinetic theory, and Maxwell's model of atomic vortices. It also encompasses gravitation and its Newtonian derivation, Quantum Mechanic & Planck's constant, and EM (as well it should, being based on Maxwell's model). The model does specifically predict certain differences that are not currently covered in the standard physics models as they exist today.
    Clearly, as I showed in "Simply Beauty", we can define all the QM/EM constants in terms of p, L, c, and the fine structure constant. So, in this regard, the model is both internally consistent and fully compatible with existing data. Moreover, it encompasses gravity, defines elemental charge, and predicts new aspects of known processes that can in fact be tested.
    Discussions on the Aether (Dan M. & Paul Stowe) - Mountain Man's News Archive
    I didn't seek to embrace an aether, for a noted before, I was taught to "believe" that the aether concept was definitively falsified. And I bought it. The path to the aether, was for me, a shocking experience. For I realized that, contrary to what I was taught, the falsification of the aether was a myth predicated on "assumptions", the validity of which has never been honestly re-evaluated in light of the weight of later observations. Further, Lorentz had provided an acceptable causal model (the ansatza) which was abandoned for purely philosophical reasons. This coupled with the "fact" that every aspect of modern physical phenomena are consistent with a physical medium, makes denying such a possibility IMHO an anti-science behavior.
    Problems & Philosophy in Modern Physics - Mountain Man's News Archive
    It is interesting to note that as we approach the close of the twentieth century that the state of physics is, IMHO, much worse off than it was at the same point last century. No, I don't mean we don't know more, clearly we do. But the advances in knowledge appears superficial, based upon "a rwverse engineering" approach rather than a first principles attempt at understanding underlying principles.
    I think it is this attitude, which I designate as a "modernist" after (Neil Bohr), that has resulted in the growing unhappiness that is driving the younger set to question/re-examine/re-access the very basis of this philosophy (which it clearly is). It is, with a straight face, very difficult to deny that there is something very physical about the state that we have come to call "empty space". So whether we call it space-time, zero point energy (ZPE), quantum foam, strings/superstrings, loop space, or (a)ether, there is something that can manifest it presence (which in it most basic form is energy).
    The nature of Charge - Paul Stowe
    Thus, there should be little doubt, given the preceding presentation, that the property we call charge is an inevitable result of field compressibility and inexorably connected to the wave properties of the continuum.
    Moreover, given this definition, Permitivitty and Permeability which today have arbitrary definitions, become density and inverse energy density (pressure/modulus). This facilitates the conversion of all EM/QM properties into prosaic medium properties and results in a completely consistent system that will match all physical observations.
    This one is also very interesting:
    Foamy Ether - A Framework for a Theory Of Everything
    The new ether model, proposed in this article, replaces the vacuum of empty space with foamy ether. Conventional atomic particles (whatever they are) are replaced with distortions in the foamy ether. Now this is the key difference! There is no matter in ether - but rather, matter is ether and so is space. That's it: the entire universe as we know it is comprised of foamy ether. The rest of this article will describe in detail many physical phenomena using the new ether model (i.e. gravity, electromagnetism, strong force, Relativity, Quantum Mechanics, etc.).
    Very interesting. Foamy ether == compressible ether....
    This guy has some nice animations that explain this:
    Gravity
    You may have noticed when viewing the particle forming simulation, that as soon as the nodes collapsed to form a particle, the ether immediately started to rush inward. This inward flow of ether is what causes gravity. To be more precise, the 'accelerating inward flow' of ether is gravity.
    Also nice to know that Tesla studied ancient literature, according to none less than Lord Kelvin:
    Aether (Akasha), Vedic Philosophy & Nicola Tesla - by Toby Grotz
    I do not know how I can ever thank you enough for the most kind letter of May, 10, which I found in my cabin in the Lucania, with the beautiful books which you most kindly sent me along with it: -"The Buried Temple", "The Gospel of Bhudda", Les Grands Inities", the exquisite edition of Rossetti's "House of Life", and last but not least the Century Magazine for June, 1900 with the splendid and marvelous photographs on pp. 176, 187, 190, 191, 192, full of electrical lessons.
    Also an "excerpt from an unpublished article called Man's Greatest Achievement" by Tesla:
    "There manifests itself in the fully developed being , Man, a desire mysterious, inscrutable and irresistible: to imitate nature, to create, to work himself the wonders he perceives.... Long ago he recognized that all perceptible matter comes from a primary substance, or tenuity beyond conception, filling all space, the Akasha or luminiferous ether, which is acted upon by the life giving Prana or creative force, calling into existence, in never ending cycles all things and phenomena. The primary substance, thrown into infinitesimal whirls of prodigious velocity, becomes gross matter; the force subsiding, the motion ceases and matter disappears, reverting to the primary substance."
    Wow, seems like Tesla wasn't the only "in" to Indian physics:
    Nikola Tesla, the great scientist who specialized in the field of electricity, was much impressed to hear from the Swami his explanation of the Samkhya cosmogony and the theory of cycles given by the Hindus. He was particularly struck by the resemblance between the Samkhya theory of matter and energy and that of modern physics. The Swami also met in New York Sir William Thompson, afterwards Lord Kelvin, and Professor Helmholtz, two leading representatives of western science. Sarah Bernhardt, the famous French actress had an interview with the Swami and greatly admired his teachings.
    So, lot's of interesting food for thought...
    Update: this is also very interesting, lot's of video's, etc:
    Free Energy and Free Thinking
    A figure which appears to be very interesting is Walter Russell, mentioned here:
    Walter Russell was one of the most accomplished artists, sculptors, writers and scientists of this century. His periodic chart of the elements accurately predicted the location and characteristics of four elements years before they were discovered in laboratories. These are now known as Deuterium, Tritium, Neptunium, and Plutonium. Russell apparently entered into a heightened state of awareness after being struck by lightning. He began several weeks of drawing and writing about the basic nature and make up of the physical universe. Russells' family finally called the family doctor to determine if Russell should be committed to an mental institution. The doctor, upon seeing the results of Russells weeks of work, said that he did not know what Russell was doing, but that he definitely was not mad.
    Although the exact time and occasion of their meeting has not yet been determined, Nikola Tesla and Walter Russell did meet and discuss their respective cosmologies. Tesla recognized the wisdom and power of Russells' teaching and urged Russell to lock up his knowledge in a safe for 1,000 years until man was ready for it.
    An interesting video on this fellow:
    Walter Russell - Cosmic Illumination as told by Michael Hudak
    Update 2:
    More on Russell on: University of Science and Philosophy - P.O. Box 520, Waynesboro, VA 22980 - Home
    Great graphics on vortexes here: University of Science and Philosophy - P.O. Box 520, Waynesboro, VA 22980 - Vortex Graphics
    And animations: University of Science and Philosophy - P.O. Box 520, Waynesboro, VA 22980 - Conical Wave Cycles
    Awesom Arend
    Really nice resources.. Many thanks.
    Another resources for non professionals like me:
    BriefHistoryAether
    NaturalPhilosophy
    Add these two on magnetism based on Aether theory:
    Magnetism
    Magnetism2
    Thanks again for your nice effort in this regard.
      Russels book, the one Tesla referred to, can be downloaded here:
      Read maybe 10 pages. Looks like the best manual for the Universe I saw this far...
        Fantastic links
        The following words struck me dumb:
        ''This is easily testable, all one has to do is create a
        "shaped" asymmetrical electric field and place any neutral object
        within the field an look for an imposed acceleration.''
        2 words ''Professor Turtur''.
        Ive been playing with a lafforgue thruster rep today....not very successful but early models inevitably are. I might have another go at something similar to what Turtur did tomorrow. Thanks for the inspiration lamare
          Originally posted by seth View Post
          Fantastic links
          Then I've got three more words for you: "Thomas Townsend Brown":
            Book linked in post #3
            Hi Lamare, once again excelent work, there are bigger diagrams than the one's
            I have, on page 156, p170, p192, p214, p229. Awesome stuff. I refer to the diagram on page 192 as the one I had seen before but a very small one that I couldn't read. That is in the book you linked to in post 3. By Walter Russell.
              to you too!
              I have put this book into some OCR software. Just finished the prelude:
              THE supreme service which man can render to evolving man is to answer for him, dynamically, the great heretofore unanswerable question concerning the One universal force which man calls God, or Mind, or by other names. For long ages man has impatiently awaited the knowledge which would tear away the veil from the invisible universe which lies beyond his perception and bring it within the range of both his perception and his exact comprehension. Mathematical and measurable proof of the existence of but One Mind, One force and One substance would give to man absolute control over matter, the power to create, even as God creates, and within the same limitations.
              Man is omnipotent when he but knows his omnipotence. Until that day he is but man. Voltaire said that man could never comprehend God for man must be God to comprehend Him. Man is God and therefore God is within the comprehension of man. Man is Mind. Man is matter. Mind and matter are One. God is Mind. This is a universe of Mind, a finite universe, limited as to cause, and to the effect of cause. A universe of limitations cannot be infinite. There is no infinite universe. A finite universe, in which the effects of cause are limited, must also be limited as to cause; so when that measureable cause is known then can man comprehend and measure all effects.
              The effects of cause are complex and mystify man but cause itself is simple. The universe is a multiplicity of changing effects of but One unchanging cause. All things are universal. Nothing is which is not universal. Nothing is of itself alone. Man and Mind and all creating things are universal. No man can say: "I alone am I."
              There is but One universe, One Mind, One force, One substance.
              When man knows this in measurable exactness then will he have no limitations within those which are universal. He will then know that all knowledge exists within man and is subject to his desire to recall it from within his inner Mind. Knowledge is not acquired from without but merely recollected from within. The recollection of knowledge from within is an electro-magnetic process of thinking Mind which is as exactly under man's control as is the generation of the same power to turn a wheel.Man must "think in light"; his thinking must be in terms of the electromagnetic periodicities which measure all motion, for of such is he himself, and nothing else.
              To know how to think in light from within is to open the doors of all knowledge. Omnipotence lies in perfect thinking. There is no power in this universe other than the energy of thinking Mind. Thinking is the cause of motion and the periodicities, or states of motion, caused by thinking Mind are registered in light which man calls "matter." Matter is light. Nothing is which is not light.
              We are prone to think that this civilization of ours is an extremely advanced one. On the contrary, man of today is in an exceedingly primitive state of his evolution. He is a bearer of heavy burdens, sweating at heavy labor in the bowels of the earth because of his pitiful ignorance of universal power which awaits only his knowledge to render it available for his free use. Knowledge of the One Thing will lift the yoke which man has placed on his own shoulders. This knowledge is herein written down in the language of a new dynamic science of new concepts which are measurable; which explain the heretofore unexplainable. Language is lacking in words to express new knowledge. Seemingly contradictory words must be used in the hope that the intent will be understood by taking all that is herein written and putting it together, rather than in trying to find comprehension through the analysis of a few inadequate words in isolated paragraphs. For all those questions which lie unanswered within the heart of man there is a dynamic answer, such an answer as two and two make four.
              Faith and theory regarding the universal One need have no place in the thinking of man. They are wanderings in the dark. All things are answerable in light. The universe is a tonal one, a dimensionless universe of light. All nature is a series of orderly tonal periodicities of the One force, assembled into the complex idea of thinking Mind, and registered in light, or matter, or energy in interchanging potentials, all of which are variable, yet comprehensible and measurable states of motion of the One substance.
              All dimension is an illusion, an appearance, due to rising potential, which must disappear into its inevitable sequence of lowering potential, and again appear in endless cycles of appearance, disappearance and reappearance.
              Ecstatic man is he who can think in those high octaves of the inner Mind which has been termed "spirit."
              Ecstatic man is inspired man of universal genius, of inner thinking.
              Inspired man is he to come whose thinking will be from within, in light, and it will be an ecstasy of thinking which will produce enduring things. That work which is created in ecstasy of inner thinking can alone endure.
              To think in light is not a new power being developed by evolving man. It is a power which is now within him awaiting only his knowledge of the use of that power. It is merely the recognition by man of his absolute control of the many dimensions of the universal constant of energy which constitutes the thinking process of Mind exactly as he can control the changing speeds of his motor car. When man can change the low speed of his objective thinking in this universe of dimension to the high speed of his inner thinking where dimension disappears in light, then is he superman. Then is he universal genius.
              Light is the universal language in which the Divine Concept is plainly written. Fundamentally wrong in its basic premises, and wasteful in its practice, man's modern concept of the universe must be torn down and built again on truth as plainly told in light. Primitive in his concepts, man divides the universe into the seen and the unseen, then finds himself groping in the dark, blindfolded, hopelessly trying to find the way to the door of the Holy of Holies.
              There is no unseen universe. The way to that innermost sanctuary of the Most High is as clearly posted as the Lincoln Highway; but man has not been able to read the plainly worded messages written all along the way in light. Man's most wonderful of instruments, the spectroscope, has told him little, for he has not yet learned to read it. He does not know that those many lines of light are but letters of the alphabet of light in which the universal One registers His mighty thinking in the universal language of light.
              The spectrum of iron is to man naught but the spectrum of iron. To the cosmic import of those many glowing lines he is indeed blind.
              Again, in helium he reads the lines as helium's lines and sees not in them the plain story simply told of six new elements of vast import awaiting man's use in the easing of his burden. And of those most important of the elements, which man calls the "inert gases," nothing at all is known except that they will not combine with any other elements. O the pity of it!
              Wrong concepts of the atom's structure and the modern electric theory, of energy and its transmission, of conductivity, radiation and gravitation, and of that electro-chemical state of opposed motion called luminosity, all of these wrong concepts of motion, and of matter, must be remoulded on truth. With truth comes knowledge; and with knowledge power to transmute at will, and simply, plentiful substances of matter into those which are the rarest, to meet the needs of man. There is no substance which nature produces which man cannot produce, or synthesize, or "create" from apparent nothingness when he knows that which is herein written down and charted. Man's miracles of today become commonplace events of tomorrow.
              Civilizations come and go, exalted by man's thinking or by it plunged into the abyss of darkened ages. This message is for all mankind and not for the few, for it is placing within his hands a power which could either glorify or frightfully enslave him in accord with the usage of that power. Either way it matters not, for in the end truth will survive, and man will complete his destiny.
              Truth lives. There is naught but truth and that which appears to be otherwise has no existence and therefore is not, nor ever will be.
              Don't know if I'll finish the rest of the book, it's quite a lot of work to correct all the errors...
              Update: A complete, OCR-ed version is available here:
              THE UNIVERSAL ONE, Pdf.
                Thankyou lamare. Much appreciated
                  http://www.energeticforum.com/108591-post25.html
                  I realise TTBrown was the pioneer with assymetrical electrical fields and acceleration, but i havent heard of him using neutral objects for acceleration. The only guy i know who did precisely that is Turtur - the rotor is just connected to ground, as im sure you know.
                  Does TTBrown also have a design where the acceration occurs in a neutral object?
                  Thanks again lamare - i appreciate the links.
                    Tesla on ether / relativity
                    Nikola Tesla : Tesla's Controlled Earthquake
                    Cosmic Ray Studies
                    He announced also the successful passage of an induction current with a varying flux through a circuit without the use of a commutator - a feat believed impossible since the days of Faraday. And he revealed studies of the cosmic ray which, he said, exposed many of the major tenets of the theory of relativity as falacious.
                    Dr. Tesla dealt harshly with the relativity theory, calling it "a mass of error and deceptive ideas wrapped in a magnificent mathematical cloak." He declared: "Its exponents are very brilliant metaphysicists rather than exponents of positive science. Not a single one of the propositions of relativity have been proved."
                    Nikola Tesla : Faster Than Light!
                    It may come as a shock, to most students of science, to learn that there are still in the world some scientists who believe that there are speeds greater than that of light.
                    Since the advent of Einstein, most scientists and physicists have taken it for granted that speeds greater than 186,300 miles per second are impossible in the universe. Indeed, one of the principal tenets of the relativity theory is that the mass of a body increases with its speed, and would become infinite at the velocity of light. Hence, a greater velocity is impossible.
                    Among those who deny that this is true, there is Nikola Tesla, well known for his hundreds of important inventions. The induction motor and the system of distributing alternating current are but a few of his great contributions to modern science. In 1892, he made his historic experiments in Colorado; where he manufactured, for the first time, artificial lightning bolts 100 feet long, and where he was able, by means of high-frequency currents, to light electric lamps at a distance of three miles without the use of any wires whatsoever.
                    Talking to me about these experiments recently, Dr. Tesla revealed that he had made a number of surprising discoveries in the high-frequency electric field and that, in the course of these experiments, he had become convinced that he propagated frequencies at speeds higher than the speed of light.
                    In his patent No. 787,412, filed May 16, 1900, Tesla showed that the current of his transmitter passed over the earth's surface with a speed of 292,830 miles per second, while radio waves proceed with the velocity of light Tesla holds, however, that our present "radio" waves are not true Hertzian waves, but really sound waves.
                    He informs me, further, that he knows of speeds several times greater than that of light, and that he has designed apparatus with which be expects to project so-called electrons with a speed equal to twice that of light.
                    Coming from so eminent a source, the statement should be given due consideration. After all, abstract mathematics is one thing, and actual experimentation is another. Not so many years ago, one of the world's greatest scientists of the time proved. mathematically that it is impossible to fly a heavier-than-air machine. Yet we are flying plenty of airplanes today.
                    Tesla contradicts a part of the relativity theory emphatically, holding that mass is unalterable; otherwise, energy could be produced from nothing, since the kinetic energy acquired in the fall of a body would be greater than that necessary to lift it at a small velocity.
                    It is within the bounds of possibility that Einstein's mathematics of speeds greater than light may be wrong. Tesla has been right many times during the past, and he may be proven right in the future. In any event, the statement that there are speeds faster than light is a tremendous one, and opens up entirely new vistas to science.
                    While it is believed by many scientists, today, that the force of gravitation is merely another manifestation of electromagnetic waves, there have, as yet, been no proofs of this. There are, of course, many obscure things about gravitation that we have not, as yet, fathomed.
                    At one time, it was believed by many scientists that the speed of gravitation is instantaneous throughout the universe. This is simply another way of putting it that there are speeds greater than light.
                    Yet, from a strictly scientific viewpoint, no one today has any idea how fast gravitational waves — always providing that the force is in waves — travel. If the moon, for instance, were to explode at a given moment, how long would it be before the gravitational disturbance would be felt on earth? Would the gravitational impulse or waves travel at the speed of light — that is, 186,000 miles per second — or would the effect be instantaneous? We do not know.
                    The entire subject will no doubt arouse a tremendous interest in scientific circles. It is hoped that other scientists will be encouraged to investigate Dr. Tesla's far-reaching assertions; either to definitely prove or to disprove them.
                    Nikola Tesla : No High Speed Limit, Says Tesla
                    Tesla disagreed with the part of the Einstein theory which states that the mass of an object increases with its speed. The mass of a body is unalterable, contended Dr. Tesla, According to the article, "otherwise energy could be produced from nothing, since the kinetic energy acquired in the fall of a body would be greater than that necessary to lift it at a small velocity."
                    Nikola Tesla : Pioneer Radio Engineer Gives Views on Power
                    It might be inferred that I am alluding to the curvature of space supposed to exist according to the teachings of relativity, but nothing could be further from my mind. I hold that space cannot be curved, for the simple reason that it can have no properties. It might as well be said that God has properties. He has not, but only attributes and these are of our own making. Of properties we can only speak when dealing with matter filling the space. To say that in the presence of large bodies space becomes curved, is equivalent to stating that something can act upon nothing. I, for one, refuse to subscribe to such a view.
                    Nikola Tesla : Tesla, 79, Promises to Transmit Force
                    Assails Theory of Relativity as Work of Metaphysicians and not Scientific
                    He confined himself yesterday to three of his startling adventures in the realm of theoretical and practical science. One of these, he said, "would appear almost preposterous." The second, he said with true candor, "would be considered absolutely impossible by any competent electrical engineer." The third would knock the props out from under the theory, of relativity, he said, but in this case also he expressed his doubt that the modern generation of scientists would take his challenge seriously.
                    Cites Cosmic Ray Proof
                    He described relativity as "a beggar wrapped in purple whom ignorant people take for a king." In support of his statement he cited a number of experiments he had conducted, he said, as far back as 1896 on the cosmic ray. He has measured cosmic ray velocities from Antarus, he said, which he found to be fifty times greater than the speed of light, thus demolishing, he contended, one of the basic pillars of the structure of relativity, according to which there can be no speed greater than that of light.
                    Cosmic rays, he asserted, he found are produced by the force of "electrostatic repulsion"; they consist of powerfully charged positive particles which come to us from the sun and other suns in the universe. He determined, "after experimentation," he added, that the sun is charged "with an electric potential of approximately 215,000,000,000 volts, while the electric charge stored in the sun amounted to approximately 50,000,000,000,000,000,000 electrostatic units."
                    The theory of relativity he described as "a mass of error and deceptive ideas violently opposed to the teachings of great men of science of the past and even to common sense."
                    "The theory, "he said, "wraps all these errors and fallacies and clothes them in magnificent mathematical garb which fascinates, dazzles and makes people blind to the underlying errors. The theory is like a beggar clothed in purple whom ignorant people take for a king. Its exponents are very brilliant men, but they are metaphysicists rather than scientists. Not a single one of the relativity propositions has been proved."
                      Used as a referenced by none other than Eric Dollard.
                      William Lyne's "Occult Ether Physics"
                      Books written by William R. Lyne
                      If you have any serious interest in ether physics, Mr Lyne is top notch in his research.
                        Just stumbled across another great site with lots of info:
                        Especially this page is very interesting:
                        • #14
                          Finally People are catching the drift
                          YES haleluah Eureka.
                          Finally people are coming to understand the true nature of our reality.
                          Lots of good stuff & links above I concur. Forget all you learned about Electricity and physics it's mostly bull****. Aether is not so hard to understand. Many "Giants" have left us copious breadcrumbs to follow.
                          We need only stand on their shoulders to see farther.
                          Brother Sagan mentioned "READ the RIGHT books".
                          Read about N.Tesla,V.Shauberger,T.T.Brown,W.Russell.J.Keely.W .Reich.T.G.Heironomous. D.Pond.D.B.Larson.N.Stubblfield.E.Leedskalin. and so many others.
                          Several of these people "Harvested" the Aether with real emperical results.
                          No business or government will even condone this, it will only emerge as an underground popular movement.
                          EACH of us must replicate,teach,emancipate ouselves.
                          • #15
                            Not your Fathers electricity.
                            The real "juice" everyone's chasing is the LEM which runs perpedicular to the "Current" running through the wires.
                            E.Dollard dissected and explained and showed us this.
                            (Peter may be a genious, but he sucks as a camera man, Hope he has a good sense of humor. I liked when T.Brown gave Eric the speeding ticket from the Relativity police)
                            T.Beardon concurs.
                            Nature accords this fact.
                            Traditional coils are used to separate & INSULATE the LEM from TEM while providing a medium they both may traverse.
                            I see so many people striving and acheiving results but don't understand this simple premise. It's NOT your Fathers Electricity we are dealing with here. A degree in Elec.Eng could be a severe handicap.
                            Need Translation read D.B.Larson
                            BEMF= a cruel joke
                            Spontaneous Discharge of a Knife switch = A DEADLY cruel joke.
                            Transverse Hetzian=Bad, retarding, limited to light speed,half a banana.
                            Longitudinal = +lightspeed+. Juicy,infinate. instantaneous.
                            IMHO
                            We live in a bathtub of energy and need only expend the energy to pull the plug then suspend a propeller over the hole to tap the flow.
                            WHY IS THIS SO HARD?
